Old 03-19-2015, 10:49 AM   #1471
TallTerror13
TallTerror13's Avatar
Drives: 2014 DGM BRZ & 2015 WRB WRX
Anyone have experience with superpro bushings?
Do you think this one is legal? Too much metal? http://www.superpro.com.au/superpro-...999501126&vid=
TallTerror13 is offline   Reply With Quote
Old 03-19-2015, 01:01 PM   #1472
Kostamojen
Superpro bushings are good, used them before on my previous car for years.
The Following User Says Thank You to Kostamojen For This Useful Post:
TallTerror13 (03-19-2015)
Old 03-19-2015, 03:25 PM   #1473
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Aussy made as well.. direct competitor to Whiteline. no complaints had them on my impreza back when. maybe a bit stiffer than whiteline.. they had 2 hardness's purple and Yellow IIRC... they tend to have a more complete kit over Whiteline, where Whiteline has more individual applications. meh... 1/2 dozen on one, 6 in the other..
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
Old 03-19-2015, 05:49 PM   #1474
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I was feeling body roll when racing last year. Is there a reason not to do them at the same time? I will hold off if so. The car is stock, I will be putting on enkei rpf1's 17x9 +35 with 255 z2 star specs.
Will camber bolts adjust far enough to make the -2.5 or -2?
You can't get -2° in the front with just bolts. 1.1-1.5 ish depending on car.
Mad_Mike is offline   Reply With Quote
The Following User Says Thank You to Mad_Mike For This Useful Post:
Scooby South (03-19-2015)
Old 03-19-2015, 06:44 PM   #1475
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
While camber plates are the easiest option, I can get -2.5 with camber bolts. I run SPC bolts in the lower hole and the used the lower hole "Crash bolts" in the upper hole for more adjustment. I only put one autox on this setup but multiple canyon runs on rough roads and haven't had slipping yet.
I am lowered an inch btw
Old 03-19-2015, 07:15 PM   #1476
Scooby South
Conedancer
What size wheel/tire??
with stock struts and -2.5 there is potential for rubbing on the inner strut with more than a 42 offset.. 17x9 42 is about as big as you can go.. and thats only with about 1.4 neg.. At that point you only have about a 5-7mm gap between the strut and the wheel/tire.
Bill
Old 03-19-2015, 07:31 PM   #1477
finch1750
finch1750's Avatar
Bill
Im on stock wheels with a 225 right now. No idea what the other guys set-up is but just saying it is possible to get that much with bolts. It's only my 2nd year autox so my car is minimally prepped while I focus money on events vs mods.
I plan to run a 17x9 with a +35-38 offset using slip on spacers in the end (RCE Yellows with Koni struts. I'm just aiming to be locally competative right now. May jump to coils eventually)
Old 03-19-2015, 10:46 PM   #1478
cactus
cactus's Avatar
Drives: 13 SWP BRZ
Are the raceseng cascam plates worth the money, or what are you guys running?
I am running them now, was going to do Voshlags, but they where OOS. Racesengs give a little more bump travel then the Voshlags, way more than the com-cs I was using.
cactus is offline   Reply With Quote
Old 04-03-2015, 07:27 PM   #1479
BE4VER
( ͡° ͜ʖ ͡°)
BE4VER's Avatar
Drives: 14FR-S
I took a look at the 2015 scca rulebook and see the STI and release series scion are classed into B street. Looking over the STX portion I see there is no mention of those cars in STX. All I see is a general listing for all FR-S/BRZ 12-15. Does that mean those cars are STX legal or are they just not classes in ST yet? If those cars are classed into STX can the base version cars use their front lip and side skirts and spoilers in STX?
Also was there any new discussion on Oil coolers being allowed anytime soon? Checked the recent fast tracks and saw no mention but thought I read that was being brought up.
“Has Anyone Really Been Far Even as Decided to Use Even Go Want to do Look More Like?”
BE4VER is offline   Reply With Quote
Old 04-03-2015, 07:46 PM   #1480
conedodging
conedodging's Avatar
Drives: '14 BRZ
Oil coolers are in the rulebook for ST (see 14.10.A).
conedodging is offline   Reply With Quote
The Following User Says Thank You to conedodging For This Useful Post:
BE4VER (04-03-2015)
Old 04-03-2015, 07:53 PM   #1481
BE4VER
( ͡° ͜ʖ ͡°)
BE4VER's Avatar
Drives: 14FR-S
Sweet so that went through. Awesome.
Old 04-03-2015, 10:49 PM   #1482
Scooby South
Conedancer
Yes.. front lip/sideskirts can be used since its a factory accessory..
Mine for reference...
The Following 2 Users Say Thank You to Scooby South For This Useful Post:
BE4VER (04-03-2015), fstlane (04-03-2015)
Old 04-03-2015, 11:08 PM   #1483
Kostamojen
Doesn't include the replica lips, correct?
Old 04-03-2015, 11:24 PM   #1484
Scooby South
Conedancer
Actually they do. Rule says a suitable Replica is allowed as long as its the same dimensions as stock.
14.2 BODYWORK.
F. Addition of spoilers, splitters, rear wings,bumper covers, valances, side skirts, and non-functional sccops/vents is allowed provided that either:
1. It is a production part which is standard or optional equipment of a US model of the vehicle. (“Model” is defined in Section 12.3.)
2. It is listed in the vehicle manufacturer’s US accessory catalog for that vehicle for normal highway use. This does not allow for parts sold through a manufacturer’s performance catalog (e.g., Ford Racing, HPD, Mazdaspeed, Mopar Performance, Mugen, NISMO, SPT, TRD, etc).
Parts must be installed as directed by the manufacturer. Exact replicas,including weight, from alternate sources are also permitted.
they aren't SPT.. but part of the Accessory catalog for the BRZ ... Bolded the main part.. since they were offered on the "Blue"
Bill
Kostamojen (04-03-2015)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
