Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
Drives: 2015 Series Blue BRZ WRB
Double checking, these are the correct part numbers 901000394 or Toyota/Scion part # SU003-02818
Can you safely run two in each side, to achieve more camber? |
#2 |
Drives: 22 BRZ limited
With Camber bolts in the lower holes, the lower bolts now become crash bolts for the top holes. I got -1.9 deg camber both sides on the front with stock PP suspension.
#3 |
Drives: 2014 scion frs
Part numbers look correct. According to subaru, the bolts are reusable but the nuts are not. Nut #902380008. Stock subaru camber bolts (one per side) will give you -1 deg camber.
#4 |
Drives: '13 FRS - STX
No, the second bolt is the exact same as the camber bolt, swapping it for the factory part does not net any additional camber.
-1.1 maybe a bit more if you're lucky with one set of camber bolts. https://www.ft86club.com/forums/showthread.php?t=103609 |
The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (07-03-2020) |
#5 |
Drives: '15 BRZ RA
Attached are the details. As other mentioned , you'll get a maximum of -1 deg camber.
#6 |
Mine is just 0.6 mm with Subaru Camber bolts...
#7 |
Drives: 2014 GT86
mm? Isn't it toe that's measured in alternatively inches or mm aswell no just degrees/minutes, not camber?
#8 |
Drives: '15 BRZ RA
#9 |
Sorry, I was in hurry, my camber went from stock 0 to around 0.5 degrees.
The Following User Says Thank You to gpvecchi For This Useful Post: | nikitopo (07-04-2020) |
#10 |
Drives: 2016 Scion FRS Release Series 2#439
Double SPC camber bolt sizes;
Lower location is a 14mm bolt. Upper location is a 16mm bolt. I use both plus Peddars Offset Top Mounts (-.75). All three combined achieve -2.75 front camber, without coil-overs. In my case Koni Yellows with TRD springs. Alignment by Alex at Burning Rubber (Oakville, ON). Last edited by Muskoka800; 07-16-2020 at 04:29 PM. |
Camber bolts or crash bolts for max spring perch clearance? | norcalpb | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 01-29-2021 11:53 AM |
OEM Camber Bolts (Crash Bolts - SU003-02818) | dieseldan444 | Brakes, Suspension, Chassis | 2 | 07-12-2018 09:06 PM |
Max camber on OE crash bolts?! | warmwetness | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 09-11-2016 10:43 PM |
DIY | Video Installing Camber Crash Bolts | Dezoris | DIY (Do-It-Yourself) Guides | 24 | 09-06-2016 11:07 AM |
Part Number for OEM crash (camber) bolts for FR-S? | Rampage | Tracking / Autocross / HPDE / Drifting | 4 | 07-10-2013 11:14 PM |
