03-25-2016, 08:39 PM | #3795 | |
They should respond this week I guess they are busy with something @KraftWerks
03-27-2016, 09:39 PM | #3796 |
Drives: frs
folks, anyone is running c38 kit on Kraftwerks tune?
03-28-2016, 08:53 AM | #3797 |
Drives: WRB Brz
Got mine installed and running!
Ran into a few more issues, only had a single hose piece for the oil and was missing the U bracket and spacer for the reservoir tank. I had to look at pics of used kits to find that out. Single hose was only long enough to reach to the back once. Had to place the tank up front using the intake brackets off of the supercharger/pulley mount. Also had to dremel one of the maf sensor hex screws into a flathead as it was on too tight. All in all, the kit is well designed and I appreciate not having to cut into anything. A good tip for priming the supercharger. Don't completely mount the tank, if you lift up high enough initially gravity will push the oil to the inlet of the SC instead. Finish the mounting once it you see a slight leak from inlet. This made the priming only take a few "dead" starts to start leaking through the outlet. Again, when lifting make sure you have enough in there to not run out and have an air pocket. A couple of questions: 1) Does anyone have proper steps or video on how to use the gates app? My belt was super loose at 21mm, adjusted down to 17mm right now and I still hear a vibration when starting from a stop (~1.5k). I'm afraid to over tighten. This would probably be helpful to the whole kraftwerks community. 2) With the BOV re-circulated. Should I be hearing it? I guess the question is more of, I don't hear mine at all which has me worried pressure is staying in the system. I May disconnect it to the atmosphere to see if I can hear it working. For now, i'm babying it during break-in but, i can feel a difference already. |
The Following User Says Thank You to CaptivaBlueTeg For This Useful Post: | Rulin (03-28-2016) |
03-28-2016, 09:54 AM | #3798 |
Drives: frs
@CaptivaBlueTeg
1. here's how i did it: http://www.ft86club.com/forums/showp...postcount=3381 after a month or few once your belt breaks re-check your tension 2. it's recirculating, so generally - no. You can here some chattering though after you go wot and then release gas pedal |
The Following 2 Users Say Thank You to vgi For This Useful Post: | CaptivaBlueTeg (03-28-2016), Rulin (03-28-2016) |
03-28-2016, 06:27 PM | #3799 | |
WRX -> BRZ. (TX)
Drives: 2015 Series.Blue WRB
I have the aem failsafe, just been sitting on a shelf for 6 months though... Sent from my Nexus 6 using Tapatalk
KraftWerks c3094 SC Kit ARK GRiP w/ test pipe KW V3 OEM Audio + Reference 400CF |
03-28-2016, 07:03 PM | #3800 |
Drives: 2013 Ultramarine FR-S
03-28-2016, 08:17 PM | #3801 | |
Drives: 2014 Monogram FR-S Whiteout
I think the car can only detect when it has no oil pressure at which point it is too late. It was my understanding oil pressure is the only sensor the car didn't have and is why most people run an analog gauge for it. |
The Following User Says Thank You to Bykov For This Useful Post: | Freeman (03-28-2016) |
03-28-2016, 08:43 PM | #3802 |
Drives: Raven FR-S 6M
I think I will be going with oil pressure and temp only
“The World is Flat”
[||•]=(86)=[•||] |
03-29-2016, 09:57 PM | #3803 | |
Drives: 14 BRZ Crystal Black Silica Limited
Sent from my SM-G920V using Tapatalk |
03-29-2016, 10:02 PM | #3804 |
Drives: WRB Brz
Update on my belt adjusting:
Only time will tell if it's correct. I was definitely loose even at 19mm, the app would not register. Once I got it tensioned up the app was giving me a consistent readings within 3hz of each other. With that said i'm getting 58-60hz constant and not hearing the vibrations at the lower rpms like before. This brought me closer to 17mm range. |
03-29-2016, 10:12 PM | #3805 | |
03-29-2016, 10:32 PM | #3806 | |
04-04-2016, 12:45 PM | #3807 |
Drives: Whiteout FR-S, Evo 8 RS
Hey guys. Don't know if anyone had an issue with a broken bracket before, but they will break if they are mishandled or over tightened.
04-04-2016, 01:30 PM | #3808 |
Drives: frs
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
