#57 |
http://www.carjoying.com/quad-core-a...vr-steeri.html
on the website above it states; "Bulit-in WiFi, Support 3G/4G/Wifi hotspot sharing" so do i get free data to this radio? Last edited by dill916; 12-14-2015 at 09:38 PM. |
#58 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
You need some form of internet connectivity, whether it's tether through your phone or a mobile hotspot. Actually you don't need internet, unless you want to do things that need internet
Sent from my XT1096 using Tapatalk |
#59 |
ah so I could just connect via bluetooth and run off my phones data as the stock radio does. Great! I am a big android fan. Not many radios like to recognize my Oneplus One phone via USB cable and the Bluetooth in my car is random when it decides to connect so i think i will be purchasing this in the future. Much appreciated!
#60 |
Bringing Hachiroku Back
Drives: 2013 Firestorm FR-S
So this is where the mic connects and this is the mic it came with. Where do you guys suggest I should put it? Tia!
![]() Sent from my SM-N920P using Tapatalk
#61 |
Drives: FRS RS 1.0
I suppose this location would give you the best results?
Although it looks soo weird sticking out the dash console like that. Is there noway to reuse the oem mic? Last edited by shadoken; 12-15-2015 at 10:02 PM. |
| The Following User Says Thank You to shadoken For This Useful Post: | eurominican (12-16-2015) |
#62 | |
It's been said in this thread you would have to solder to be able to use stock mic unfortunately. Sent from my SM-N920P using Tapatalk
#63 |
So where do you put the antenna wire?
![]() The diagram/instructions say to wire it to blue cable but that's the pin everyone says to move from pin 8 to 9 (or viceversa) to make the stock amp work for the door speakers so tap that wire for the stock antenna power? EDIT: I tapped the blue wire and it works fine. Sent from my SM-N920P using Tapatalk
#64 |
I believe I connected the antenna booster wire to the amp remote turn on wire, usually it's blue
#65 | |
Thanks!
#66 |
So there's no use for this plug? The harness that came with the HU does not match
![]() Also, I got this adapter for the stock usb port and it does not fit... and there are a bunch of people in the amazon product page saying that it does. Smh.... Metra AX-TOYUSB-2 2010-Up Toyota USB Adaptor https://www.amazon.com/dp/B00EAYYQDO ![]() Bunch of liars!!! (Unless I'm missing something) ![]() Sent from my SM-N920P using Tapatalk
#67 |
Drives: FRS RS 1.0
Lol those reviews ... Looks like the seller listed the wrong item.
#68 |
Edit: Links fixed
Here are the exact parts I bought to connect my radio to my car. Copied directly from my amazon order history. These all fit and work: [ame="http://www.amazon.com/gp/product/B00BXF5A74?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s01"]Axxess AX-TOY28SWC Steering Wheel Controller Add-On Harness with RCA and 28-Pin Connector for Toyota Vehicles [/ame] [ame="http://www.amazon.com/gp/product/B003VYWSES?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s01"]Metra 40-LX11 Lexus Antenna Adaptor Cable 2002-Up[/ame] [ame="http://www.amazon.com/gp/product/B00EAYYQDO?psc=1&redirect=true&ref_=oh_aui_detailp age_o02_s00"]Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles [/ame] Last edited by B-R-Z; 01-30-2016 at 01:22 PM. |
| The Following 3 Users Say Thank You to B-R-Z For This Useful Post: |
#69 | |
Sidenote - amazon is amazing, they refunded the charge for the wrong usb adapter, didn't ask for it back ![]() Sent from my SM-N920P using Tapatalk
#70 |
This post might be helpful. It does specify that you need AX-TOYUSB not AX-TOYUSB2 like you purchased.
http://www.ft86club.com/forums/showp...postcount=1645 |
| Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 01:41 AM |
| Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. | junglizste | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-08-2015 12:55 PM |
| Ca-Fi Dashlinq4 Android head unit universal Toyota | phanguy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-19-2014 12:57 PM |
| FS: T7019A Android Head Unit | pheoxs | Audio/Visual, Electronics, Infotainment, NAV | 4 | 08-26-2013 06:05 PM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 03:42 AM |
