Software Tuning Discuss all software tuning topics. |
#15 | |
Drives: 2013 BRZ Limited WP
So I added the OEM intake back, capped off the sound pipe, and didn't install the part that goes under the bumper.. Reflashed the e85 tune and drove around for about 20 miles. LT trim after the drive is at 20%. ![]() So AFR is at 14.6:1 and LT trim goes to 0 on acceleration. When I first started the drive, LT trim was 3%. Gradually rose as the drive went on. I can't reflash to 93 right now bec i have more than 3/4 of e85 left in the tank. |
#16 | |
You can add a gallon or two of 93 to lower the ltft as the oft tune is a slightly safe tune and good for e60-e70 or so. I suggest checking for exhaust leaks, and double check which e85 tune you are running. There is a open flash header e85 tune and non ofh e85 tune which is a little more conservative. After all that, I'm all out of ideas and suggest you to post on the e85/oft thread or make a new one. |
The Following User Says Thank You to swarb For This Useful Post: | DarkMatter (09-06-2016) |
#17 | |
Drives: subaru brz
Another thing worth mentioning is that before I add that gallon of gas I can hardly start my car on the first try in the morning around 60 degrees but now I have no problem starting my car. So I assume the ethanol percentage is really high before adding petrol, because ethanol does not evaporate as much as petrol in low temperature and causing the ignition problem. |
The Following User Says Thank You to zmz0305 For This Useful Post: | DarkMatter (09-06-2016) |
#18 | |
#19 |
Drives: UK GT86
If you're on about the intake tube (AKA snorkel) then not having this in place will leave you more susceptible to high IATs after being stationary which will have a knock on effect to fuel trims.
.: Stealth 86 :.
#20 |
Huge E85 fan!
Drives: 2016 Scion FRS
Do you have a catch can? If so, check the vacuum lines and make sure they are tight. You could have a vacuum or header leak with high pos. fuel trims.
At idle and at 2500 RPM, how is your LTFT compared to your STFT? Does your STFT shoot up as you rev it? |
#21 |
Drives: subaru brz
I just tried, STFT does shoot up to around 5% when rev up to 2500RPM. Does that mean I have a leak?
#22 | |
Drives: FT86
stft will move rapidly with load and throttle application this is normal. just look at your ltft oft tunes will have low ltft with arround 70% ethanol above 75% or high ethanol will see ltft trend positive lower than 70% ethanol will see ltft trend positive once you see over 10% at anything above idle then it indicates large variance in e% or you have other problem like intake or exhaust leak or maf scaling issue to aftermarket intake |
The Following User Says Thank You to steve99 For This Useful Post: | zmz0305 (09-10-2016) |
#23 |
Huge E85 fan!
Nah, 5% is nothing. It doesn't look like you have a leak.
The Following User Says Thank You to guybo For This Useful Post: | zmz0305 (09-10-2016) |
#24 |
Drives: 2013 Scion Frs 6mt
Bro e85 varies every time you put a new tank in. I'll scale my MAF for one full tank get it perfect than I'll fill up again it'll be off by a couple percent. Your intake is definitely causing the high fuel trims. Scale your MAF... If you don't wanna do it in sure me or Steve or KN47 will do it... Perhaps for a fee... I don't know depends how generous they are because time is money... but I promise either one of us will promise you some results lol... Oh to really achieve even better drive ability there's a few tricks I'm sure we know as well (;
#25 | |
Drives: subaru brz
I added some 93 and it all goes well. Very unfortunately I cracked my OFT screen this morning and I am screwed now ![]() ![]() |
Anyone else with ECUTEK having fuel trim issues. | Shit Luck | Software Tuning | 12 | 11-14-2021 10:58 PM |
Sudden high fuel trims - help please! | cawith | Issues | Warranty | Recalls / TSB | 13 | 10-15-2015 04:30 PM |
Crawford Billet Power Block LT ST Fuel Trim levels | Subaru86 | BRZ First-Gen (2012+) -- General Topics | 0 | 09-30-2015 07:48 PM |
