03-18-2014, 10:30 PM | #3879 |
Hmm stock catback seems to be the way to go for quietness. Wow, just realized that's with header as well. Awesome stuff.
Did nameless scrape the idea of making this with a cat? I didn't see the option on their website... Last edited by Sonolin; 03-18-2014 at 10:47 PM. |
03-18-2014, 10:45 PM | #3880 | |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
Quite a few pages back.
03-18-2014, 10:46 PM | #3881 |
WTF I thought they were trying to go for STX legal?
Strange, but for most performance no cat is obviously better. |
03-18-2014, 11:11 PM | #3882 |
That guy
Drives: Ultramarine mt FR-S
Their "workaround" is for you to leave a cat in your frontpipe.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
03-18-2014, 11:15 PM | #3883 | |
Loving this headers sound so far though, full exhaust seems to sound better to me than most UEL + full exhaust, at the top end. I guess I like the EL sound better & the fact its a better design. Anybody with full exhaust 2.5" ? How loud is it? |
03-19-2014, 12:11 AM | #3884 |
Fanboy
Drives: 2013 ultramarine frs
Just get a catted front pipe or keep the stock front pipe. The gains from removing the header cat are significantly greater than from removing the second cat.
I'm done helping those who won't help themselves.
TL;DR: -Duke |
03-19-2014, 12:58 AM | #3885 |
Drives: Pavement MT GR86
I'm running the stock cbe.... Might run something at a later date. Definitely quiet at cruise and loud on cold start and semi loud above 4k under load.
GR86 MT premium
03-19-2014, 11:13 AM | #3886 |
Long Distance Driver
Any more coated pics from anybody?
03-19-2014, 12:14 PM | #3887 |
Drives: 2013 Asphalt FR-S
I got a couple yesterday, but im at work. Will post latter. Just picture the uncoated one painted flat black... that's what it looks like
~Namaste~ |
The Following User Says Thank You to mad_sb For This Useful Post: | Sargy (03-19-2014) |
03-19-2014, 01:33 PM | #3888 |
Twin Screw You
@14BRZ I'll retract what I said before about no rattle. This morning, there was a small rattle on intitial startup, but after a few seconds it went away.
03-19-2014, 01:48 PM | #3889 | |
Tuning runner length/diameter on an intake manifold to shift power does the exact same thing as tuning primary/secondary length/diameter on a header. You optimize them so the harmonics work in your favour at the RPM range you want.
The Following User Says Thank You to wparsons For This Useful Post: | Dimman (03-19-2014) |
03-19-2014, 05:59 PM | #3890 |
Drives: 07 AcuraTL-s,2013 ScionFRS hotlava
Still no consumer dyno upto now?
03-19-2014, 06:34 PM | #3891 |
Drives: '87 Corolla GTS, '13 FR-S 6MT
03-19-2014, 10:51 PM | #3892 |
Drives: 2013 Scion FRS
Just received the coated version, they are black / dark grey. Build quality is exceptional as per usual for Nameless. I will post some photos sometime tomorrow.
For those who installed the header, would you mind going through what would be the easiest process? I assume you would: -Completely remove O2 sensors from OEM header (disconnect the entire wires) -Remove OEM header -Clean up area and contact points + install new gaskets (Look here for part # http://www.villagescionparts.com/sho...sembly=1103630) -Install O2 sensors back into Nameless header (Should spacers be added or is there no point?) -Lift engine 1-2 inches via oil pan (unbolt passenger side mount) -Bolt Nameless header onto engine block (Anyone have the torque specs? Has anyone been able to use a torque wrench for those or is space too limited?) -Use the 2 provided nut and bolts to attach header to front pipe -Relocate fan connector with provided ziptie Also - I usually grease most bolts and nuts I remove on a car before putting them back. I know it's not the same situation as an exhaust gets extremely hot, but would you guys apply a graphite grease or something similar to these various bolts and nuts? Thanks! Last edited by Deathreaper; 03-20-2014 at 12:15 AM. |
The Following User Says Thank You to Deathreaper For This Useful Post: | Sargy (03-20-2014) |
Tags |
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
Similar Threads | ||||
Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 10:38 PM |
Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-18-2012 11:32 PM |
Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
