#309 | |
AutoX Nut
Drives: 2020 Toyota Supra
#310 | |
Drives: Some kind of Subaru
@7thgear if you can get the AD08R for a price closer to what the other tires cost, it's worth trying out. |
#311 | |
Senior Citizen
Drives: Scion FR-S
225/45-17 size was tested. For the Toyo to last as long as the Z2 or Rival, it needs to be squared up or even a bit stretched...with more front camber, IMO. Now only if we had a a plus 1" in wheel width option instead of diameter... |
#312 | |
Drives: BMW 135i, soon to BRZ
#313 |
Senior Citizen
Drives: Scion FR-S
#314 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
He's saying that an extra inch would move you out of C Street. I don't think he understood what you were actually saying.
#315 |
If you think that the wheel allowance should've instead been +1 width instead of +1 height, then the cars would be classed accordingly. The SAC recommendation would likely bump the twins relative to other cars.
The Twins' gains for the extra inch would be more than other cars gains. the 7" is part of why the grouping is what it is. |
| The Following User Says Thank You to mrazny For This Useful Post: | simpleisbest (11-19-2013) |
#316 |
Drives: DGM BRZ
i would imagine the increase in center of gravity would be negligible vs. the grip improvement you'd get from running 18's?
#317 |
i'm sorry, what?
Drives: Canada
why would you think you'd be getting any significant grip increase from going up to 18's?
which isn't to say there isn't.. but there are a few things that need to be kept in mind the forumla isn't that black and white
#318 |
Drives: BRZ(sold), STI
What center of gravity? If you keep the OD the same, you'd have the same CG.
The rotational inertia of the rim matters a bit. If you move the thick aluminium band of the rim's barrel within your tire/wheel combo an inch further from the center (somehow keeping the weight the same), you'd increase rotational inertia by %10%. I think it takes about 5-6hp to accelerate all four wheels at WOT. With 18" rim you'd have 0.5HP less going to toward acceleration. Peanuts, if you ask me. Grip increase? Hm. Maybe a bit sharper turn-in, if you go with tires with lower sidewall, keeping the overall diameter the same. |
#319 |
i'm sorry, what?
Drives: Canada
the arguments are assuming the relative tire size goe sup along with diamater for a change in gearing.
#320 |
#321 | |
Senior Citizen
Drives: Scion FR-S
I guess we'll find out this year how the SAC's wise decisions with regards to classing turn out. I think that we will have an uphill battle with the 370Z and only have a slight advantage on tight and heavy transition courses. It will be rough at many regions around the nation, including mine. Needless to say, I can't share your faith in the SAC's ability make smart decisions and balance the classes. Just look at the poor souls with non-M3 BMWs in F-Stock/Street!! It looks like a virtual garbage dump sunday with the M3's on top. |
#322 | |
Classing is about strong classes, not doing the best for every submodel of car. If "A" bmw and "A" mustang are in the hunt, F Street did it's job. The SAC job is huge, with SEB oversight and wishes along with balancing newer driver needs, established driver needs, overall parity, and quality of competition. Those are solid guys putting in a ton of work for whats a thankless job. They do better than most give them credit for. All i can say about wheel width or *any* rules allowance... be careful what you wish for. STX heavy cars wanted more wheel/tire, they got bumped to STU. There's just not room for everyone to get what they want unfortunately. NASA classing doesn't work. |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
