#197 |
Drives: Asphalt frs
That's definitely the tune these cars are know for idling issues once boosted have him talk to his tuner.
#198 |
Drives: 2013 Scion FR-S Firestorm Red
Thanks a million! I'll tell him to contact delicious and let you guys know how he faired
Sent from my SM-G935T using Tapatalk |
| The Following User Says Thank You to MooKz For This Useful Post: | SoCal80six (07-10-2016) |
#199 |
Drives: Asphalt frs
#200 |
Drives: Asphalt frs
#201 |
fastest frs in sbg
Drives: sick ass ultramarine frs
Side note, what kinda clutch is he running
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#202 |
Boosted
Drives: Not a supra....yet
Motor was built by a friend, stock compression forged rods and Pistons + valve springs only
#203 |
Boosted
None, I'm on completely stock everything than a clutch / flywheel !
#204 |
Drives: Asphalt frs
#205 |
fastest frs in sbg
What clutch and flywheel?
#206 |
fastest frs in sbg
So i was bored and i put my mishimoto fans in and map radiator support in. Well turns out the damn driver side fan is blowing instead of sucking. Damn mishimoto. Ud expect they would have better quality control for a $300 fan shroud
#207 | |
Drives: Asphalt frs
#208 |
Boosted
I tend to flat foot shift a lot, and I also had semi slicks for 5000 miles , full skinny/ slick setup atm and over 20 launches. It sometimes would lock me out now or would do stupid little things; nevertheless it has lasted all that. I'm not saying these trans aren't weak, but they aren't glass like people make them seem.
| The Following User Says Thank You to SmsAlSuwaidi For This Useful Post: | SoCal80six (07-05-2016) |
#209 |
fastest frs in sbg
Pre assembled but everything looks same as stock. Just doesn't function the same
#210 | |
Drives: 2013 Subaru BRZ
Mishimoto Fans
Thank you for the post. It sounds like the polarity is reversed on the fan. For a pusher you want the blue wire to be the ground and the black wire to be the power. Hope I was able to help. If that does not work, please contact us directly at Support@Mishimoto.com Best Regards, Jarret |
| The Following 2 Users Say Thank You to Mishimoto For This Useful Post: | MAPerformance (07-20-2016), MooKz (07-20-2016) |
| All TURBO kits compilation thread | subatoy | Forced Induction | 112 | 04-10-2015 10:14 PM |
| MAPerformance Turbo Kit Officially Released! | MAPerformance | Forced Induction | 633 | 07-26-2014 11:42 PM |
| AVO stage1 turbo kits now at MAPerformance! | MAPerformance | Forced Induction | 37 | 01-13-2014 10:53 AM |
| P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 07:27 PM |
