#29 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
#30 | |
Drives: FR-S 10 Series/'93 RX-7
Highly doubt it. |
#31 | |
Drives: Da-Big Banana
Well I'm just here to learn something I might not know about the FR-S and check out all the cool mods......
#32 |
Serial Cone Killer
[QUOTE=Enthalpy;1Highly doubt it.[/QUOTE]
That's what my thoughts were, I just wanted to confirm. Sent from my SCH-I535 using Tapatalk 4
#33 | |
Drives: 2005 Toyota Camry
In the context of this thread, yes the intake resonator for a BMW 3-Series may be different from a 5-Series, but what is the target audience for the car? More importantly, resonators are not about reducing sound... much like aerodynamic lift on a car, the reverse of it is often labeled as "downforce" when it should be named negative lift. Resonators are used to achieve a desired intake noise. Whether that's lower/higher is a part of that, but to say resonators are used to lower intake sound as a blanket statement is adding to the common misconception. But if you want to join the personal attack bandwagon like everyone else, go for it. I judge you by your individual posts, I don't make wholesale judgments on your character by what you collectively post online. To each their own. -alex |
#34 | |
The problem is that you keep saying there is something more to the resonator, but have not been able to prove it even after I showed you 2 cars using the same exact engine, producing the same HP and TQ numbers. All you are throwing is simple unsupportable speculation as to how a resonator is used by a company. |
#35 | |
I am speculating. And in case you missed it, you're speculating as much as I am. Two identical engines and identical peak horsepower/torque numbers does not mean the engines have the exact same tune... it may be very close but there may be minor differences. BMW isn't stupid... the same engine used in a heavier car (5-series) would have a different projected consumption and warranty requirements over the expected lifespan of the model. The easiest way to make changes to this is to fine tune the engine powerband... That's all I am saying. If you continue to read it as me throwing out unsubstantiated speculations, so be it. -alex |
#36 | |
#37 |
Drives: 2018 BMW M240i
#38 | ||
TRD's aftermarket parts are what Toyota feels they can sell to car owners while retaining a warranty. Depending on the territory they can also be street legal if required (CARB E.O. comes to mind, for example). However, given that they are restricted by what they can/cannot do to the ECU (they can't simply reflash the ECU, for example, because it may make the car be in non-compliance of emissions laws), there's always some type of constraint that prevents the part from being the best that it can be. Often times aftermarkets are better performance at a cheaper price than the OEM "racing" version of the same part, because a lot less money was spent on R&D for regulation compliance and more R&D was spent on outright performance. -alex |
#39 | |
All TRD parts are 50-state Emissions Legal. Toyota dealers reflash the ECU's everyday.
#40 | |
1) Intakes are mostly street legal, but not all TRD parts are street legal. Some intakes in other countries may not meet local requirements. If it's street legal it just means the manufacturer has taken the necessary steps to meet emissions requirements. http://www.toyotaracing.com/trd/cata...g_lowres_R.pdf (last page) 2) Toyota dealers do reflash ECUs every day, but that's not my point. Is there a specific ECU reflash that is supposed to be done with an intake install? If not, the R&D was put into the intake itself to work with the OEM ECU flash, hence the higher cost of the TRD intake versus a comparable aftermarket design. A Toyota dealer reflashing a Toyota manufacturer approved ECU flash, versus Toyota offering a ECU reflash that is not in emissions compliance are two completely different matters. The former almost always have to be approved by the EPA prior to being sent to dealers, the latter requires extensive testing to make sure it doesn't change some other parameter of the car excessively. As a closing note, I'm not going to edit anything I've written in this thread. People can read it and figure out if I'm blowing hot air out of my ass or not. And I'm definitely not schooling anyone with wrong/misleading info, contrary to what has been claimed. -alex |
| Tags |
| mav's sandy lady parts, resonator |
| Piano Black Dash Panel and Black Traction Control Button? | stoneman155 | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 10-03-2015 12:09 AM |
| XXR527 Chromium black 18x8.75 Hankook Ventus 225-40 Black BRZ | random hero | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 66 | 02-14-2013 01:20 AM |
| ADVAN RSII 18x8.5 & 18x9.5 (Hyper black / Semi-Gloss Black) - in stock! | Touge Factory | Wheels and Tires | 13 | 01-15-2013 08:43 PM |
| Oakley Halfjacket 2.0 Polished Black with Black Iridium lenses. | Zadkiel | Miscellaneous | 8 | 12-02-2012 02:51 PM |
| SoCal: 2004 S2000, Black on black, 70k miles, 16.3k OBO | Mike | Cars for Sale/Trade | 0 | 08-01-2012 08:54 PM |
