11-30-2014, 12:34 PM | #113 |
Drives: Subaru BRZ Limited M/T
What I like about the SRC's is that I probably will not do lot of bushings. The steering rack is all I'm looking at. Bushings are great for racing but not necessarily for DD. Then I'll see how my swaybars play with the suspension.
Always a process Sent from my iPhone using Tapatalk |
11-30-2014, 07:11 PM | #114 | |
You really start to feel the soft stock bushings with higher spring rates. Metal can be a bad idea for a daily driver but poly can work well when done right (single axis). Upgraded bushings are a big deal and even more so if you have a stiff coilovers. - Andy |
11-30-2014, 07:17 PM | #115 |
Then I'll look into it. I already have the Grp N front control arm fwd bushing. It was for my STI. Ralli Spec tells me they are compatible with the BRZ.
Then I'll go from there. Thanks for the heads up Andy. I was just hoping to avoid them, but I guess not. Last I had them put in, on the STI, cost was an arm and a leg. But on this car I should be able to do most of them myself. I bought tools for a reason no. Sent from my iPhone using Tapatalk |
12-01-2014, 12:16 AM | #116 |
Stock bushings are capable. Leave the car as is or else you are changing too many things at once and could possibly get lost in your settings. We'll work with you on specific changes.
12-01-2014, 10:34 AM | #117 | |
- Andy |
12-01-2014, 04:05 PM | #118 |
After paying a premium to have the Whitelines installed on the STI, I'll probably just pay for a complete replacement unit. The hassle is so much less. Install, torque, align. Done.
And, personally, I just prefer the GrpN. Install will probably be over the Holidays, lead times being what they are. Then see what else I need and go from there. It is an expensive way to go for mostly DD. In season I'll do 2 autocross's per month. And this yr I will try for a track day. Justify the price LOL Sent from my iPhone using Tapatalk |
The Following User Says Thank You to FastWhite For This Useful Post: | Racecomp Engineering (12-01-2014) |
12-03-2014, 10:52 AM | #119 |
Update: someone else bought the last set. So mine are awaiting a new shipment. Ya'll are just gonna have to wait on a review. The good stuff always takes time.
12-03-2014, 02:50 PM | #120 | |
Drives: 2015 CWP BRZ Limited
Don't mean to thread jack but i was looking at the RSR sport and the TEIN street flex. I'm not going to track, only car about street Daily drive performance and just having it fit well when i put my new wheels on it (gram light 57extremes) can you give me the pros or cons or just which one you'd recommend between these two? i think i can get the street flexes for like 1500 and the rsr sport would be between 1700-1800..i was told the tein are better because they can be serviced in california down the street from my shop and they have a better warranty.. how would i get my rsr serviced?@! thanks!! John |
12-03-2014, 02:55 PM | #121 | |
RS*R is a 20 minute drive for us. You are correct with TEIN's servicing. RS*R, I'm not as familiar with their services since we've been invited to test their product as an independent tester on multiple occasions. You can't go wrong with either one. Both are designed to improve the qualities of the platform and introducing a little extra sportiness in the experience. Both are capable as street and very light tracking purposes with excellent performance potential. If you care more about ride quality and nice ride height, I suggest looking into the RS*R Black-i as that is much more suited for lifestyle setups. |
12-04-2014, 10:15 PM | #122 | |
Drives: 2017 BRZ
Pondering whether that aluminum needs some help in this part of the world - powder coating? Not sure. I have time to figure it out, gonna be a few months till the rest of the suspension parts are all available and assembled in a box waiting installation. |
12-04-2014, 10:29 PM | #123 |
I emailed racer X on that. For a $100 they'll anodize it black or some other colors.plus the urethane bushings don't seem to available on the website. I can purchase the rod ends but not the urethane bushings.
12-05-2014, 05:08 AM | #124 | |
Because compromise ®
Drives: Red Herring
http://www.racerxfabrication.com/product.php?product=56 Are you using NoScript?
12-05-2014, 09:48 AM | #125 |
When I pick the options with rod ends, then add to cart, the cart will then show one item. Do the same for the urethane bushing and it will never go into the cart to show the item was added.
No biggy, I have to call them anyways to add the anodizing options. It's not on the website. Sent from my iPhone using Tapatalk |
12-07-2014, 10:39 AM | #126 |
Issue resolved. The urethane bushings do come with dust boots which is what I was selecting. All good now.
Similar Threads | ||||
Daily coilover reviews compilation thread. | cdrazic93 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 04-09-2014 01:24 PM |
Coilover Suspension Kits! TEIN | Tanabe | Cusco | KW & More! Lowest Prices + FREE S&H | AJ@ECSMotorsports | Brakes, Suspension, Chassis | 23 | 03-09-2014 11:20 AM |
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 05:25 PM |
