#43 | |
My 86 with subframe and diff support inserts has enough NVH to annoy the missus that she wants the windows down if we go for a drive, even when its 35!° C. Noise mainly, some vibrations at certain RPM's. 75% of my noise comes from the Whiteline diff inserts. The added NVH from inserts doesn't bother me "much" though.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#44 | |
#45 |
Drives: BRZ 2018
I installed finally the tS >16 lower stoppers with tS longer bolts in all four subframe corners.
Car seems little bit more predictable when sliding or during weight transfer on continuous corners, imho it should have them from the factory. No NVH increase, may be due to stiffened rear end it is more comfort now but the difference is tiny anyway. |
| The Following 2 Users Say Thank You to JIM THEO For This Useful Post: | nikitopo (02-09-2019), Prodigalson (11-20-2024) |
#46 |
All 4? Shouldn't they go in front only?
#47 |
Drives: '15 BRZ RA
There were some reviews in the past that the fronts do most of the work, but I'm thinking now that it is best to install all 4. You should get a bit more improvement with the rears. It looks that STI installed only the fronts to keep the cost lower. Not so much because of the additional cost of the part, but the additional installation work. I remember to pay more for labor than the parts when I installed the front in my car. Normally you don't remove completely the subframe, so I guess you need extra time if you do both front the rear.
#48 | |
Drives: BRZ 2018
#49 |
Drives: 2013 Raven FR-S
Has anyone mentioned the spoon rigid collars yet? I plan on doing those in conjunction with the WL subframe inserts.
Spoon has a cool video explaining how the rigid collars work, but in short, they help mate the irregular surfaces of the subframe and chassis together. Manufacturing processes don't allow perfect mating surfaces between the subframe and chassis, and these are supposed to fill in that area making the mounting points completely flush. This supposedly equates to a whole bunch of handling goodness ![]() https://www.spoonsports.eu/50261-na1-001.html Some of the speedhunter guys have them on their cars as well. http://www.speedhunters.com/2018/01/...-honda-heaven/ http://www.speedhunters.com/2011/06/...s_to_the_gt_r/ |
#50 | |
Drives: BRZ 2018
See yourself the difference between the tow bolts:
#51 |
Huh, interesting. So the "TS" bolts are different dimensionally, and still work?!
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#52 |
I'm really interested in some thoughts from the group on this topic. I am planning to do something relatively soon, and I'm split on whether I should run Spoon rigid collars, or if I should go for full solid bushings like those from SPL, or if I should do bushing topper inserts like the Whiteline ones for my subframe. I really want to reduce subframe slop, because as I've gotten stickier tires it's more and more obvious how much the body moves.
What's the consensus on the best solution that isn't going to absolutely torture me if I happen to drive on a rough road (which is unfortunately all over the place here in SATX)? |
#53 |
Daily driver? It all comes down to you, man. How hardcore are you? I drove solid subframe and diff mount along with all kinds of other "track" parts a hundred or so miles everyday for months. Some of my friends hate how loud the exaust is in the car, or how much vibration there can be while driving, harsh bumps. And I completely understand why, but they're also just a passenger, they dont feel the wheel in their hands, or how the car moves under you. All essentially useless when you're sitting in your commute. The largest noticeable differences for me was how quick the rear responded to hard throttle/clutch kicks, cured wheel hop and quick direction change stability.
| The Following User Says Thank You to 15limited For This Useful Post: | Tristor (02-27-2019) |
#54 | |
Potato Farmer
Drives: #SLOBRZ
I have sound deadened my boot, which helped with noise (and got rid of exhaust drone) My car is my work car, so i put on a fair few km's, and had done drives from Melb to Canberra and the noise doesn't worry me.
Something something butter..
www.vic86brzclub.com |
| The Following User Says Thank You to fuddbutter For This Useful Post: | 15limited (02-27-2019) |
#55 | |
ThisGuyLoves86's
Drives: 2013 Scion FRS
Can you clarify if you install 4 tS uppers and 4 lower tS stoppers? And 4 of the longer STI bolts? Thanks! -Jason
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car) 2003 Nissan Pathfinder (R50) (current car) 2018 Lexus GX460 (current car) 2023 GR86 Neptune M6 Premium (Leased) |
#56 |
You can fit 3 stoppers, the lower are not compatible on the back.
4 longer bolts are OK |
| Sold | 86TOYO2k17 | Transmission and Driveline | 9 | 03-28-2020 03:00 PM |
| Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? | eckoflyte | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-14-2018 12:24 PM |
| FS: SuperPro subframe inserts & LCA inner bushings | xn7485 | Brakes, Suspension, Chassis | 1 | 09-13-2017 04:23 AM |
| whiteline rear subframe inserts | charged86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 05-18-2013 10:20 PM |
