Drives: 2013 Hot Lava frs 6MT
Car wont start and everything is connected properly
I just replaced my transmission, and the car started before I took it off the jack stands, and then once I put it back on the floor, it wouldnt start. Not sure as to why it decided to not start now. The transmission is dripping a little bit of fluid and I'm out of coolant. But I'm not sure which one is the issue.
Update: I added coolant and transmission fluid and it still wouldnt start. It would crank but not start. Last edited by P.navarro86; 12-08-2019 at 12:22 AM. Reason: Update |
#2 |
Do you have any power mods?
You sure their is gas in the tank? Is the battery cranking over the engine strongly? Why was the engine out of coolant? Did you do anything else to the car when you messed with the transmission? Sounds like it's not getting fuel to me - ![]() humfrz |
#3 |
[insert cool phrase here]
Drives: BRZ Premium
Odd as why you need coolant?
Check your starter cables. Check that you didn't fry the battery or fuses. Does it crank, or does it try to start? Your tranny shouldn't leak. Not sure how you could be low on tranny fluid? Unless you have an automatic...... Do you have an automatic transmission? That would explain the coolant...
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#4 |
Put it back up, unplug and check all connections you disconnected then go again.
I would hazard to guess it's just a bad connection. Once fixed ensure you do some mad skids to show the car who is the boss.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#5 | |
snap out of it, Mr.ac, pay attention, his sig says his car is a MT. He stated that the car cranks over, but just won't start - ![]() Best the ease that bottle of whisky back into the liquor cabinet and mention to the OP you have a nice selection of civics for sale - ![]() humfrz |
#6 |
I just put a gallon of gas in, but it said I had a quarter tank prior to that. And then I tried to start it and nothing happened so I tried to jump start it and it just made a whirring sound. Also no power mods.
#7 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Did you take the flywheel off? If yes, remove the torque converter bolt access cover and rotate the engine by hand with a long ratchet on the crank bolt. The flywheel should run perfectly straight. If you've got the locating pin hole located incorrectly it may be crooked and the starter may have trouble engaging the ring gear.
#8 | |
Drives: BRZ Premium
How did you guess I was halfway into a bottle? For the record I'm a cognac man.
| The Following 2 Users Say Thank You to Mr.ac For This Useful Post: | gravitylover (09-06-2020), humfrz (12-08-2019) |
#9 | |
You mentioned in your first post that "It would crank but not start". I'm confused. Does the starter turn the engine over or not? ![]() humfrz Last edited by humfrz; 12-08-2019 at 10:59 PM. |
#10 | |
![]() A Cognac man, well ain't you a fancy drinker - Back in my drinking days, I just drank American made stuff - ![]() OK, back to regular programming. humfrz |
#11 | |
Drives: BRZ Premium
Back the the topic, sounds like a dead battery. If it made a whirring sound that makes me think the battery had just enough juice to move the starter. Or that the starter was or is not fully engaged to the fly wheel. If all else fails, try taking the tranny out again, yeah it's a pain. But you'll might find the answer if you do. Third and more costly, tap out and pay a mo'canic. Not what any diy-ers want to hear.
#12 |
So I probably killed the battery trying to start it, but i didnt disconnect anything except the transmission itself. I left the clutch and flywheel alone. And it would crank over in the beginning but not start
#13 | |
humfrz |
#14 |
Thank you! I'll look into it
| The Following User Says Thank You to P.navarro86 For This Useful Post: | humfrz (12-11-2019) |
| BRZ having issues detecting key fob properly to start | bovined | Issues | Warranty | Recalls / TSB | 3 | 09-06-2019 01:38 AM |
| Car wont start? Anyone else? | ScionFrsFan | Issues | Warranty | Recalls / TSB | 150 | 06-09-2017 10:35 PM |
| Doing it right ... from the Start, Help me get my FR-S Sorted properly | SCIONMONTREAL | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 07-09-2015 11:31 AM |
| car wont start after tune | JesseTheFlash | Software Tuning | 7 | 12-17-2014 01:43 PM |
| Car Wont Start Up HELP !!*** | ScionFR-S | Issues | Warranty | Recalls / TSB | 20 | 11-28-2013 02:01 AM |
