#43 | |
Because compromise ®
Drives: Red Herring
http://www.carcraft.com/techarticles...xhaust_system/
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Kiske (10-09-2014) |
#44 |
Drives: Scion FR-S
Sweet. Thanks for the link.
#45 |
Drives: 2013 WRB BRZ
Any updates?
Second place is just the first place loser.
Dale Earnhardt |
#46 |
Drives: FRS Silver LS1 swapped.
They are going to start working on it again this Thursday, Headers finally came back from the manufacturer CNC processing so they can make duplicates. They are in the process of moving to a bigger shop so things have been slow lately.
#47 | |
Drives: 2013 Subaru BRZ
you're right, hopefully someone will go through the trouble of figuring out how to piggyback the stock ECU to keep steering assist, gauges, etc, because swaps could get a LOT cheaper than $9k in the near future.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
#48 |
What will you be doing with your old engine?
#49 |
Drives: ZC6, Junk of ALL sorts
# 1. Always know where your towel is.
ZC6-CBS, is home |
#50 |
#51 |
#52 |
#53 |
#54 |
The Angry Brit
Drives: 1991 E30 318iS
This is in Plano TX? Any chance I could take a look, depending on their shop hours? I'm not from the area but I visit it often, I have a friend in McKinney. I'll be there the 7-10th November. Really would like to consider an LS swap one day and it would be cool to see one up close while in progress.
#55 | |
I'm sure they would let you check it out along with their other projects just give them a call, they are right in the middle of moving though so stuff is in disarray. Check out their radical Miata build. |
| The Following User Says Thank You to cf6mech For This Useful Post: | VacantSky (10-29-2014) |
#56 |
The radiator can be moved forward on the lower mounts very easily by just drilling new holes for the lower posts and grinding that tab off the frame.
I did this on my turbo install to gain extra clearance. In your pics, you can see how easy it is to do. Grind tab, drill holes, and move forward over 1''. |
| FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates | Steeze_Its | Brakes, Suspension, Chassis | 7 | 06-27-2014 10:32 PM |
| FS: Vorshlag Front Camber Plates | h4nh | Brakes, Suspension, Chassis | 1 | 03-01-2014 11:49 PM |
| FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) | serial gixxer | Brakes, Suspension, Chassis | 18 | 05-20-2013 09:51 PM |
| WTB: Front Vorshlag Camber Plates | YDNA | Brakes, Suspension, Chassis | 0 | 05-03-2013 06:31 PM |
| Maybe a repost, but have you seen the Vorshlag project car? | Bart1 | BRZ First-Gen (2012+) — General Topics | 3 | 01-07-2013 02:19 PM |
