| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Drives: 2017 Subaru BRZ
#16 |
Wise old man
Drives: 86 GTS
AD08R like 30 PSI hot too
#17 | |||
Drives: GT86
If you think about the current range and how good the PS4 is in smaller sizes, and having the Cup 2 for those of us who want the very best dry handling, having 3 sport/performance (or 4 if you add the remaining PSS sizes) tires makes little sense. Quote:
Obviously you can't compare to more track-oriented tires, but you have to keep in mind it is a road tire. And a really good one. I don't know why, temperature/pressure wasn't the issue. Perhaps i just had really big expectations after all the good words about them. Dry handling was good but they lasted less than 10,000km on a car weighting less than 900kg, which is quite absurd considering i am a smooth driver. Wet handling is not very good because of how hard the sidewalls are, which also had a big impact on ride comfort.
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday |
#18 |
Drives: 2014 GT86
Iceman: if AD08R lasted only 10Kkm, now imagine how long cheater tires like RE71R might last
. If one of pros of Essex BBK kits was hailed cheaper & longer lasting wearables (much thicker pads of common shapes) that let BBK to pay-off soon, then imho many underestimate tire wear importance for self-financed track day enthusiasts.
#19 |
Drives: '15 BRZ RA
A052 vs. RE71-R
[ame="https://www.youtube.com/watch?v=yPW2UxP0pt4"]A052 VS RE71-R - YouTube[/ame]
Left is the RE71R and right is the A052. A052 2018 1/20 2'07"97 RE71R 2017 2/18 2'08"36 |
#20 |
Drives: GT86 Cosworth
Ive been running AD08Rs for the last couple years.
Ive done around 8km road and 6 or so trackdays. They have around 3.5-4mm tread left and the last trackday it was wet and they were terrible. i couldnt get any heat and they just slid about. A friend on PS4s had alot more grip. id say 20seconds in a lap. Is it possible my AD08R have be heat cycled out? They are about 3 year old (been on my car 2 years) and have been used in two winter and recently in sub zero. One day it was -6C and snowing. I love them i nthe dry and these A052 caught my eye as they have an A rating for wet grip. |
#21 | |
Drives: '15 BRZ RA
It is true about the wet grip rating of the A052, but on the other side the Yokohama global site(*) provides the rain symbol only on the AD08R's. So, I am not sure who is correct and who is wrong. Someone that maintains the Yokohama site or the European testing agency? In general the A052 tires are quite expensive and still don't have many reviews. I was tempted to test them, but it is a lot of wasted money if their wet grip is not better. (*) https://www.yokohamatire.com/advan-tires |
#22 |
Swiss Alps Driver
Drives: Toyota gt86
small bump on this old thread.
I have purchased a set of A052 for my car, for track purpose only. So far, i've tested them only on the wet. They're very good on the wet. Best tyre i've purchased being honest under those conditions. I was way faster than a lotus A380 cup with PS cup2 at this time.
| The Following User Says Thank You to vgarcin For This Useful Post: | nikitopo (12-02-2018) |
#23 |
Only users lose drugs.
Drives: All the time
What have your previous track tires been?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#24 |
My Japanese is lousy, to say the least. Still, entertaining to watch...and a direct comparison of RE-71 and A052 on the 86 platform, though in larger 245/255 size, from what I could see. He was trying as hard as he could to keep up with that FD RX7..lol. The results at the end clearly show the A052 as a direct competitor to the RE-71R on track, though I don't know what the test conditions were...cold tire? Warmed up and then a single hero lap? What are they like after 20+ minutes? I see mention of 3 and 6 lap measurements, but I don't know what the ratings were.
[ame]https://www.youtube.com/watch?v=oAc0ew8vFKA[/ame]
#25 |
The A052 is superior to the RE71R for raw grip and heat capacity, but cost significantly more.
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#26 |
Swiss Alps Driver
Drives: Toyota gt86
I have tested a lot of different compounds:
Federal 595 RSR Toyo R888R Yokohama AD08R Michelin Pilot Sport Cup 2 On the dry, i'm running michelin slicks S8C I have not tested the A052 on the dry yet, but knowing Yokohama, they should be quite good.
#27 |
If the extra grip and heat tolerance mean the A052 ends up being a more durable track tire than the RE-71, then a good portion of that cost increase is removed. Now, if I could only get my current set of tires to wear out faster..lol.
| The Following User Says Thank You to venturaII For This Useful Post: | CSG Mike (12-04-2018) |
#28 | |
Drives: 2014 GT86
| The Following User Says Thank You to churchx For This Useful Post: | venturaII (12-04-2018) |
| FS: Yokohama ADVAN AD08R 245/40/18 | fungus | Canada Classifieds | 3 | 06-04-2017 07:07 PM |
| Yokohama Advan V105 | Cope52 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-20-2015 12:10 PM |
| Yokohama Advan RSII Peeling | jcat5150 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 04-18-2014 08:38 AM |
| Yokohama S-Drive? Advan Neova? | OnionTou | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 07-10-2013 01:51 AM |
