Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-27-2017, 09:30 PM | #141 | |
Drives: 2013 FRS
Hello Allen, we already work on a fix for the rattle. It comes from strong vibrations within the gearbox and our shifter increases them. We are also in contact with our partners in the US and will announce the delivery of an add-on asap. We take this very very serious and are full aware of the issue. Thank you for reaching out to us. I will inform you personally as well as soon we have a 100% solution in place. Best regards Marcel. Very good and sincere followup , but I did ask about my issue with the lockout button and didn't receive an answer. I have heard about grease from a fellow member, but in terms of cable, are there any adjustments I need to or can make? |
The Following User Says Thank You to ft86me For This Useful Post: | ATL BRZ (06-29-2017) |
06-28-2017, 05:57 PM | #142 | |
Drives: GTS 86
It looks like it didn't take the pictures, but is post #103 |
The Following User Says Thank You to Hawk77FT For This Useful Post: | ft86me (06-28-2017) |
09-03-2017, 12:36 AM | #143 |
Drives: 2014 WRB BRZ Limited
So the fix kit for the vibration is out.... has anyone tried it out? Does it work?
09-12-2017, 12:00 PM | #144 |
Drives: Toyota 86
Installed the shifter rattle fix, and it does not improve the situation that much. Maybe slightly less rattle below 5,500 rpm, but that's it.
Anyone else have a solution? |
09-26-2017, 02:11 AM | #145 |
Drives: 2015 CWP BRZ
Is the shifter rattling like crazy for anyone in gears 1-3 from 2-3k rpm? I have the rattle fix installed but it isn't doing anything for me. Also rattles in the higher gears but above 3k rpm or so.
It definitely isn't from the button either, sounds like a loose bolt at the bottom of the shifter although I didn't leave any bolts loose.... |
09-26-2017, 08:07 AM | #146 |
Drives: Toyota 86
Installed the anti-rattle kit from IRP and no dice. Still rattles. Seems like it is the button or the rod underneath the button. Does anyone have a root cause for why it rattles?
09-26-2017, 06:12 PM | #147 | |
Drives: GTS 86
Investigating the fix with them as we speak! |
09-28-2017, 07:10 AM | #148 |
Drives: 2014 Whiteout FRS
If someone can't take the rattles and wants to sell let, me know. 😎 I'll deal with the rattles, have been since day one.
Sent from my Pixel using Tapatalk |
09-28-2017, 08:47 PM | #149 |
Drives: Toyota 86
09-28-2017, 10:39 PM | #150 |
Drives: World Rally Blue BRZ
Thanks! Do let us know if you guys come up with anything
10-02-2017, 12:58 AM | #151 | |
Drives: '17 Hot Lava 86
The car is very notchy when cold, but still a little notchy when hot. I know that the shifter itself may not alleviate the problem, but with the throws being so short, does it make the notchiness harder to feel? I just want to have a buttery smooth gearbox and I don't know how to go about accomplishing that. The car serves as a daily driver for now, but plan to start some autocross events with it soon. Thanks |
10-02-2017, 08:38 PM | #152 | |
Drives: Toyota 86
Suggest you consider getting a slightly heavier shift knob (I loved the RaceSeng Apex R) and some good transmission fluid for what you are after. Personally, I enjoy the IRP, but between the rattles and the stiffer shifts it is not for everyone. |
10-02-2017, 09:39 PM | #153 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
I have a suggestion for someone to try with their shifter to get rid of the rattling. I brought this up when I got a solid transmission mount on my trans and it has me convinced this is similar. Someone should look at creating a rubber mount to go between the hanger and bolts for the exhaust hanger that bolts on to the transmission. I think it is transmitting engine vibration along with exhaust vibration into the shifter. If someone wants to try that, see if this helps. You are going to have to possibly widen the bolt holes on the hanger and add in a rubber grommet to absorb all of the vibration, otherwise just placing a rubber piece between the hanger and transmission isn't enough because those bolts will be on the hanger and mount. Someone let me know if this helps at all. If I don't hear anything I will test this out myself once I buy the shifter and swap it out. I have been super busy lately with moving and the new house so I can't do much right now.
The Following User Says Thank You to Drakiv For This Useful Post: | Hawk77FT (10-02-2017) |
Similar Threads | ||||
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 09:57 PM |
WTB: Megan Racing Cat-Delete pipe And short shifter | AZ_Racer_1 | Want-To-Buy Requests | 1 | 01-25-2015 12:54 AM |
kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
Short Vid about Okinawan Street Racing | vividracing | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 03-03-2014 10:29 PM |
TOM'S Racing Parts, First from Vivid Racing! | vividracing | Exterior Parts - The Rest | 4 | 09-11-2012 04:20 PM |
