07-20-2017, 08:18 AM | #295 | |
To win a Super you HAVE to have a pairing or 2 get lucky for you. It's the name of the game |
07-20-2017, 12:32 PM | #296 | |
Drives: 2022 BRZ
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
07-20-2017, 01:13 PM | #297 |
Drives: DS FRS
I got a 2nd once as well. The winner spun through the finish line on the final side and went down the narrow finish chute backwards without hitting anything and beat me by 0.003 seconds. Obviously, this was all a very long time ago when I was young and virile
-Max H.
07-20-2017, 06:19 PM | #298 | |
Custom User Title
I was talking with Mark most of the weekend he was definitely trying to win but he had some strange issues with his TPMS sensors turning his traction control on mid-run and then something else with car setup after that. Packwood is a tough site to get your car dialed in for as it's not flat, grip changes significantly depending on where you are, and sometimes we have some pretty difficult bumps. There isn't a lot of areas to put your foot down and go so conserving momentum is pretty critical. Huh? Are you mistaking me for Brian?
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
07-20-2017, 07:31 PM | #299 | |
Drives: DS FRS
-Max H.
07-30-2017, 12:21 AM | #300 |
Drives: Series 10 FRS
So I have been running RE71Rs , but decided to try a set of Rival 1.5S on my DS FRS. I have read for many cars, people find 2-5 PSI more than RE71Rs is optimal for Rivals. Is that what others have found for twins with 225/45-17s? Thx for any insight...
07-30-2017, 06:09 PM | #301 |
Drives: 2013 Asphalt Scion FR-S
I think you can actually run the same pressures as you do on the Stones, but I'd recommend exactly what you stated to save the shoulder a little bit of wear. I haven't seen any drop off when running a bit under 35 psi when I started running them around 30 psi or just under, but the wear is improved.
07-31-2017, 04:58 PM | #302 | |
Custom User Title
Different topic: I've tried the Nexens because the BFG and Bridgestone were out of stock for all of June and I hate them. Can't wait to get back onto BFGs at Nationals.
07-31-2017, 05:04 PM | #303 |
Drives: DS FRS
Curious - why do you hate them and how do you feel they compare?
-Max H.
07-31-2017, 11:03 PM | #304 | |
Custom User Title
With the BFGs there was minimal push and it was easy to dial it back in. I couldn't quite get the oversteer I wanted that I liked with the Bridgestones but it made up for it a lot with mid corner and corner exit. The Nexens do turn in much quicker though which is a huge plus over the BFGs and they're slightly quicker at turn-in than the Bridgestones.
07-31-2017, 11:20 PM | #305 |
Drives: DS FRS
Thanks for the feedback. I've only driven my car on Nexens, although I've raced the BFG and Bridgestone on other cars. On the Nexens, I can loosen the car up pretty well just by stiffening the rear shocks. We'll see if that holds true in Lincoln.
-Max H.
08-01-2017, 06:48 PM | #306 |
Custom User Title
56 entrants and I know of at least one more coming tonight. 5th biggest class this year! Hopefully they kick the Camaro out next year so the twins don't just die in street.
The Following User Says Thank You to Locust For This Useful Post: | Shark_Bait88 (08-02-2017) |
08-02-2017, 01:56 PM | #307 |
Drives: 2016 FR-S
How much of that is the Camaro and how much of that is the driver? I get to go up against Brian locally but the altitude doesn't help when going up against WRXs.
08-02-2017, 04:22 PM | #308 |
Custom User Title
I assure you guys the Camaro is an overdog in this class. We'll see what happens at nationals but don't be surprised at how much faster it is.
Similar Threads | ||||
SCCA Solo Street Modified (SM) Discussion | whataboutbob | Tracking / Autocross / HPDE / Drifting | 61 | 07-27-2020 10:03 AM |
SCCA Solo C Street Discussion | Kido1986 | Tracking / Autocross / HPDE / Drifting | 4833 | 07-08-2020 03:52 PM |
Gen3MR2's C Street (SCCA SOLO) Progress | Gen3MR2 | Tracking / Autocross / HPDE / Drifting | 0 | 02-12-2016 01:02 PM |
2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
Henry's C Street (SCCA Solo) progression | Kido1986 | Tracking / Autocross / HPDE / Drifting | 74 | 05-04-2014 08:20 PM |
