Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
07-06-2019, 12:04 AM | #43 | |
Benz Tech
Drives: 2017 BRZ Premium
Me either, not deep enough. |
07-06-2019, 09:15 PM | #45 |
CVT issue?
07-08-2019, 09:58 PM | #46 | |
Drives: 2013 Subaru BRZ
Is it easy to install the vacuum pump? |
07-08-2019, 10:18 PM | #47 |
extra what?
Look for the link in my sig line. You'll be able to find the below pages in context.
BRAKE SYSTEM (OTHER): VACUUM PUMP: REMOVAL; 2013 MY FR-S [03/2012 - ] BRAKE SYSTEM (OTHER): VACUUM PUMP: INSTALLATION; 2013 MY FR-S [03/2012 - ]
The Following User Says Thank You to Ultramaroon For This Useful Post: | xkenx1995 (07-08-2019) |
07-08-2019, 10:51 PM | #48 | |
Ahh thank you for this. Do I need a new o ring or any other part numbers along with the vacuum pump? Sent from my iPhone using Tapatalk |
07-08-2019, 11:32 PM | #49 |
extra what?
You'll need an o-ring and a tube of the engine glue. The tough part will be surface prep. Don't underestimate the need for attention to detail and cleanliness.
07-13-2019, 09:35 PM | #50 |
Hey guys just an update I am bringing my car in to get it checked out on Monday. I listened more with the stethoscope and had my sister rev the engine to about 1.5k. Before I had no one to ask to rev it for me lol. I’m almost certain it’s the vacuum pump now because it rattled and clicked became way more noticeable with the RPMs going up. I have a spare vacuum pump that I bought when I spun a rod bearing with the first motor, and I don’t trust myself installing it properly without it leaking. Fingers crossed!
The Following User Says Thank You to xkenx1995 For This Useful Post: | ActionMaxon (07-14-2019) |
07-16-2019, 11:14 AM | #51 |
Another update: I won’t be able to bring my car into the shop until Thursday because they’re busy, but I noticed every cold start seems to spit out some fluid (oil? Coolant? Unburnt fuel?) it only comes out of the right side tailpipe. I noticed where I parked for work is starting to build up.
07-16-2019, 11:16 AM | #52 |
Drives: Crapcan
Its condensation. Don't worry about it.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | humfrz (07-16-2019) |
07-16-2019, 11:30 AM | #53 |
I agree. However, the OP may wish to give the exhaust a sniff test. If it smells like oil, it's oil, if it smells like coolant, it's coolant, if it smells like gas, it's gas, if it smells like exhaust gasses it's water.
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | xkenx1995 (07-16-2019) |
07-16-2019, 11:35 AM | #54 |
Drives: Crapcan
What if it smells like blueberry swirl
The Following User Says Thank You to NoHaveMSG For This Useful Post: | xkenx1995 (07-16-2019) |
07-16-2019, 11:53 AM | #55 | |
CVT issue?
Okay I placed a paper towel on it and kept it on there for a while and took a whiff. To me it doesn’t smell sweet or like anything out of the ordinary. Would there still be condensation even if I park in my garage? I parked overnight so I would assume there would be no condensation the next morning. Sent from my iPhone using Tapatalk |
07-16-2019, 12:29 PM | #56 | |
Back in the old days, when exhaust pieces were made of steel, that's what would help rot them out. Not so much of a problem with modern SS exhaust systems. humfrz |
Similar Threads | ||||
Automatic Transmission issue- dealer is not recognizing the issue, please help! | Arrex | Issues | Warranty | Recalls / TSB | 36 | 06-03-2019 04:15 AM |
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? | darkbluemn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-05-2018 08:49 PM |
HELP! CEL + TC issue!!! | JC0830 | Issues | Warranty | Recalls / TSB | 45 | 01-28-2017 04:33 PM |
BRZ Nav MP3 issue | TheRipler | Electronics | Audio | NAV | Infotainment | 5 | 09-06-2013 02:21 PM |
Cel issue | Z06tofrs | Issues | Warranty | Recalls / TSB | 2 | 08-27-2012 10:13 AM |
