#3935 |
Drives: 2017 subaru brz red, 93 FD RX7
Anyone run Michelin X-ice 3 215/60/r17's? wondering if theyll fit with the performance package wheels.
The Following User Says Thank You to deku For This Useful Post: | Leonardo (12-18-2018) |
#3936 | |
Country Boy 4 Life
Stock size is what I'd suggest. If you want taller, a 205/50/17 or 225/45/17 would work too.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | deku (11-24-2018) |
#3937 |
Drives: 2014 GT86
Also, as x-ice3 was mentioned and it's apparently winter tire, i suggest for winter choosing narrower tire, of eg. 205 or 195 width.
#3938 |
Country Boy 4 Life
There are no 195/50/17 or 195/55/17, so unless OP goes to a 16, a 195 is not going to happen.
I LIKE TIRES! |
#3939 |
hmm ill have to return them then. i found some blizzak ws80s today, 215,45r17. thanks for the help guys
The Following User Says Thank You to deku For This Useful Post: | Leonardo (11-24-2018) |
#3940 |
Drives: C7P Gt86
Hi, can i fit on stock gt86 18x9J et40 (225/40r18)in front without modifications? In future I want lowering spring 1inch drop, thanks
#3941 |
Drives: 2015 BRZ
Yes on stock there will be no issues maybe some poke in the front though. I dont think there should be any issues after lowering 1" either.
#3942 |
Drives: C7P Gt86
#3943 |
Drives: Toyota 86
A little help and advice needed
I just got Federal 595 RS-RR tires from my friend, the sizing is 245/40/R18.
So I am also looking for 18x8.5 +35 wheels, my ride has TEIN Street Flex with approximately 1 inch height drop. Currently running with TE37 +48 with 25mm wheel adapter, 215/45R17 tire size. I wonder if my new setup will have any problems? |
#3944 |
Drives: 2015 BRZ
#3945 | |
Drives: 2015 BRZ
#3946 |
Drives: Asphalt FR-S
Currently running 17x8 +45 wheels with 235/40. Kind of debating going 245/40. Right now the sidewall is flush with the rim. FYI stock ride height and enkei TSP6 wheels
![]() Sent from my Pixel 2 XL using Tapatalk |
#3947 | |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
EDIT -> Nevermind my post, I was talking about 18" not 17", my bad, sorry
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 Last edited by Killerbee; 12-18-2018 at 08:17 PM. |
#3948 |
Country Boy 4 Life
Hey, whats up? This is totally wrong. 245/40/17 is the same diameter as the stock 215/45/17. Additionally, 245/35/17s do not exist.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | Killerbee (12-18-2018) |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
