Old 06-14-2014, 02:48 PM   #1
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Blown Engine
What do you guys think about a 350whp Turbo Build that blow a rod, have this happen to anyone else?
The FR-S enguine block was broken at top and the rod came outthe enguine. The driver states that he was not at redline and under normal acceleration.
Let me add this turbo kit have a meth tune, I dont know how was that posible at 350whp? Any light?
Sent from my SAMSUNG-SM-G900A using Tapatalk
kombatlion is offline   Reply With Quote
Old 06-14-2014, 03:19 PM   #2
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Detonation
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 2 Users Say Thank You to woode For This Useful Post:
kombatlion (06-14-2014), raytrix (06-16-2014)
Old 06-14-2014, 03:20 PM   #3
stugray
Drives: 2013 GBS BRZ Limited
If you melt a piston, anything can happen from repairable damage to full blown nonlinear catastrophic structural exasperation.
Who did the tune?
The Following 2 Users Say Thank You to stugray For This Useful Post:
charged86 (06-19-2014), kombatlion (06-14-2014)
Old 06-14-2014, 03:28 PM   #4
mrk1
Drives: Sterling BRZ Ltd
You can pop a motor at any hp level or rpm. Sure it's more likely to happen at higher stress levels but that's not the only possibility.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Old 06-14-2014, 06:34 PM   #5
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
unmodified NA engines have thrown rods too, no big deal.
JP is offline   Reply With Quote
Old 06-14-2014, 07:54 PM   #6
jflogerzi
jflogerzi's Avatar
Just because he threw a rod means nothing. He was using 91/93 with meth. Improper tune, abuse, idk but there are other factors besides he was boosted and the block can't handle boost. Gotta pay to play.
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 06-14-2014, 08:34 PM   #7
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Here in Puerto Rico we have a shop that bought an FRS and build Turbo Kits... the turbo kits are very good quality.
Fiebruzmotorsport
Now tuning I dont know men I have questions... I have 358whp on dynojet. 93oct Meth no fuel upgrades like pump or injectors.
Old 06-14-2014, 08:37 PM   #8
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Is weird men, I just dont want to raise boost anymore I am scared jajajaja
Old 06-14-2014, 08:47 PM   #9
woode
Boosted Member
woode's Avatar
358whp and stock fueling?? What AFR?
Old 06-14-2014, 09:08 PM   #10
kombatlion
kombatlion's Avatar
Drives: Toyota GT86
Run between 10 on full boost to 14 something on normal use
Old 06-14-2014, 09:12 PM   #11
jflogerzi
jflogerzi's Avatar
wow 10 is pretty damn rich under WOT pull.
Old 06-14-2014, 09:18 PM   #12
woode
Boosted Member
woode's Avatar
Weird, I would have thought the stock fueling would have ran out well before you were able to squeeze 350+ WHP out of it. I guess the meth helps out a lot.
Old 06-14-2014, 10:05 PM   #13
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Rpm and thrortlemhave ZERO to do with moment of the breakdown. The damage is typically done over time or during a previous event when breakdowns occur under normal driving. I blew a large hole in #4 on my wrx in a parking lot going 20mph. Obviously thebdamagebhad already been done and it just happened to give out at that time.
It seems many people on this forum have yet to realize a naturally aspirated motor with 150lbs torque is not and does need to be overbuilt, there us zero reason to believe that this engine should stand up to ant reasonable increase in power. In fact tear downs of this engine by professionals have clearly revealed the design decisions clearly favored light weight engine components for high rpm and not strength.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
The Following User Says Thank You to sluflyer06 For This Useful Post:
kombatlion (06-15-2014)
Old 06-15-2014, 02:24 PM   #14
Dephective
Drives: '13 Whiteout FRS
No, this motor does not have forged rods. Yes, this motor was built for high-er stroke speeds. You happen to be missing a few keys points as to other variables that engine internals see outside of just the torque produced by the combustion process, as well was the overwhelming empirical evidence of literally thousands that are boosted on stock internals.
Applying conventional thinking, yes this motor doesn't like boost. Understanding the many benefits of DI, you will start to see why we can make power reliably with boost. The cooling effect on in-cylinder temperatures that DI provides keeps both the piston head cool, and helps prevent detonation. This is especially important at the 12.5:1 CR that we have. Another thing people would say is a disaster for boost. Quite the opposite. Having that high CR allows us to spool much larger turbines with our measly 2.0L, and make some decent torque with much lower PSI. There are many more variables to factor in. The only difference between our block and the FA20DIT factory turbo motor from subaru is different pistons. They opted for a lower CR to be safe.
As for the OP, I very rarely blame a kit for engine failure unless the install was suspect. The real question is, why are you running stock fueling at 350whp? Tuning, especially with adding in the Meth variable, would be my first guess for the root cause of failure. Sure rods just give out sometimes. But tuning is absolutely key to boost reliability. Without having logs, there's no way to know though.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
The Following 2 Users Say Thank You to Dephective For This Useful Post:
kombatlion (06-15-2014), Scalzo (06-18-2014)
CEL - Engine Blown!!!!!!! rapidcars Issues | Warranty | Recalls / TSB 65 12-10-2014 10:32 PM
Blown engine! known head problems? Dmitri Issues | Warranty | Recalls / TSB 72 08-23-2014 04:51 AM
BRZ Blown engine question Mujen84 Forced Induction 118 04-02-2014 06:04 AM
Initial d blown engine be6sti Other Vehicles & General Automotive Discussions 6 10-15-2012 10:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
