#113 |
Had the diff cradle and outrigger inserts (KDT925) put in today. First impressions:
- Reduces, but does not eliminate, drivetrain lash. Before when I would let off the gas, especially going downhill at lower speeds, I could feel moderate drivetrain shock. Almost a double jerk, as if the drivetrain was bouncing off the stock bushings on decel. Now it is a single jerk. - There is a more immediate reaction from the rear end to throttle input. This is particularly noticeable when applying gas mid-corner. Before, the soft bushings seemed to absorb some of the initial application of throttle. Now the rear end will step out more immediately because of the stiffer inserts. - There is some gear noise when letting off the gas, especially under 2000 rpm. Sounds like a faint, medium-pitched whir. - There is also a faint, hollow noise when letting out the clutch in 1st and 2nd. Overall, I'm really happy with this upgrade, particularly the way it stiffens up the drivetrain lash. The car feels more connected. I don't notice any additional vibration, just some new mechanical noises, which aren't annoying at all. Next track day is this weekend. I'll update if I notice any differences with these inserts.
2022 BRZ Build 2013 FR-S Build |
#114 |
Drives: Scion FR-S 2013 Raven
Thanks for the input @DarkSunrise
o= FR-S =o |
#115 |
Whiteline differential insert bushings review
![]() I just remover the set of bushings insert in the front (the outrigger) of the diff and every clunk and gear wine at any speed are gone... Am thinking keeping the car like this because it's just perfect ![]() I think it's the perfect compromise if your car is a DD. Anyway, with the rear bushings insert, just that maybe remove 80 % of the movement of the diff... What do you think?
o= FR-S =o Last edited by Mikepage; 09-12-2014 at 09:16 AM. |
#116 |
Senior Addict
Drives: 86 GT
Do you mean you removed the "outrigger" bushing inserts? I'm about to install this weekend and contemplating if I should skip on the outrigger bushings.
#117 | |
Yes the 2 on the left first post first picture... See my previous post I added a picture
o= FR-S =o Last edited by Mikepage; 09-12-2014 at 09:17 AM. |
#118 |
Just a quick update after the track days. The diff inserts make the rear end react slightly more abruptly to changes in throttle position. You have to be more careful when initially applying throttle at apex - as I later found out when it rained!
Also wife-approved. The other day, as we were riding in the car, I asked whether she could tell that I had done something to the car. She had no idea. I only have the rear diff inserts though. Probably would be a lot worse with transmission inserts and/or engine mounts.
#119 | |
You have the Whiteline set also right? Did you give a try to the outrigger before making this choice? I think it's the best without the outrigger... For you wife and for the comfort of course...and do not say me "because race car" lol i was loving the feeling with, but, too loud for me during long trip like my last 1600km. Thanks!
o= FR-S =o |
#120 | |
http://www.whiteline.com.au/product_..._number=KDT925 I'm not sure if I got lucky or what, but there's barely any increased NVH. My wife couldn't even tell. I don't have any other inserts or bushings though.
#121 | |
Ok then it's probably very different when you have the subframe inserts
o= FR-S =o |
#122 |
Haha yeah I would imagine so. I am wondering whether I should try adding the Perrin transmission mount insert. Seems like the next logical step.
#123 |
2nd 86 member
Drives: 2013 Asphalt AT FR-S
I have this Whiteline Setup for over 2 months and I love it! My canyon carving is so much better and way more fun!
KCA416 Camber adjusting bolt KSR210 Steering- rack & pinion, KDT926 Gearbox- positive shift kit KDT925 Differential- mount in cradle & support outrigger insert bushings KDT922 Rear Crossmember- mount insert bushings All these bushings & the camber bolts make a difference. The car accelerates better, the turning and cornering are better and the traction is way better. Yes, I do have some new clunks, whines and vibrations, but this car has so many other NVHs', so it doesn't bother me. I have the "Crickets", "water bottle clicking popping sounds" and other stock noises. I haven't heard much luck with replacing the fuel pump, so I didn't replace it. I tried lubing inside the trunk per Subaru but it didn't work. I'm not going to remove the back seat ledge with brake light to fix it as recommended by Subaru unless It drives me completely crazy. If you want the FR-S/BRZ to accelerate better, corner & turn better and have way better traction, I highly recommend this Whiteline package |
#124 |
Drives: BRZ Pearl White
There is a ton of driveline movement on these cars under wheelspin. It seems like the transmission support could also use stiffer bushings in addition to the ones holding up the diff. Are both types available?
Anyone supercharging this car should fit stiffer driveline bushings first or at the same time, it is brutal. |
| The Following User Says Thank You to Ubersuber For This Useful Post: | Mikepage (09-12-2014) |
#125 |
I will add, just a little detail, after removing the outrigger, it's more difficult to engage the first gear during moving when the car is not completely stopped...
o= FR-S =o |
#126 | |
You probably talking about wheel hop...but wheel up is impossible to resolve at 100%...
o= FR-S =o |
| DIY - Whiteline Rear Crossmember Mount Insert Bushings | F1point4 | DIY (Do-It-Yourself) Guides | 91 | 01-17-2021 03:23 AM |
| Whiteline crossmember bushing insert review | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 11-09-2016 04:30 PM |
| Rear Shifter/Transmission Mount Insert Bushings | TheseColorsDontRun | Mid-Atlantic | 7 | 08-30-2013 11:29 AM |
| Whiteline diff bushings and trans mount insert. | Simmons | Transmission and Driveline | 7 | 06-09-2013 09:45 PM |
| WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 5 | 01-16-2013 06:15 PM |
