04-29-2020, 05:39 PM | #5447 | |
This is also why even a header swap will make the Jackson Racing factory tune not work. |
The Following User Says Thank You to CSG Mike For This Useful Post: | imprezive (04-30-2020) |
04-29-2020, 10:54 PM | #5448 |
I’ve got a high flow second cat. If I want to run the carb tune I need to switch back to the stock pipe correct?
04-29-2020, 11:19 PM | #5449 |
04-30-2020, 05:52 PM | #5450 |
pessimistic skeptic
FYI: CARB tune is running fine with my catless HKS dual resonated front pipe and 2017+ stock header since almost a year. More power at high rpm and more mpg with normal driving, and no CELs.
04-30-2020, 06:59 PM | #5451 | |
It seems like an unnecessary risk with questionable reward. |
04-30-2020, 07:51 PM | #5452 | |
pessimistic skeptic
04-30-2020, 07:55 PM | #5453 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | ybotspawn (04-30-2020) |
04-30-2020, 07:56 PM | #5454 |
pessimistic skeptic
There is a MAF sensor for that purpose. There is no such assumption.
04-30-2020, 08:01 PM | #5455 | |
Drives: 13 Subaru BRZ
Jackson Racing Supercharger Owners Thread
Correction map sensor, different principle entirely. I’m not going to attempt to debate you on what you’re doing and why it’s bad. Generally though I tend to believe guys like @ know more than I do. Good luck with the ticking time.... ummm motor Sent from my iPhone using Tapatalk |
04-30-2020, 08:04 PM | #5456 | |
Drives: brz 2017 hksv2
only bad things I would think of about upgrading to catless without returning, is the performance left on the table ecu won t rise ign timing more than it is allowed to, and cam timings could be made more aggressive and with less overlap at higher rpm also at lower rpm and loads it could need some fix |
04-30-2020, 08:09 PM | #5457 | |
pessimistic skeptic
The Following User Says Thank You to mrg666 For This Useful Post: | tomm.brz (04-30-2020) |
04-30-2020, 08:09 PM | #5458 | |
Also, it relies entirely to a pre-set scaling Primary lambda is what catches AFR fluctuations but the ecu must be in a closed loop mode (either stock logic, or ecutek CL fuel control) to take action and correct that AFR to follow the target CSG Mike maybe forgot, but the master tuner of his company is already enabling closed loop mode all the time at all rpm |
04-30-2020, 08:10 PM | #5459 |
yoy were right about knock relief when going catless, but to take effectively advantage of its scavenging potential, needs to be retuned again
The Following User Says Thank You to tomm.brz For This Useful Post: | mrg666 (04-30-2020) |
04-30-2020, 08:13 PM | #5460 | |
pessimistic skeptic
Edit: I actually did. Worked with one of the most popular places. They sent me a tune which was garbage that I couldn't even drive. Second iteration was no better. I said keep the money and cut the chase, installed the stock MAP sensor and flashed back the JR factory tune which is working great. |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
