#85 | |
#86 |
Country Boy 4 Life
I LIKE TIRES! |
#87 |
Drives: 2014 Subaru BRZ
I just got the Kansai new version that has just one "big" bolt and nut, with a hole drilled through the plates. Anyone install this version yet? The bolt seems way too big to fit without scraping paint off the body of my car.
I'm planning on cutting the clip hole in them and drilling ends for smaller bolts that will fit nicer. Unless there's a trick I'm missing? ![]() ![]() Sent from my SM-G925V using Tapatalk |
#88 | |
#89 |
Wise old man
Drives: 86 GTS
how do you get to the underneath of the front section of the bumper? total removal of all undertrays?
#90 | |
Drives: 2013 BRZ Limited
#91 | |
#92 | |
#93 |
How do I shift?
Drives: '13 GBS BRZ
The one from OP's pic makes the most sense. Anyone knows a similar fix to it? The new ones just seem like way too much trouble.
#94 |
#95 |
Drives: BRZ Turbo
#96 |
How do I shift?
Drives: '13 GBS BRZ
Update: purchased the side marker bumper bracket for driver's side + headlight bracket for both sides and this is the result:
Note on first pic the gap on fender and headlight ![]() Then look at the same places: ![]() So the little metal thing is a great idea for an easy fix, but after doing this I realized that is not the main issue. The brackets were bad to begin with, so they've made new ones. And while it's not 100% fixed (more like 99), this is more of a permanent fix than the original tool in this thread.
| The Following User Says Thank You to carsebuco For This Useful Post: | amaciose (04-17-2018) |
#97 | |
#98 | |
| bumper sag repair, anyone tried this yet? | nickmerronesucks | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 07-28-2016 11:14 PM |
| Bumper repair | keneyy | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 10-19-2015 06:30 PM |
| WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement | mariolefty1 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 05-06-2013 05:52 PM |
| Front Bumper repair | grgonium | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 01-15-2013 07:25 PM |
| Bumper Repair | Thatruth2001 | Northwest | 1 | 09-12-2012 02:15 AM |
