#15 |
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
Stainless lines are not a bad upgrade on a daily. But for the first few years your OEM lines will be just fine for street use.
If you drive on the street AS IF you were on the race track, then you will enjoy the consistency they give over the years. ![]() Pads with more grip will expose the need for better feedback that lines can give. One thing I like about them for, for street cars, is that when your braking hard you will have better control of that limit when the car goes into ABS, for example. As folks have said above... Lines do vary in quality A LOT, for example, all are braided hose, but some have a clear sheath over the braid and some manufacturers have ditched that or made it 'optional' to save some cost. Some brands are not even technically street legal... So what we are telling you is do your homework before trying to save money on a part that WILL kill you if it fails. ![]() I know we have used Technafit, Speigler, and Goodridge in the past with good results on all sorts of cars, not all of them have the nice application specific fittings for our cars though. Stay away from no-name brands, etc. |
#16 |
Drives: GBS BRZ Limited
Oh I was originally looking at the StopTech lines and wouldn't buy ANYTHING not DOT rated for street use. I have no problem paying for quality parts, especially when my life's on the line. This was more a "while I'm at it" thought process.
What I think I'll do is wait until I need brake pads, then bleed the system, swap the lines, and put on some Hawk pads or something since everyone seems to agree its not necessary on a brand new car. |
#17 |
Isn't it the other way around? I've never heard of stock lines failing but i've heard of SS lines bursting.
#18 |
Sure is. The Speigler lines are 2x the cost of the "no-name" $100 set mentioned above. Do you trust the cheap stuff with the single most important safety system on your car?
#19 | |
But yeah, anything steering or braking related is a top priority for myself. |
#20 | |
Drives: Some rust bucket
Nevertheless, always inspect your brake lines whenever you can. |
#21 |
Drives: Scion FR-S
#22 |
SS lines are a waste of $$$ IMHO, they trap heat and dirt can get in the braids and eventually wear even silicon lines. Get a higher quality rubber line. Seen so many SS lines fail before rubber lines.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#23 |
Rambling Man
Drives: 2013 FR-S 6MT - In Heaven Now
Personally, I don't care about looks, especially since no one sees them. Better braking performance would definitely be a bonus. The main reason I'm switching, some may not agree with, but it makes me more comfortable and I'm in the car, so I'm going to try it. The reason is I got in a crash last week, and it sheared off front & rear pax side brake lines. Personally, I'd prefer that didn't happen again, so we'll (hopefully not) see/test whether they help with that.
All we know is.... He's called The Stig |
#24 | ||
You should really flush all the fluid out if you're pulling the lines anyway. Swap lines, flush the whole system.Quote:
The difference in feel is less than the difference in feel between stock pads (more compressible) and good aftermarket pads, so if you just want a stiffer pedal you'll get more change from pads. I swap back to stock pads every winter, there's a very noticeable difference in pedal feel (and bite).
#25 | |
Rambling Man
That was just a possible side benefit anyway though All we know is.... He's called The Stig |
#26 | |
They are not going to do a single thing to prevent them from snapping when you crash either.
#27 |
Rambling Man
| The Following User Says Thank You to FNCrazy For This Useful Post: | Tcoat (07-29-2016) |
#28 |
On the bright side they will take forever to rust!
| The Following User Says Thank You to Tcoat For This Useful Post: | FNCrazy (07-29-2016) |
| WTB: stainless steel brake lines for SCION FRS (front & back) | dcfr | Canada Classifieds | 2 | 04-03-2013 08:49 AM |
| Dynosty Stainless Steel Brake Lines $99 Shipped | Dustin@Dynosty | Brakes, Suspension, Chassis | 9 | 12-29-2012 10:56 AM |
| Goodridge Stainless Steel Brake Lines | LavosTRD | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-29-2012 07:37 PM |
| Stoptech Front Stainless Steel Brake Lines | Pekingduck | Brakes, Suspension, Chassis | 1 | 10-21-2012 11:29 PM |
| Stainless steel brake lines | taosracer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 09-20-2012 05:09 AM |
