Drives: Scion FRS
Heated Mirror DIY
Here is the DIY for installing heated mirrors. I used aftermarket mirror glass, but you can adapt these to use if you buy complete mirror assemblies to. It took about 2 hours to do the second side.
I am not responsible for any damage you cause doing this. Parts(for both sides): Rexpeed or other mirrors(Rexpeed did not sponsor this) 6 x Sumitomo 8240-4422 090-3 multilock terminal unsealed (I think AMP 368084-1 090-3 receptical will work) 2 x AMP 353537-2 040-3 tab 4 x AMP 316836-1 040-3 receptical Wire: I used 18 awg high abrasion resistance going to the door because it is exposed. I think 22 awg is what the existing harness is Heat shrink electrical tape. Subaru Relay 82501AG041 Tools flat head screw drivers. swedge or trip removal tools. #3 phillips screw driver or socket Wire Stripper Crimper Fish Tape Directions
The Following 8 Users Say Thank You to markitect For This Useful Post: | BWilky (11-17-2016), Dadhawk (11-16-2016), DIE1000DEATHS (11-18-2016), emutcfut (12-15-2016), NahumCC (11-17-2016), thatfilipinoguy (11-16-2016), Trap63 (11-12-2016), Ultramaroon (11-11-2016) |
#2 |
Drives: Scion FRS
I think this should cover it pretty well, if you guys have any questions let me know.
The Following 2 Users Say Thank You to markitect For This Useful Post: | Dadhawk (11-16-2016), thatfilipinoguy (11-16-2016) |
#3 |
Drives: 2013 FR-S 10 Series
Good write up for the non keyless entry FR-S. Thank you for taking what I started with on my 10 series and making it easy for everyone else.
Sent from my SAMSUNG-SM-G891A using Tapatalk |
#4 |
Drives: 2017 86 Asphalt
might be a stupid question, but could i just buy the door wiring harness from the models equipped with the heated mirrors and just replace the one in my door right now? it seems that the heated mirror wiring goes all the way to the harness already and just needs connecting?
#5 |
Drives: Scion FRS
You might be able to find a junk yard harness, but it seemed like more work to pull it through. You might even need to remove the door, when I was looking at the best way to run the wire I concluded that the harness is installed in the footwell, going outside before the door gets put on.
#6 |
Drives: 2015 Scion FR-S
Thanks for the great DIY! I'm planning to install my heated Rexpeed mirrors this weekend and I haven't had a look at the passenger side yet, but I assume the process for adding the wiring is the same or at least very similar?
FS: Passenger Side Mirror Housing(non heated) | OmarGC | Exterior Parts (Aero, Lighting, Etc.) | 1 | 10-13-2016 11:53 AM |
FS: Brand New Blue convex mirror (heated element, led turn signal option) | ucsmfu | Exterior Parts (Aero, Lighting, Etc.) | 8 | 08-20-2016 02:48 PM |
FS: Brand New Blue convex mirror (heated element, led turn signal option) | ucsmfu | Canada Classifieds | 4 | 08-19-2016 03:26 AM |
FS: Like new BRZ/FRS Rexpeed blue wide angle mirror non heated | Mint86 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 06-04-2016 10:20 PM |
DIY Request: heated mirror install | 1Cor10:23 | DIY (Do-It-Yourself) Guides | 16 | 02-13-2015 05:17 PM |
