Old 12-30-2013, 03:39 AM   #1
brn12345
brn12345's Avatar
Grev dropping suddenly at high rpm
I was doing a full throttle log last night after the header install and noticed that the Grev falls suddenly at high RPM even though the throttle is fully depressed. I added Engine Load calculated and it holds at 100% until I take my foot off the pedal. This happened in most gears but not always. I managed to get a photo of the log for the 3rd and 4th gears and in 3rd Grev seems normal to the shift point and in 4th it drops at around 7000rpm.
I am running OFT Stage 2.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 12-30-2013, 06:02 PM   #2
arghx7
Drives: car
So one of these is an ECU RAM value, and the other one is a calculated value by the logging?
Old 12-30-2013, 08:45 PM   #3
jamesm
Are you talking about the big drop off when it appears that you are shifting or something? Or the slow tail down after peak torque? If so, that's pretty normal. Load will peak at peak torque and then should stay pretty constant to redline. It's a function of VE, so cam timing has an effect. Load tailing off means VE is tailing off, and you're dropping torque.
Old 12-31-2013, 08:05 AM   #4
brn12345
brn12345's Avatar
I am not sure what "Engine Load Calculated %" is but as far as my understanding goes Engine Load (I have always assumed this was the one the ecu used for looking up tables) as displayed in G/Rev is a function of RPM and MAF. If this value plummets before the throttle is released from full then there is something wrong. The engine cant go from high load to extremely low load this fast.
I am talking about the area in the photo attached I circled in green. On the left circle Engine Load (G/Rev) continues at a high value until the throttle is released. The other figure Engine Load Calculated % also drops at the exact same time. If you look at the circle in the top right, you will see that Engine Load (G/Rev) drops before the throttle is released. RPM, Engine Load Calculated are still high at that point.
I am starting to think there could be something amiss with the mapping. I might try flashing to a stock rom to see if this issue exists.
Old 12-31-2013, 08:35 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Hit the limiter?
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-31-2013, 09:12 AM   #6
trustyler
Drives: Toyota 86
Originally Posted by Kodename47 View Post
Hit the limiter?
What exactly happens to the car when you hit the limiter? I noticed my car loses power and seems like the clutch is slipping or something. Does this make sense?
trustyler is offline   Reply With Quote
Old 12-31-2013, 01:04 PM   #7
jamesm
It looks like that log was running about 3 samples/sec. I wouldn't worry about any synchronization between different channels at that rate. Collect another log at 15+ samples/sec and you'll have much better data to go by.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
brn12345 (01-01-2014), SkullWorks (12-31-2013)
Old 12-31-2013, 01:51 PM   #8
SkullWorks
Drives: SSM LT MT BRZ
I think jamesm nailed it,
Old 12-31-2013, 07:16 PM   #9
ztan
Drives: Toyota 86
Agree with James. This is a logging sync issue - your logs are collected at around 400ms interval (2.5Hz).
The math : Load(g/rev) = 60*MAF(g/s)/RPM(rev/min)
In your logs above, the g/rev number drops faster, but also recovers faster indicating that RAM call is lagging behind all the other parameters or derived from extra MAF and RPM calls.
What logging platform were you using? You can probably speed up by logging less parameters (derive load from above formula). I pull 30 parameters with 5 extra calculated parameters with the Tactrix standalone at a 50ms interval (20Hz). Techstream is much slower, but could also pull VSC data alongside ECU data.
ztan is offline   Reply With Quote
Old 12-31-2013, 09:23 PM   #10
jamesm
with ecutek it matters a lot which params you're logging. some have no effect on speed and are pretty much free whereas others cost 2 or 3 hz by themselves.
Old 01-01-2014, 12:03 AM   #11
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
that the most up to date stage 2? 1.42
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 01-01-2014, 03:19 AM   #12
Kodename47
Kodename47's Avatar
Drives: UK GT86
I guess he's using OFT.
Out of interest, which ones James?
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-01-2014, 08:06 AM   #13
brn12345
brn12345's Avatar
Its the built in retard limiter Shiv built into the map. It does exactly what you feel. Easily removed if you don't like it. I removed it last night for dyno testing and found I like it better without the retard limiter.
Will give it a try thanks! I set BRZedit to log at 20, was logging at 100 before but I guess I was logging a whole bunch of parameters. Reducing them now and will test.
Actually I use BRZedit to log, Romraider to modify the maps, and OFT to flash.
Yes its the most up to date stage 2 1.42.
The Following User Says Thank You to brn12345 For This Useful Post:
trustyler (01-01-2014)
Old 01-01-2014, 08:37 AM   #14
trustyler
Drives: Toyota 86
Ahhh..thanks for your clarification. Does it also prevent the engine from over-revving when a misshift occurs? Because if yes, I'd just leave it on I guess no matter how irritating it is.
K&N Air Filter installed, MPG dropping? HATED1 Engine, Exhaust, Transmission 35 05-09-2018 11:13 PM
Santa keeps dropping the BRZS off HeubergerMotors BRZ First-Gen (2012+) — General Topics 11 12-19-2013 07:26 PM
Car suddenly drives different (Auto)? Weeber Issues | Warranty | Recalls / TSB 52 10-18-2013 11:30 PM
Dropping car off Friday for TSB service.. some questions pgeist Issues | Warranty | Recalls / TSB 6 07-15-2013 03:45 PM
About to buy my BRZ then suddenly... Mango22 BRZ First-Gen (2012+) — General Topics 44 09-10-2012 11:04 AM
