Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
Drives: 2013 Subaru BRZ
Transmission Oil Leak?
Noticed oil leak on the top & driver side of the transmission. Any thought of what this issue could be.
I checked ground and no oil, I'm assuming the bottom plate cover caught it, if anything. I don't smell anything burning/oil smell when driving. The only thing I noticed is, after driving awhile (1 hour or so), I notice the gear shifter area/center console becomes quite warm. I assume that's normal nature of heat coming from transmission. ![]() |
#2 | |
(I can't tell from the picture) Usually, transmissions don't leak out of the top. Maybe something else is leaking on it .. ?? humfrz |
#3 | |
My friend asked if I didn't tighten the fill hole of the tranny, but I haven't done a single tranny oil change, so that makes it a bit puzzling. There isn't anything on top of the tranny. Unless I am wrong? Thanks |
#4 |
hmmm....... you might check those heater hoses, where they go into the firewall, for leaks. A leak from them could be following the firewall down and dripping onto the top of the transmission.. ??
I suggest you reach back and get a sample of the dark stuff and see if it feels and smells like oil. Maybe clean off the top of the transmission with something like brake cleaner and see if the "stain" returns. OR, wait until someone who knows what they are talking about, to come along and chime in ...... ![]() humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (09-14-2015) |
#5 |
chicken tonight
Can you take a couple more photos from different angles?
#6 |
Drives: white-out FR-S
I would have to agree with ultramoon. Need better angles. I don't see red fluid.
Sent from my Nexus 5 using Tapatalk |
#7 | |
I stuck my hand in and it's definitely oil. Just don't know where it's coming out. There's this black rod on the top, I notice it's got oil around it, but no idea what it does. |
#8 |
Drives: Scion FR-S
Hmm I have noticed the same thing going on with my FRS automatic as well did you find the solution??
#9 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
That is the transmission pressure breather (relief) hose... It's "normal" for some oil residue (oil condensation) to build up around that area... However... if you are noticing alot... enough to cause; say, a drip, that's not normal.
This is only for the AT FR-S/BRZ.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#10 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
I saw the same thing last week when I did my Trans Fluid change. Noticed it first on the drivers side, toward the rear and followed it up to what appeared to be a breather. Pic is from the top looking down. Like @DaJo says, probably normal.
The Following User Says Thank You to BirdTRD For This Useful Post: | Ultramaroon (10-06-2016) |
#11 |
Drives: 2013 FRS 10 series
Mine has the same issue. Have you got it looked at since this was posted? I have almost 30k miles on my 2013 frs auto and the whole top of the transmission seems to resemble your "leak". Most of the grime was built up around the back of that hose that DaJo mentioned. Its just dark, gritty grime. I was noticing a faint buring smell on WOT and a few regular drives that caused me to pop the hood and look around. Everything else looks bone dry. I plan on dropping the bottem cover and seeing if there is any fluid down there, but from what I have seen it looks dry. The top of the transmission is the only part that looks grimey. Could this residue be causing the burning smell?
#12 |
Drives: '13 Ultramarine
Pretty sure DaJo nailed it...
Gas Leak? | Fuco | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 26 | 10-07-2022 09:40 AM |
Help - oil leak | tlim | Engine, Exhaust, Transmission | 4 | 04-10-2015 08:40 AM |
Oil leak. | ohnoitsthefuzz | Issues | Warranty | Recalls / TSB | 2 | 03-23-2015 01:31 AM |
A/T Pan leak | goke186 | Issues | Warranty | Recalls / TSB | 0 | 04-15-2013 10:31 PM |
topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) -- General Topics | 51 | 05-04-2012 07:54 PM |
