Old 04-07-2016, 08:12 PM   #43
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Originally Posted by derek1ee View Post
So I did the install again yesterday, after checking rod to shaft clearance (I didn't have to modify anything and the clearance was fine with driveshaft labs aluminum shaft).
However I find the washer supplied by CAE can be easily slide on, as well as the shifter assembly itself. So maybe if you're experiencing too much resistance then it's putting more stress on the rod?
The pin pretty much had to be forced into the shifter, which I should have known was very wrong. I have a very early FR-S, bought before they were officially realeased... maybe they changed it, or maybe the CAE shifter I have was too tight compared to the others, as both the spacers and pins were extremely tight. The pin was definitely overstressed from basically being swage fitted into the shifter hole...though it felt like the shifter was rotating I doubt it ever rotated (especially from the ammount of force it took to go up and down the gears) and it finally failed from being torqued back and forth from shifting - totally my fault for not fitting it like I should have.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
GT86_PRAGUE (05-17-2016)
Old 04-17-2016, 12:14 AM   #44
Vracer111
Vracer111's Avatar
Well, just finished putting it back to stock...it's functional and shifts well. It's not bad and quicker shifting than the CAE Ultra shifter, but I miss the CAE... I'll take my time with getting the stock shift linkage that broke modified to properly fit the CAE Ultra shifter so there should be no failure again.
Anthony (04-17-2016)
Old 04-17-2016, 12:44 PM   #45
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
You can shift faster with the stock shifter than with the CAE?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 04-17-2016, 02:56 PM   #46
Vracer111
Vracer111's Avatar
YES...I think the linkage pin being effectively bonded/welded to the CAE shift lever had something to do with the CAE being slower to shift...stock is noticeably faster and WAY easier to shift than the CAE was, still sloppy - but better than I remember with much less issues going into 1st from a stop. Must be the Perrin solid engine mounts and transmission stiffener. I'm almost perfectly fine with the stock shifter now save for the slight slop and it being positioned so low....
The Following 2 Users Say Thank You to Vracer111 For This Useful Post:
Anthony (04-17-2016), raven1231 (06-06-2016)
Old 04-17-2016, 05:06 PM   #47
Anthony
Weight Nazi
Anthony's Avatar
Ah. Yeah, because I'm pretty sure I can shift a lot faster with the CAE, and that's comparing it to the Kartboy.
Old 04-25-2016, 03:25 PM   #48
derek1ee
Drives: BRZ/FRS/STI/M3
Doing more test fitting on my install, I noticed that the rod is rubbing the CAE underplate when in reverse, any of you guys seeing similar issue? If you look from the underneath, you can see the rub mark on the underplate if it is.
derek1ee is offline   Reply With Quote
Old 05-10-2016, 01:52 PM   #49
derek1ee
I figured this out, by moving the shifter assembly all the way back, there's no more rubbing.
I do have one more question:
Once you adjust the limiter screw so that it shift into 1st gear effortlessly, and when the shifter is in 1st gear, are there any gap between the limiter screw and the shifter? I'm seeing about 1mm gap. If I adjust the gap to be smaller, then it's harder to shift into gear.
Old 05-10-2016, 05:59 PM   #50
Vracer111
Vracer111's Avatar
Adjust the set-screws (there are 3) for best, smoothest shifting action for reverse, 1-2, and 5-6; don't worry about any resulting gaps. There needs to be a gap... once you have them set in place and everything is good then stake with RTV or epoxy them.
GT86_PRAGUE (06-03-2016)
Old 06-03-2016, 08:19 AM   #51
GT86_PRAGUE
Drives: GT86
Mine CAE arrived today :-D
GT86_PRAGUE is offline   Reply With Quote
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
Anthony (06-03-2016)
Old 06-06-2016, 01:36 PM   #52
GT86_PRAGUE
Drives: GT86
Cant shift into reverse. Any ideas?
Old 06-06-2016, 02:01 PM   #53
derek1ee
I think you may have the same problem like I did.
Basically, with the limiting screw screw out all the way, the selector rod is rubbing/hitting the shifter plate (the one with the rubber thing).
For me, if I move the shifter all the way back (holes are slotted), then I can shift into reverse with (I think) no rubbing.
But to be safe, I just took a dremel and grind down the selector rod to have more clearance.
The Following User Says Thank You to derek1ee For This Useful Post:
GT86_PRAGUE (06-06-2016)
Old 06-06-2016, 03:17 PM   #54
Anthony
Weight Nazi
Anthony's Avatar
Video?
Old 06-06-2016, 06:49 PM   #55
derek1ee
And this is where I had to grind down, grab the image on internet so not the same selector rod in BRZ, but should give you the idea.
The Following 2 Users Say Thank You to derek1ee For This Useful Post:
GT86_PRAGUE (06-08-2016), Hyper4mance2k (06-08-2016)
Old 06-07-2016, 01:47 AM   #56
GT86_PRAGUE
Drives: GT86
Video?
Nope, no video. Every gear works fine, except the reverse.
My mech will move the CAE a bit back today, fingers crossed...
cae ultra shifter
Perrin Rear Shifter Bushing Install F1point4 DIY (Do-It-Yourself) Guides 55 10-21-2021 02:39 PM
Shifter wobble after Kartboy install ? Simon99 Engine, Exhaust, Transmission 5 04-13-2015 12:06 AM
Shifter rattles after CF driveshaft install? Venz1028 Engine, Exhaust, Transmission 5 03-28-2015 02:43 AM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Shifter bushing install Bullnettles Engine, Exhaust, Transmission 4 06-20-2013 04:36 PM
