Old 02-13-2015, 02:04 AM   #1
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
what lugs nuts you guys are running?
I completed my first track event the other weekend, and my lug nuts were completely falling apart when taking them off. They were NRG Lugs, but damn.. didn't expect it to be so bad. Makes me wary of aluminum lugs now. I was wanting opinions on OPEN ENDED lugs for track use. I have extended studs so open ended is a must.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 02-13-2015, 02:45 AM   #2
CSG David
CSG David's Avatar
NRG uses really crappy materials. If material and finish QC aren't done correctly, bad things can happen. At this point, you are better off running chromoly lug nuts.
The Following User Says Thank You to CSG David For This Useful Post:
enjoi23 (02-13-2015)
Old 02-13-2015, 04:07 AM   #3
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
I use CSG aluminum lug nuts for 30+ track events so far. Highly recommended.
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
Old 02-13-2015, 04:31 AM   #4
Doozer
Doozer's Avatar
Drives: gt86...among others
WedSport steels on ARP studs. Ran alloys at first but kept stripping them at the track because of improper over torque
racing gods live deep in corners
Doozer is offline   Reply With Quote
The Following User Says Thank You to Doozer For This Useful Post:
MTCRX (11-11-2015)
Old 02-13-2015, 11:40 AM   #5
CSG David
CSG David's Avatar
Chromoly you can be an idiot on torque settings. Aluminum is a little more ductile so torque settings must be careful. When using anti-seize, we back off on the torque settings by 5 to 10 ft-lbs. The resulting torque is about ~75ft-lbs. This has worked very well.
The Following 4 Users Say Thank You to CSG David For This Useful Post:
Doozer (02-14-2015), jbailey8748 (11-16-2015), MINOCIN (02-13-2015), MTCRX (11-11-2015)
Old 02-13-2015, 12:03 PM   #6
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Muteki SR48's.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 02-13-2015, 12:19 PM   #7
DarkSunrise
DarkSunrise's Avatar
Cheap Gorilla steel lugs.
[ame="http://www.amazon.com/Gorilla-Automotive-21123BC-Diameter-Thread/dp/B001O08ADO"]Amazon.com: Gorilla Automotive 21123BC Small Diameter Acorn Black 5 Lug Kit (12mm x 1.25 Thread Size) - Pack of 20: Automotive[/ame]
Not fancy, but no complaints.
2022 BRZ Build
2013 FR-S Build
Old 02-13-2015, 01:24 PM   #8
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Muteki sr35
-Jack Burton
Old 02-13-2015, 04:43 PM   #9
ayau
Drives: Some rust bucket
Cheap Gorilla open end lug nuts. They're steel but still pretty lightweight. I don't like the Mutekis because they're heavy.
[ame="http://www.amazon.com/gp/product/B002803VPQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1"]Amazon.com: Gorilla Automotive 30027B Acorn Open End Bulge Lug Nuts (12mm x 1.25 Thread Size): Automotive[/ame]
Old 02-13-2015, 07:19 PM   #10
FRSKEV
Drives: FRS
Im using McGard lugs nuts, seem to be working fine for me. Changed my wheels probably 20 times last summer with no problems. 10+ autox events and 1 track day.
2013 Scion FR-S
Autox - Track
Paint Protection Film Pro
FRSKEV is offline   Reply With Quote
Old 02-13-2015, 11:08 PM   #11
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Do the CSG Lug nuts work with rpf1's to use it on track?
ExxelDistributions is offline   Reply With Quote
Old 02-13-2015, 11:41 PM   #12
1ofaKind
bRz
1ofaKind's Avatar
Drives: Subaru Brz
Amuse Titan lugnuts, best lugs and lightest lug nuts on the market.
Touge Monster
1ofaKind is offline   Reply With Quote
The Following User Says Thank You to 1ofaKind For This Useful Post:
Icanfaptothis86 (08-06-2015)
Old 02-14-2015, 12:06 AM   #13
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Evasive Super Lug Nuts / CSG Aluminium Lug Nuts
Build Thread
Instagram
Old 02-14-2015, 12:57 AM   #14
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Muteki 31885
Decay107 is offline   Reply With Quote
How do you guys running 18x9.5 in the front do it? ysr50guy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-04-2014 02:49 PM
Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-25-2014 11:46 AM
BRZ stock lugs and lock nuts w/ key scion dad Wheels and Tires 0 09-15-2013 10:46 PM
what upgraded pads are you guys running? ft86me Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-18-2013 01:22 PM
Stock Wheels and Gorrilla spline Lugs Nuts USMC -FRS Wheels and Tires 3 02-21-2013 02:32 PM
