#15 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I know I will get even wear when I run -2.5 or w/e I end up running next spring as on stock alignments I replace my tires every 20k due to wear hahaha!
| The Following User Says Thank You to go_a_way1 For This Useful Post: | LenA (12-09-2015) |
#16 |
Drives: FR-S Whiteout
You could have flipped the tires after a couple of events or some mileage to try to maximize your tire life. Though, unless you granny your car everywhere, stock alignment (-0~-0.5* front camber) is not very easy on the outside edge of the front tires. -2.0~2.5 front is good compromise, I think.
Intent > Content
cowardice is the mother of cruelty. |
#17 | |
Not Bаnned Anymore
I plan on running -2.5 front and -1.5 rear when I install my coils and LCA's this spring with 0 toe all around. You think thats a good starting point? |
#18 | |
Intent > Content
#19 |
Drives: '13 FRS - STX
![]() I only have a few dozen miles on them, initially it seems to soak up the little road imperfections better than OEM but it seems to bounce on big displacements like speed bumps. I'll be autocrossing it next weekend and able to put some real miles on it over the next three weeks which is why I haven't posted anything about it. Seems like a great quality bang for your buck lowering (I winged the collar heights and I ended up 1" lower than stock, might be able to get some height), comfort is very similar to OEM and the stiffer springs are apparent but not harsh even with the light driving I've done. I think that drive cycle is extremely important, I drove a few hundred miles on the freeway with -3 degrees and feel like it took a noticeable amount off the inner shoulder, but they wear evenly on track at that alignment. I've been adjusting camber before and after events, seems to have almost no effect on toe. Someone who's car sees 90% hard driving will wear pretty well with -3 degrees, 90% DD will roast those tires compared to a more conservative alignment. |
#20 | ||
To the OP, the biggest change you'll notice is that with less rear toe the car will be slightly less stable in a straight line. It's not going to want to spin, but it will follow contours of the road a bit more. Not scary, just something to be aware of.
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
#21 | |
I wanna go fast
Drives: 2013 FR-S 6MT
| The Following User Says Thank You to 2much For This Useful Post: | LenA (12-09-2015) |
#22 |
Drives: 2015 Silver BRZ
Thanks for the feedback. I'll see what West End recommends. I'm an engineer, so even if I don't go with camber bolts etc, I'd like to get a baseline and see where things are relative to the broad factory ranges and go from there. Most of my driving is DD, so I really only want to do mods that improve DD with some occasional HPDE in near future
Len |
#23 | |
Intent > Content
#24 |
Dismember
Drives: 2013 Red Scion FR-S
I'd just zero the toe and get crash bolts for the front. Excellent compromise. Cheap too. Don't overthink it. Also, a local speedshop may or may not know the platform well. Roger Krause Racing near my home does tons of racing and suspension work. They literally said to go online and find out what works then come to them to get it done.
#25 |
@LenA good deal. Ideally for this car, you want more camber in the front than the rear. About .5 or so. Good luck.
| The Following User Says Thank You to swarb For This Useful Post: | wparsons (12-09-2015) |
#26 |
Drives: Scion FR-S
Hey guys just recently got an alignment and was curious about something.
my front camber left is 1.5 and the right is 1.8 does should i be concern about .3 difference? |
#27 |
Drives: '23 BRZ
#28 | |
Huge E85 fan!
Drives: 2016 Scion FRS
I haven't tried those settings, but that's close to what I set my last car to. The car will seek out the camber of the road and want to wander on the highway. There will be more tire wear up front. But the car will feel so much better in every corner. |
| How does AC impact power? | scionfrs2014 | Scion FR-S / Toyota 86 GT86 General Forum | 48 | 05-13-2019 06:58 PM |
| Recommendation for Cordless Impact Wrench? | iLaw | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 04-27-2017 11:51 PM |
| Way too loud. Best fix for minimal impact? | transition | Engine, Exhaust, Transmission | 55 | 07-24-2014 12:02 PM |
| Air temps and impact on engine load | brn12345 | Software Tuning | 0 | 04-30-2014 03:50 PM |
| shop in west Houston for performance wheel alignment | hankster | Southwest | 0 | 08-21-2012 07:08 PM |
