| Software Tuning Discuss all software tuning topics. |
Drives: 2017 CWP STi
Custom Tuning
How are custom tunes done?
I have a bud who's done these type of things and he's saying he can custom tune my BRZ without dyno'ing it, he said as long he can full throttle into 3rd gear, it's fine. T/F ? I was under the impression you needed to dyno it. What are the differences between a custom vs stage 1 ? |
#2 |
Drives: 2015 Firestorm Scion FRS
It's what I'm doing at the moment. I just call it street tuning instead. As long as you can find a decent quality flat road that is minimal to no traffic, no cops, and long enough that you can do a 3rd or 4th gear pull to redline-ish. Preferable an industrial area on the weekends when there's no one working and little to traffic or empty highway if you can find one at a suitable time.
A dyno is just a more safe, closed, and controlled environment for a price. Whereas on the street, road conditions may not be perfect (bumpy roads, sloped roads, temp variations, etc) so you are taking a bit more risk and it's less controlled. You may get busted by a cop during a pull, annoying locals can snitch on you if they think you're street racing, driving them crazy with a loud exhaust, or think you're acting dangerously on public roads. Or you get in an accident if you lose control or something unexpected happens. Stage 1 and stage 2 are more marketing terms IMO but typically an off-the-shelf tune suited for a stock car or a certain set of upgrades (intake and catback exhaust, headers). A custom tune is tailored to your car according to how your engine behaves and the aftermarket parts that you have. Since no engine performs the exact same way, variations in gas, and every aftermarket part performs different. I have the OFT stage 1 tune with a perrin air filter, trd catback and jdl uel catted headers so I'm refining the OTS tune so it's suited to my car specifically. |
#3 |
Okay, was just curious.
How much better is a custom tune verus a stage 1? I use 91 gas and an invidia n1 exhast, thats about it. How much extra hp/torque? @G-awesome |
#4 | |
#5 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
The difference is drive-ability
If I say yes, will that make you think I understand?
#6 |
Drives: UK GT86
You mean much like the OEM tune then....
.: Stealth 86 :.
#7 |
I would like to respectful disagree about street tuning..
"Street tuning" is usually setting up for WOT only, chassis dyno tuning usually involves a three dimensional tuning chart. Throttle position, RPM, and load: and needs a lot of time to get it right. That is why using a tune from a reputable source is often a better deal. Experience with this particular engine is also a great benefit and time saver. With eight injectors tuning for dally driving and spirited driving is a challenge. |
#8 | |
#9 |
Alright, I just stage 91 tuned my car.
After I tuned it , my check engine light was lit up on my dashboard. Whats the issue here and is it dangerous to drive around with it? I have to drive my car for a few hours straight tomorrow, dont wanna die. Secondly, I seem to have "knocking" when I break. As I come to a stop, the breaks knock back and forth. Dangerous? Whats the issue here and how can I get rid of this? |
#10 | |
Drives: FT86
If you have oft read the code if it says no codes it not engine code It likely a P0700 if your auto , oft may not cleat it if you want to clear it just diconnect battery and press brake pedal then reconnect battery, unless yo have obd scanner to clear codes. no idea what the knocking sound is |
#11 | |
Drives: FT86
however a good custom or dyno tune will be checked on street and track conditions as well you dont have to "street" tune at WOT and whatever ecu logging you can do on dyno you can do on street or track. often you find things you need to tweak while driving on the street and track as its hard to simulate those conditions on dyno. most tunes even canned or ots tunes are initially developed on dyno. If you developing a tune from scratch yep dyno is the way to go. If you already have a dyno developed OTS or canned tune thats done well and matches your modifications on a non boosted car then custom dyno tuning does not generally gain you much at all, and you would go pretty close just "street/track" tuning your good OTS/canned tune. |
| The Following User Says Thank You to steve99 For This Useful Post: | 86kahl (06-19-2016) |
#12 | |
As Im braking, I feel a small shift forward and backwards. Any idea what that could be? it feels like my brakes release for a split millisecond and then catch again @steve99 |
#13 | |
Drives: FT86
When you flash/reset ecu some learned parameters are cleared this may make the engine run a bit strange for the first couple of drive cycles. the "knock" sound is sometimes the ecu shutting off injectors on overunn ie coasting to a stop to save fuel, you sometimes get a bit of backlash is drive train creates a few weird sounds, usually more noticable with air-conditioner load or switching (ac runs with defrost function as well) Table below shows the rpm the institutors start fueling again on overun, when car warmed up this occurrs at about 1300-1400 rpm, if you get a rattle arround then comming to a stop that might be it Last edited by steve99; 06-19-2016 at 01:16 AM. |
#14 | |
I'm not too sure about this 'knocking' you feel in the brakes. Sounds like it's just the abs kicking in when you brake hard so the brakes won't lock up. |
| *** CMS TUNING l Stage1 l Stage2 l E85 l SC l Turbo l FlexFuel l Custom | Circuit Motorsports | Engine, Exhaust, Bolt-Ons | 581 | 04-12-2016 11:03 AM |
| Installs, Service, Maintanance, Repairs, Custom work, Tuning, Dyno Database! | Infamous Performance | Mechanical Maintenance and Tools | 521 | 10-30-2015 12:58 PM |
| Delicious Tuning is the way to go for a custom tune. | Canivideo | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 01-13-2015 04:47 PM |
| FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! | Diode Dynamics | Interior Parts (Incl. Lighting) | 155 | 11-19-2014 12:42 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 06:55 PM |
