Old 01-02-2014, 11:34 PM   #29
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
2680lb or 1215kg. That's all filled up.
56/44% F/R
Some mods for saving weight, but power and cooling mods that added some too. Build thread:
http://www.ft86club.com/forums/showthread.php?t=53027
jack43 is offline   Reply With Quote
The Following User Says Thank You to jack43 For This Useful Post:
Anthony (01-03-2014)
Old 01-03-2014, 08:53 PM   #30
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
http://www.rearseatdelete.com/FRS-BRZ.html
Claims to drop 23lbs for $300
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 04-01-2014, 02:11 PM   #31
juliog
juliog's Avatar
Drives: 86
Got my car corner balanced yesterday..
2013 Scion FR-S
Seibon DV hood
Tein SRC @CSG Mike
Wedsport TC105 17x9
235/45/17 RS3
Voltex Type 1S
Koyo Radiator
Shorai battery kit @KCMachine
Grimmspeed strut bar
Raceseng lightweight crank pulley
APR Formula mirrors
APR front air dam
Cusco Rear LCA
SPL Rear Toe Arms
No spare tire / tools
100% stock exhaust system
3/4 tank of gas
2860 lbs with driver
~2700 lbs without driver
Corner weights
816 766
664 614
Cross weights
1430 / 1430 - 50% 50%
FR weight distribution
55% 45%
LR weight distribution
52% 48%
juliog is offline   Reply With Quote
Old 06-19-2014, 01:52 AM   #32
AutoRnD
AutoRnD's Avatar
Drives: Fast ones
As a baseline, this is with everything on the car, but it's got Vortech, Brembo GT BBK, 4 point roll bar, lots of chassis bracing, massively wide tires and wheels, RB V1 widebody, no driver 2881lbs. I believe it had a near full tank of gas.
810/795
628/648
That's 1458 + 1423
delta 25 lbs
With the spare it came in at 2907lbs
813/790
637/667
That's 1480 + 1427
delta 53 lbs
Pulling the spare gave me closer cross weights.
now with my skinny ass and no spare it was
3005lbs
864/804
665/672
1536 + 1469
delta 67 lbs
Car is going through some surgery right now so we'll get back to dialing things in afterwards. Displacing weight, or using ballast weight to get us as close as we can to ideal. Currently this has the stock battery but unfortunately lightening that will do the opposite of what I want in terms of cross weights. I either need to reduce weight from the front driver side, lower that side to remove load, or do the opposite to the passenger side.
I had the rack available to me on a full gas tank day unfortunately but I will recheck it again after it gets out of the body shop.
I would imagine you guys should be looking more at your cross weights rather than F/R or L/R.
AutoRnD is offline   Reply With Quote
The Following User Says Thank You to AutoRnD For This Useful Post:
Anthony (06-19-2014)
Old 06-19-2014, 10:14 AM   #33
ja1217
Drives: 2004 Toyota RAV-4 5M
So thats 2902lbs. with me + race gear (~215lbs.) and 70lbs. of ballast for me to stay in my class for time trials.
That would put me around 2617lbs. for the car itself. The car was weighed with around 1/3 full tank. Other than removing the driver side floor mat and spare tire/tools, the interior has nothing removed and is totally stock.
Mods:
Mods:
Essex AP Racing Sprint BBK
Ohlins Road and Track Coilovers
Hoosier R6 225R45
ACT Prolite Clutch/Flywheel
Drive Shaft Shop CF Drive Shaft
Perrin Motor Mounts
Whiteline Diff Cradle
Whiteline Positive Shift Kit
Driveway Labs Rear Diffuser
K&N Drop In Filter
Crawford Performance Air/Oil Separator
Enkei RPF-1 17x8
5lbs. Shorai Li-Ion battery
70lbs. of ballast
ja1217 is offline   Reply With Quote
The Following User Says Thank You to ja1217 For This Useful Post:
Old 06-19-2014, 12:31 PM   #34
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
2617 lbs without me in it. Gas light was on. No trunk junk.
Weight loss mods:
Ballistic battery w/tray
Sparco Drivers seat w/steel brackets and stock sliders
Nameless headers + overpipe/frontpipe (not too much lighter than stock)
MCS suspension w/2.25" springs
TRD intake w/sound tune delete
Weight gain:
Ground control top hats w/strut bar
Cusco solid 22mm sway bar
Wheel/tire combo Weds w/RS3s (42lbs vs 41lbs)
3 point lap harness
Misc bushing inserts
Radium catch can
RiskyTrousers is offline   Reply With Quote
The Following User Says Thank You to RiskyTrousers For This Useful Post:
Old 06-19-2014, 05:05 PM   #35
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
NASA TT? If so, which class (too lazy to get the classification sheet out :-)?
dradernh is offline   Reply With Quote
Old 06-20-2014, 10:36 AM   #36
ja1217
Yeah, I'm in NASA TTD. Apparently the organizers thought the car was too good so they added 110lbs. to the minimum competition weight, bumping it up from 2775 to 2885. The car does pretty well, but I still can't seem to catch up to some of the good drivers in E36 M3's. I could still do an E85 tune and stay in TTD which I'm sure would help my straight line speeds, but I'd like to avoid the hassle of trying to carry around tanks of E85 to the track. My car is already completely full with 4 wheels/tires for the hoosiers, tools, jack, jack stands, camping stuff and girlfriend.
Official Component Weights & Weight Reduction Thread JRitt Tracking / Autocross / HPDE / Drifting 380 05-09-2024 07:49 PM
Official San Antonio , TX Thread!! track_warrior Southwest 3762 03-28-2019 02:03 PM
Official Norwegian Thread atledreier EUROPE 190 01-19-2014 12:38 PM
The Exhaust Weights thread qoncept Engine, Exhaust, Transmission 5 06-12-2013 02:34 PM
