Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
03-02-2017, 04:28 PM | #29 |
Drives: 2017 TOYOTA 86
I have a 2017 86 and I would not say its ever had a "rough" idle. On a cold start before it reaches operating temp, I get a small shake every once in a while, but the rpms do not drop and there is not any sound associated with the shake. When I say shake I mean 1 at a time. It reminds me of what it feels like when a car passes by when you are stopped at a red light and the air turbulence causes your car to feel like it is nudged by the air. It is very, very subtle though. Once it is warmed up, you would barely be able to tell it's running if you could not hear the direct injection (HPFP and injectors).
03-02-2017, 05:56 PM | #30 |
Drives: Scion FR-S 2015 Blue and stock
Mine is a little rough when it first starts, but once warm, I have no issues.
Some observations: - On start the car idles at a higher than normal level, this continues for a minute or two, and once warm the idle drops. - If I let the car start rolling out of my parking spot (in neutral, while warming up) the idle will drop as soon as I start moving. Seems like there is a sensor. - I try to warm the car up for at least a minute or two every morning, drives much better warm, at least in my opinion. Sorry to hear about this, my car has been rock solid since I got it (knocks on wood). |
03-02-2017, 08:29 PM | #31 | |
Is this your first ca ever? Every car made since they invented the automatic choke starts at high idle an drops once warm enough or you move it.
The Following User Says Thank You to Tcoat For This Useful Post: | burningjello (03-03-2017) |
03-02-2017, 08:57 PM | #32 |
Drives: 2017 BRZ Limited
high and steady at first, then drops around 40 seconds in, then stable and slowly goes down until hits about 600rpm..
03-03-2017, 10:05 AM | #33 |
Drives: Firestorm red FRS 2015
My FRS 15 idles rough sometimes, I think it depends on where I get my gas... but I haven't really plotted it yet. I was told at the dealership they can flash my car with an update? I think I might do it soon.
03-03-2017, 04:24 PM | #34 |
Drives: '13 FR-S A/T - Stock
Does a vibrating shifter knob indicate a rough idle? It seems like more often than not, lately, mine will be slightly vibrating, and then I grab it and notice, yeah, this thing is shaking a bit.
03-03-2017, 06:05 PM | #35 |
Drives: 17 86
Thanks for the replies, and I'll know to be very specific next time. Going to see if the dealer has one I can sit in at idle to compare. I'll let you know if mine is "normal" or not.
03-03-2017, 06:29 PM | #36 |
Drives: 2017 GT86
I had a 13 FRS and just bought an 86 a month ago
The FRS would idle high at warm up and the drop to 5-600 and idle fine, except for the crickets but they never really bothered me much. The 86 idles high at warm up and drops to 5-600 after that. So far no crickets The only difference I have noticed at warm up is the 86 seems to idle higher for longer than the FRS did |
03-03-2017, 06:36 PM | #37 |
Drives: 2015 Raven FRS
Oil pressure on a hot engine at idle (750) is only 3 to 5 psi. That's scarry low. So I had my tuner (Shawn Church) raise the idle to 950 so now my idle oil pressure stays at 20 psi when hot. Car idles smooth except when the AC is on. Then rpm goes up and down as AC compressor comes on and off. Also being supercharged that adds some more draw off the engine. But all in all can't complain a bit.
03-04-2017, 10:12 AM | #38 |
Drives: BRZ DGM Limited
2013 BRZ...idle is smooth all the time, even before it warms up. Driven in temps from 98 to 10 degrees. Only idle issue is that with fast stops it will dip a few RPMs and then recover
03-05-2017, 08:55 PM | #39 | |
Now I am older and wanted a car that was sort of like a bike: not too convenient, more fun than most to drive. But with heating. And windows. Got this. So its all good, I am many things: husband, small business owner, computer guy. Nobody that knows me would say I was a car guy. I do love my FRS though, and I have been learning a lot including from you and this forum. So thanks! |
The Following User Says Thank You to sgtcarrot For This Useful Post: | Tcoat (03-05-2017) |
03-05-2017, 09:07 PM | #40 | |
03-05-2017, 10:18 PM | #41 | |
extra what?
There's always that one guy. Pretty awesome.
03-07-2017, 02:06 AM | #42 |
Drives: Toyota GT86 Coupe Red (UK)
My 2014 UK spec GT86 idles fine most of the time.
The AC compressor clicking in and out raises and lowers the idle by about 100rpm. Sometimes clutch drag causes it to hunt, falter, recover, repeat. Shifting into neutral sorts it immediately. However occasionally, like for 2 or 3 weeks every year the idle routinely falters when the AC compressor clicks off. Revs drop below 500, car shakes and it recovers. Then 10 seconds later the compressor kicks in and out again and it falters again. After it's little spell for a few weeks it returns to normal.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
Similar Threads | ||||
Unofficial - CEL/SL/Idle Issue List for FR-S/BRZ Owners | eurospeed | Issues | Warranty | Recalls / TSB | 3105 | 05-06-2024 06:47 PM |
Any series.blue owners or lip/skirt owners drop their car? | spicyricecake | BRZ First-Gen (2012+) -- General Topics | 43 | 03-04-2015 04:40 PM |
Are FT86 owners future Ferrari / Lambo owners? | pantdino | Scion FR-S / Toyota 86 GT86 General Forum | 126 | 08-31-2014 08:23 PM |
Any wisdom from IS300 owners? How bout Miata or S2000 owners? | Ocean-Grown 86 | Member's Car Journals | 7 | 08-22-2014 11:52 AM |
FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 03:12 AM |
