Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-09-2019, 08:04 PM | #1 |
Drives: BRZ Limited PP
Are FactionFab F-Spec Coilovers any good?
I don't know much about these, but I'll try to make a pro/con list based off of what I've seen. Most of the info that I've found relates to the FR-Specs which are basically a more expensive version of these, and not what I'm looking for.
PROS: -Affordable -Doesn't reuse the factory tophats unlike other entry coils such as Tein Streetbasis z -Has dampening adjustment CONS: -Maximum drop is 2.4" front, 2" rear (I only want to drop 1" to 1.5" so not a big deal) -No camber adjustment (the 1-1.5" drop probably won't affect the camber too much) If anyone has these or is able to give me some insight about these, I would really appreciate it. Are there any other negatives I should know about? |
11-09-2019, 10:22 PM | #2 |
Well a big negative imo is that these are cheap coil overs and you’ll eventually switch to something else in due time, wasting money on these in the process.
When it comes to suspension you need to buy nice or you will buy twice. |
The Following User Says Thank You to norcalpb For This Useful Post: | Tristor (11-10-2019) |
11-09-2019, 11:08 PM | #3 |
Drives: 2014 GT86
I'd also reconsider how much you want to drop. 1.5" is a lot (OEM there is ~ 2.5" bump travel including bumpstops), as there is not much on twins to begin with. If you are looking for as cheap as possible coilovers, i guess your budget is limited. Thus i suggest to keep lowering within 1", to not need extra parts to fix issues from overlowering, like roll center adjusting kit, diff risers. One thing, how much specific coilovers spec they allow to lower, other - how much it makes sense to do, to not fsck up geometry, not get increased wear of CV joints, make ride unbearably harsh and car with problems clearing speedbumps and driveways.
The Following User Says Thank You to churchx For This Useful Post: | Tristor (11-10-2019) |
11-10-2019, 05:05 AM | #4 | |
Because compromise ®
Drives: Red Herring
1/ A totally meaningless term. I'm guessing you mean they are within your budget. 2/ Lots of clicks are often a marketing pitch: 32 clicks is more than 24 clicks therefore the most clicks win. KW V3 12 clicks rebound and 12 clicks compression. Tein SRC 16 clicks comp and 16 rebound. AST 5200 11 clicks comp 12 rebound. If you can't tell the difference between one click adjustment there is no point. 3/ Really? If you want a decent ride with short suspension travel you are going to have to pay for it. As @churchx said above, the car doesn't have much rear travel to begin with. Yeah, you can drop the car on a budget but don't expect much in the way of comfort or damping. Have a read of this: How to screw up your cars handling and ride - step by step!
11-10-2019, 02:11 PM | #5 |
Looks like you’ve already got some accurate responses. Find my huge post in the FB group for details, but long story short, the cheapest and best way to drop an inch is to get the RCE combo kit and find someone’s used PP Sachs dampers. None of the “budget” coilovers are good, they’re universally absolute trash. Anyone who says otherwise doesn’t know wtf they are talking about. You’re looking at a minimum entry price of $1500 for acceptable coil overs on this platform and good ones start above $2k.
Lowering a street car can be done comfortably with good dampers and springs. Our factory suspension is technically already a coilover, it’s just non-adjustable. If you don’t know what you’re going to use adjustments for and have no plan there, having adjustments just introduces another variable to mess up. If you want something better than the PP dampers, get Bilstein B8s and the matching Eibach springs, you can buy them together as the Bilstein B12 Pro-kit for $1100. Cheap suspension rides like shit and doesn’t perform either. If you’re going to slam it to the ground it doesn’t matter because you’re ruining the car anyway, but if you care about quality at all don’t buy garbage parts for your car. Save to do the right thing the first time. |
11-10-2019, 04:26 PM | #6 | |
11-10-2019, 04:41 PM | #7 | |
Also, I've seen multiple people recommend the Tein Flex Zs as the best budget coilovers, and they run around $850. Do you think it would still be better to run the rce kit instead? I'm pretty new to suspension stuff, so I'm not really aware of the cost, but I do care about ride quality and I'll spend more if I have to. Thanks for the help |
11-10-2019, 04:43 PM | #8 |
Drives: '13 FRS - STX
People who sell parts always have the very best parts in stock.
The Following 2 Users Say Thank You to strat61caster For This Useful Post: | DarkPira7e (11-10-2019), wparsons (11-13-2019) |
11-10-2019, 06:01 PM | #9 |
Drives: 2014 GT86
I'd first rethink what and why and if you want to change.
Rethink your goals, better word them in questions, do own homework of gathering info without rush, stick around in forum reading sections and threads about similar themes you think about to reduce cases of reinventing bicycle, ask more specific questions to clarify some details, and only then, if at all, shell out money and mod anything. From info of your post there is too much guesswork left to us of what you want (at most from lists of what you consider good or bad in coilovers). For answer to question if some cheap specific coilovers are "any good", people already answered - in most cases no, most cheap are crap, with rare exceptions. But even better then average exceptions .. they do specific changes to car. But will those changes be what you yourself want (and haven't stated)? Back to suggestion to well think through what/why/if you want to change and what are your goals. |
11-10-2019, 06:33 PM | #10 | |
11-10-2019, 06:58 PM | #11 |
Get lowering springs, Eibach, RCE, Swift, rsr, whatever. If ride is bouncy grab a set of Koni or Bilstein dampers, still cheaper than bad coilovers.
11-10-2019, 09:03 PM | #12 | |
Drives: #337 2017 Toyota 86
If you can wait and have the budget, Xida coilovers with the touring spring pack are the answer.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
The Following User Says Thank You to Lincoln Logs For This Useful Post: | wparsons (11-13-2019) |
11-10-2019, 10:37 PM | #13 | |
*The more you know* |
The Following User Says Thank You to strat61caster For This Useful Post: | Captain Snooze (11-10-2019) |
11-10-2019, 10:37 PM | #14 | |
Given you already have PP, you can just get the RCE Yellow kit. It has upgraded bump stops that work with the lowered ride height, which is an important consideration. The combo kit from RCE also comes with rear LCAs and front camber bolts to allow for you to get a proper alignment after lowering. Find a decent alignment shop local to you so you can get a good alignment, don't go to a chain tire store as most will just "toe n go" your car. Based on your goals and budget, and the fact you have a PP car, you should go for RCE Yellows. As others have mentioned though, by all means please do as much research on your own as you can before buying stuff. |
The Following User Says Thank You to Tristor For This Useful Post: | wparsons (11-13-2019) |
Tags |
budget, coil overs, factionfab |
Similar Threads | ||||
FactionFab Twin Muffler Titanium Catback, any experiences or reviews m | Rogues Gambit | Engine, Exhaust, Transmission | 47 | 12-07-2020 11:25 PM |
FS: NJ - RS*R MOTO SPEC COILOVERS | dirtbike250x | Brakes, Suspension, Chassis | 1 | 06-07-2019 03:47 PM |
WTB RSR MOTO SPEC COILOVERS | ChrisGeezy | Want-To-Buy Requests | 1 | 03-05-2018 02:58 PM |
Buddy Club Racing Spec Coilovers - SpeedFactory Style - Good Photos and Video. | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 03-25-2016 05:22 PM |
Not a BRZ/FR-S, but some CSG-Spec coilovers in action... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 2 | 03-13-2013 11:30 AM |
