Old 07-09-2015, 11:23 AM   #379
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by Rybot View Post
While BB turbos don't need as much cooling due to less contact friction at the same RPM, air cooling is a fickle design.
For an air cooled design, ducting would be necessary for proper cooling. Most things air cooled need to have things designed around them to be effective rather than throwing in water cooling and not having to worry about air flow in the engine bay.
This is what i figured, maybe this would work in the case of those high powered drag cars where the turbos are right in front of the radiator or protruding the hoods, even still when you come to a stop.. the same thing would happen as with a regular JB oil cooled only center section.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 07-09-2015, 12:03 PM   #380
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
We have had nothing but good results with PTEs BB turbos. I personally will be running one on my project car. I like the simplicity of only having only oil feed and return. The GT/GTX units get really cramped fast with all 4 lines.
JDLAutoDesign is offline   Reply With Quote
Old 07-09-2015, 12:29 PM   #381
JDLAutoDesign
Drives: 13 FRS
We have a loca BRZ in today so we will have come up with something for the oil cooler
The Following 3 Users Say Thank You to JDLAutoDesign For This Useful Post:
Alltezza (07-09-2015), Rybot (07-09-2015), xxscaxx (07-09-2015)
Old 07-09-2015, 12:30 PM   #382
xxscaxx
Drives: 2013 SWP BRZ
+1. Getting those coolant lines in place so they don't touch either the hotside or compressor housing can be a tedious affair depending on how you route the coolant lines. Though it seems that I had more trouble with my 30r on my STi than this 28. Not sure if theres more room or just maybe the setup, since nothing was v band on the 30r. Sure is nice not having to try to get things bolted down while clocking the turbo, making sure the bolts holding the compressor on aren't interfering with the oil drain, then trying to tighten it all...that was such a pain.
xxscaxx is offline   Reply With Quote
Old 07-09-2015, 12:49 PM   #383
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
*Fingers crossed*
Hope you guys can find a way to get the cooler mounted! I'll be needing one.
Rybot is offline   Reply With Quote
Old 07-09-2015, 12:50 PM   #384
Rybot
Rybot's Avatar
Yeah, I'm not looking forward to coolant line routing, but it'll be necessary.
Old 07-09-2015, 01:06 PM   #385
xxscaxx
Its really not bad at all. I am just a stickler and hate lines everywhere. This engine makes me want to scream. I want my tucked EJ25 motor back...lol (that motor wasn't any better honestly).
If I don't end up swapping this engine out in the future I will definitely end up tucking it like @Jesse@JDLAutodesign did. I'd have done it already if @Chase Bays would ever release their tucked engine harness
Old 07-09-2015, 01:18 PM   #386
Rybot
Rybot's Avatar
How long does a tuck take? I'm guessing a whole week.
Old 07-09-2015, 01:21 PM   #387
xxscaxx
It depends on if you have to extend wires. On my STi, it was apart for quite some time...I relocated the ABS unit (which required removing all the hard lines from the bay and rebending them/rerouting them) which took the most time. I didn't do a full "complete" tuck but you couldn't see most of the wiring in my bay and fortunately the Fuse box could be relocated without extending wires. The only wire I had to extend was my alternator. Jesse posted a picture up of his wire tuck (http://www.ft86club.com/forums/showp...5&postcount=88), you will see how extensive it was. Its a reason why I want to buy an already made harness
Old 07-09-2015, 01:27 PM   #388
Lee@JDLAutoDesign
Lee@JDLAutoDesign's Avatar
Drives: Corrado
I don't even want to think about how much time I spent just removing the tape and plastic sleeving from the original harness.
Lee@JDLAutoDesign is offline   Reply With Quote
Old 07-09-2015, 01:28 PM   #389
xxscaxx
Old 07-09-2015, 01:31 PM   #390
Rybot
Rybot's Avatar
A pre made harness would be crazy expensive though, right? All that copper and those connectors.
Old 07-09-2015, 01:33 PM   #391
Rybot
Rybot's Avatar
Welp, not doing that then. If it's a crazy amount of time just for that, I'll pass.
Old 07-09-2015, 07:02 PM   #392
JDLAutoDesign
Drives: 13 FRS
These brackets will include air guides
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
Rybot (07-10-2015)
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 08:03 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
