#15 | |
Drives: Man
| The Following User Says Thank You to slyphen For This Useful Post: | Ultramaroon (12-15-2015) |
#16 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I have a 2015 Series.Rattle with the same issue. Mine doesn't make any noise until above 4-5k RPM. It's been there since I bought the car. Hasn't gotten any worse, or any better. Never got around to pulling the shifter trim off and poking around, but this thread makes me think it won't be as simple as finding a loose screw or something.
#17 | |
Drives: Man
#18 |
Drives: 2014 WRB BRZ Limited
In to see if we can figure out what's rattling. My car did this stock, after installing trd quickshifter, after removing the TRD quick shifter, and now with a kartboy. It's noticeably louder with the kartboy than it was on stock shifter, but happens under same conditions (high rpm, any gear). Going to do some testing after the holidays with the center console out and everything apart to see if I can isolate the noise.
#19 | |
Drives: Man
Sent from my SM-G920V using Tapatalk |
| The Following User Says Thank You to slyphen For This Useful Post: | xxBrun0xx (12-22-2015) |
#20 |
Drives: 2015 BRZ
I've tried nearly everything as well. So I'll chronicle my experiences and perhaps it may help others.
1. 2015 shifter starts immediately ( didn't notice because kept it under 4000 RPM during the break in ). 2. Added TRD Quick Shifter, still rattles but less. 3. Forum search indicated the reverse lockout may possibly be the cause. Purchased Raceseng reverse lockout and installed. Still rattles. 4. Forum search also indicates the reverse lockout internal spring and bushing between the lever and reverse lockout may be the cause. I grease the hell out of them and with the Raceseng reverse lockout, there's no play between the bushings and shift lever. Still rattles. 5. Frustrated and consumed with OCD to eliminate the rattle, I try a Kartboy shifter. Rattles even more. 6. When I removed the stock shifter, I noticed how solid it is. If you try to shake it or tap it, there's no rattles and nothing is loose. I'm a bit confused on what could be causing the rattle, but I notice at the very bottom of the shift lever, where the lever attaches to the transmission arm with a pin, there's two solid nylon bushings and a rubber o-ring sandwiched between the two. The o-ring appears to be worn out. 7. Suspecting the o-ring and bushings, I purchase a used shift lever. When it arrives it appears to be in good shape and the o-ring and bushing look okay. Installed and no rattle! Also I've left the Kartboy rear bushing in since I liked how it removed some slop during shifting. Removed the TRD quick shifter since didn't notice a huge difference and it worked its way loose even with blue loctite. 8. Unfortunately ~100 or so miles in I'm developing a rattle at 6000+, which I could live with since my old shifter would rattle at 4000+, which is a range I'm always in. 9. OCD still in full force and out of curiosity I purchase a new set of nylon bushings and a o-ring and install it into my original shift lever, also as a test to determine the root cause of the rattle. I also grease everything heavily, to my amazement no rattle at any RPM. It's only been about 500 miles, so I'm still crossing my fingers. Also, I've recently installed a Whiteline Positive Shift Kit and still rattle free. Current setup: Kartboy Shifter Bushing Whiteline Positive Shift Kit Raceseng Reverse Lockout Raceseng Spherology Shift Knob TL;DR - Try changing out the nylon bushings and rubber o-ring at the base of the shift lever and grease everything thoroughly. While I have the modifications listed above, I don't believe they prevent the shift lever from rattling, though I could definitely be wrong. My curiosity is satisfied, so enough experimenting for me! Last edited by Lord09; 12-15-2015 at 02:36 PM. |
| The Following 4 Users Say Thank You to Lord09 For This Useful Post: |
#21 | |
Drives: Man
#22 |
Drives: Man
just got the car back and drove around. rattle has been significantly suppressed. Although you can still tell the reminiscence of the rattle, it is more dampen and less noticeable. I can actually enjoy hearing the engine rev without being annoyed to hell by the shifter now.
Below are logs provided by subaru. 317611 gear shift rod &/or bushing R&R 1 - 35025CA000 Collar 1 - 35035CA020 Bushing O Ring 1 - 35016CA020 Boot Dust "Verified customers concern, there was a vibration coming from the shifter assembly above 4000 rpms. removed the center console, shifter assembly. installed a new o-ring in-between the lower shifter bushings and reassembled. test drove vehicle and no more rattle was heard." |
#23 | |
Inactive
Drives: .
| The Following User Says Thank You to _gt86_user For This Useful Post: | slyphen (01-07-2016) |
#24 |
A.K.A. Starlord
Follow-up question: How hard would this be to do myself?
#25 |
Drives: 2015 BRZ
You have to jack up the car and take apart the center console. If you've never worked on cars before, I think this would be very challenging.
If you have experience, it's very straightforward. Just be careful removing the lower shifter boot, it's very very fragile. |
#26 |
Inactive
Drives: .
#27 |
Drives: Man
Tbh, it still rattles, just not as much. I'm gonna take your advice and see if they can put in a 2nd o-ring.
#28 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Hmm.. not sure if I have this issue on mine, or if what im about to describe is similar.
But my shifter definitely vibrates quite a bit. I have a weighted shift knob on it now so it doesnt actually rattle enough to make noise. But I remember when I first swapped my reverse lockout (to an aluminum one), I didn't hit the pin back in enough and even that rattled loose. The lockout was also a noisy mofo as it rattled. With that pin in tight and the weighted knob screwed down real well, I haven't had any noticeable noise from the shifter. I still feel plenty of vibrations through it when I hold on to it though, but I figured thats normal since it is connected to the engine... |
| Audible shifter rattle | Hanzo | Issues | Warranty | Recalls / TSB | 134 | 08-17-2022 03:34 AM |
| How much shifter play is normal? | radroach | Engine, Exhaust, Transmission | 16 | 08-02-2017 11:25 PM |
| Shifter rattle WOT over 4500rpm | Khorne | Issues | Warranty | Recalls / TSB | 25 | 10-19-2015 11:49 PM |
| rattle from shifter at 5k.+ rpm | MurderRider | Issues | Warranty | Recalls / TSB | 11 | 02-01-2015 06:02 AM |
| BRZ Shifter Rattle TSB | sc0urge | BRZ First-Gen (2012+) — General Topics | 2 | 08-26-2013 09:53 PM |
