Old 09-08-2014, 05:51 PM   #57
Akari
Drives: 2013 DGM BRZ
Originally Posted by ort895 View Post
i know you guys are going to hate me for bumping an old thread but my question never really got answered. With 235's they rub at full lock, but what about with 225's? Will 225's make a difference?
Only way you're going to find out is to try with the specific tire you plan to run. Personally I run 235/45/17 Pilot Super Sports with stock suspension and don't rub at all at full lock.
Akari is offline   Reply With Quote
Old 09-08-2014, 06:26 PM   #58
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I'm on 17x8 5x114.3 STI BBS wheels on 15mm adapter spacers with 225/55R17 studless Blizzak tires and I just BARELY rub up front on the lower front fender at a slight angle when turning the wheel. Otherwise at full lock it passes just fine.
I don't know how you're rubbing at all with 235/45R17 tires on a 17x8 +48 wheels. I'm about to have 235/45R17 2011 WRX tires mounted on the STI BBS wheels and I know I won't rub at full lock-to-lock. If I'm wrong, however, I'll let you know.
That all being said, 225/45R17 is basically stock tire dimensions, so unless your stock wheels and tires rubbed, you'll be fine. I had 225/45R17 all-seasons for a bit on my stock wheels, but I had them mounted on the rear wheels.
Old 09-08-2014, 06:49 PM   #59
Akari
Well, we're talking about WRX wheels which are +53 offset like your STi BBS rims but without spacers. Also it's worth noting that ultra high performance summer tires usually have wider tread vs. an all season. Mine are close but with OEM suspension I have had no issues.
The Following User Says Thank You to Akari For This Useful Post:
chanomatik (09-08-2014)
Old 09-08-2014, 07:01 PM   #60
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Yeah, I was alluding to that. I honestly don't recall having any issues with my BRZ on stock 2011 WRX wheels and spacers. I hooned that thing like crazy too!
It's true, I haven't have much opportunity to have wider tires on sunken wheels.
Old 09-10-2014, 06:40 PM   #61
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
Originally Posted by Cheddar View Post
Im thinking 2005 STI gold BBS
Pretty sure only the 2004 ones will fit.
Jond63 is offline   Reply With Quote
Old 01-11-2015, 05:46 PM   #62
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
i just picked up a set i was told by some they need spacers and other they don't have you noticed any rub at all?
Chrisbrz14 is offline   Reply With Quote
Old 01-11-2015, 07:05 PM   #63
Lone Starr
Drives: WRB Limited
On stock suspension and alignment, you should be fine.
I use a 5mm spacer all the way around. Stock suspension, Whiteline camber bolts with oem crash bolts for more negative camber up front and the rim is very close to the spring perch. No contact or rub with 225/45 rs3s.
So...at last we meet for the first time for the last time...
Lone Starr is offline   Reply With Quote
Old 01-16-2015, 12:12 AM   #64
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
i haven't been able to find rs3s in 225, only 215 or 235.
Old 03-31-2015, 02:38 PM   #65
CallmeDave
CallmeDave's Avatar
Drives: 13 BRZ, 07 WRX
Ok considering buying a set with tires for $800 but for the last time is this correct.
Stock suspension: Fit?
Coilcovers" Fit?
Lowering springs: No go?
Thanks guys
13 BRZ Premium. 07 WRX.
CallmeDave is offline   Reply With Quote
Old 03-31-2015, 05:30 PM   #66
Lone Starr
Drives: WRB Limited
Stock suspension: yes
Coliovers & lowering springs: Dependent on camber. Use a spacer to run negative camber or use camber adjustment to return camber to ~0 (stock spec) to avoid spring perch clearance issues if you don't want to use a spacer.
Old 04-29-2016, 12:54 AM   #67
SosaR
Drives: 2016 FRS Release Series 2.0
Someone's selling these used for 300$ thinking of this as a winter setup, should I pull the trigger on em? I just got my car 2 weeks ago and it came with the the trd forged wheels so I'll keep those for the summer.
SosaR is offline   Reply With Quote
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 04:58 PM
TE37SL - 17x8.5 / 17x9.5 / 18x9.0 5x100 Pre Order Available Now ! RavSpec Wheels and Tires 2 07-14-2012 11:37 PM
Wheels Magazine June 2012 Nardi330 AUSTRALIA 66 06-14-2012 11:28 PM
17x8.5 wheel selection Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 06-10-2012 04:13 AM
GrimmSpeed BRZ is Here! GrimmSpeed Member's Car Journals 19 06-01-2012 01:59 AM
