Old 11-14-2017, 01:53 PM   #1
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I rattle canned a $700 Volk wheel
In my defense, the wheels were worth nowhere near that in the state I got them in.
After spending the past 14 months on house related projects, I decided I finally needed to do something I actually enjoyed. It would have been significantly easier and definitely smarter to just have them powdercoated since it is an infinitely more durable finish but I just needed a fun hobby right now. Honest thing is, the wheels may never see asphalt and could end up being turned into some JDM end tables.
I have never spray painted wheels before and I started with reading every tutorial online possible. One thing I found was no one seems to want to put effort into this. Most threads described this as a 4 to 12 hour project. I spent a little bit of time per day over two months.
In an effort to consider them refurbished, I tried to find replacement decals but sadly could only find knock offs.
If there is interest, I'd be down to share a DIY.
Original shape:
Slowly and carefully filled up scratches and chips
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following 7 Users Say Thank You to Laika For This Useful Post:
Aluma007 (11-14-2017), bcj (11-14-2017), Clipdat (11-15-2017), D_Thissen (11-15-2017), Guff (11-15-2017), Lonewolf (11-16-2017), mrg666 (11-15-2017)
Old 11-14-2017, 02:11 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Turned out nice for rattle-can, nice jerb.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
Laika (11-15-2017)
Old 11-14-2017, 02:13 PM   #3
StraightOuttaCanadaEh
Wes
looks amazing, well done. I agree, if done properly, it looks great, but patience is needed, as well as good prep. Surface, primer, clear coat, etc., not to mention the techniques during the actual painting process. Good job
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Laika (11-15-2017)
Old 11-14-2017, 02:28 PM   #4
Rattle cans get a lot of undeserved grief. It's all in the prep.
Looks great!
The Following 6 Users Say Thank You to Ultramaroon For This Useful Post:
D_Thissen (11-15-2017), Laika (11-15-2017), Leonardo (11-15-2017), Tcoat (11-15-2017), Teseo (11-14-2017), wparsons (11-15-2017)
Old 11-15-2017, 09:01 AM   #5
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Looks great!
The prep part is completely accurate. No it’s not exciting but it needs to be done for a proper finish. Any defect you leave behind will be magnified once painted. I will still say my rattle can skills are trash but that’s why I put extra effort into the prep part and this method definitely works.
If anyone is curious, I went through quite a few colors before deciding on Rustoleum antique brass metallic. I swear the stuff should just be called “universal JDM wheel paint”. Then I topped with Rustoleum Crystal Clear Enamel
The Following User Says Thank You to Laika For This Useful Post:
Ultramaroon (11-15-2017)
Old 11-15-2017, 10:43 AM   #6
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Will durability be an issue when you mount tires? Seems like the finish would get immediately blemished causing things to start peeling later... I'm a paint idiot though, so with all the prep that was done it may be ok!?
That being said, looks durn good!
Subaru STI :
Old 11-15-2017, 12:51 PM   #7
sirsol66
Drives: 2013 FRS- Hot Lava
What specific brand and color did you use? It looks like the Rustoleum vintage bronze, but i'm surprised how close to Volk bronze it looks honestly.
sirsol66 is offline   Reply With Quote
Old 11-15-2017, 01:01 PM   #8
D_Thissen
D_Thissen's Avatar
Nice work! I sandblasted and painted some 04 Impreza wheels with a rattle can and they turned out half decent. Not as perfect as powder coating, but for <$100, I cant complain.
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 11-15-2017, 01:33 PM   #9
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
SpeedElement (or any authorized distributor) can get a hold of replacement decals. I got some along with center caps for my TE37 on my MR2. Nobody lists them for sale usually but they are available.
http://www.mackin-ind.com/rays/
Laika (11-15-2017)
Old 11-15-2017, 04:36 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Nice color choice, can't go wrong with gold!
Originally Posted by humfrz
I'm old and lazy
Laika (11-15-2017)
Old 11-15-2017, 04:44 PM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Nice job! I "rattle-canned" my side skirts, BRZ fender garnish(s), and a few other parts on my car. If done properly, you can't tell.
I LIKE TIRES!
Laika (11-15-2017)
Old 11-15-2017, 09:07 PM   #12
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Thanks man! I’m hoping that because I went with a clear enamel, it should be strong enough to resist some abuse but may require a cash tip in advance when getting tires mounted.
Rustoleum antique brass. The vintage bronze is a bit too dark for me and honestly my phone doesn’t do an amazing job of capturing the color well or even consistently. I’ve never seen bronze CE28’s in person but I’ve seen bronze RE30’s and I’d say mine are a bit lighter.
Those look fantastic! What was the brand/color you went with? I might need to do that for my silver 07 Impreza next summer.
Kimsey47 (11-15-2017)
Old 11-16-2017, 09:42 AM   #13
D_Thissen
D_Thissen's Avatar
Thanks! I used 4 cans of Dupli-Color Graphite wheel paint, and 1 can of their clear coat. The only issue I had with paint peeling, was on the plastic centre caps. I forgot to scuff them up a bit lol. My OZ Ultraleggera's have quite a few chips in the paint from the last 3 years of driving. I might sandblast them and try painting them the same colour.
https://duplicolor.com/product/wheel-coating
Tcoat (11-16-2017)
Old 11-16-2017, 03:32 PM   #14
cjd
cjd's Avatar
Drives: 2017 BRZ
Let it cure enough before getting tires mounted and it'll probably do OK. I used what I suspect is the same clear enamel on my RacerX LCA's (raw aluminum) and they've held up quite nicely given the road debris that gets churned up in their direction.
I can only imagine how much patience was required to do this. Nice work.
Race Freely/Federal Tires Car Meet+Canned Food Drive RaceFreely Southern California 0 11-08-2017 12:49 PM
Wheel Directory: Volk GT-P 18x7.5 +44 airwak Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-09-2015 09:09 PM
Stance Nation Hawaii Meet and Canned Food Drive March 30 eight08customs Hawaii 15 04-01-2013 04:57 PM
Wheel Directory: Volk Racing GT-C 18x7.5 +43 BugeyedWagon Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-28-2013 03:30 PM
Lip polishing on a Volk wheel TuxedoCartman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 11-28-2012 05:53 PM
