Old 12-31-2014, 02:48 AM   #1
autobot84
Drives: 2013 Scion FRS
Stage 1 tune & long term reliability?
I'm wanting to get an OFT mainly for monitoring purposes and the basic 91 octane tune. My FRS is my only source of transportation and I need it to be 100%.
However, how does a tune hold up over time while the car is being broken in?
autobot84 is offline   Reply With Quote
Old 12-31-2014, 07:36 AM   #2
steve99
Drives: FT86
I would expect that most tunes from reliable tuners would be better than the stock tune.
On 91 octane and even 93 the stock tune will knock quite badly seen stock tune pull up to 4 degrees and have Ignition advance multiplier running around 0.7 where it should be 1.
OFT tunes and other reputable tunes will see minimal if any knock. when a tune appropriate to the fuel you have available is flashed.. Most tuners including OFT will offer 91 and 93 tunes.
Its easy to flash back to stock for service
autobot84 (12-31-2014)
Old 12-31-2014, 07:51 AM   #3
jvincent
jvincent's Avatar
I took delivery of my car in September 2013 and have been running an OFT stage 1 tune since October of 2013. The car has over 40,000 km on it, including multiple track days.
I ran the generic tune until the octane specific ones came out and I'm using the 91 tune now since that's what I fill up with.
Knocking on wood, I haven't had a single CEL or other funny engine behaviour. My only other engine mod at this point is a drop in air filter.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
autobot84 (12-31-2014), Shiv@Openflash (12-31-2014)
Speed Bleeders - long term reliability amram Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 05-14-2014 07:32 PM
Road and Track: Tune + headers + axleback added to long term BRZ tennisfreak Engine, Exhaust, Transmission 42 01-07-2014 03:31 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
Forced Induction - is there a long term reliability problem for the 86/BRZ Dazza Forced Induction 32 09-26-2012 12:39 AM
