| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2005 Toyota Camry
Oil discussion (pressure, grades, viscosity, etc) - repost from Ferrari Chat
I found this thread many years ago, and figure it's helpful for those wanting to learn more about engine oils.
Feel free to read/bookmark, the info has served me well over the years. http://ferrarichat.com/forum/faq.php?faq=haas_articles Long story short, oil pressure is the important factor in your engine oil's performance. Everyone freaks out about how thin 0W-20 is, but it's not a big deal at the ideal temps. -alex Last edited by mav1178; 08-16-2013 at 02:10 PM. |
#2 | |
Drives: Subaru BRZ Sport Tech Satin White
People tend to think the higher viscosity protects because it resists the forces moving the bearing and journal surfaces together. This is incorrect. Higher viscosity may be needed to keep the oil flow rate correct for your engine design. If the engine is designed for low viscosity oil then using higher viscosity can damage your engine. If you put higher than recommended viscosity oil into your BRZ engine you can slow the flow rate down to the point the oil within the bearings gets too hot. Oil pressure will be high but flow rate will be low. |
| The Following User Says Thank You to Suberman For This Useful Post: | 504 (08-16-2013) |
#4 | |
Drives: 2004 Subaru Forester 2.5XT
I always like to point out that Dr. Haas on Ferrarichat and bitog is a plastic surgeon. ![]() -Dennis |
| The Following User Says Thank You to bluesubie For This Useful Post: | dsgerbc (08-21-2013) |
| oil pressure gauge | onemorelap | Engine, Exhaust, Transmission | 69 | 03-04-2023 06:46 PM |
| Oil Pressure.. too low? | Dave-ROR | Tracking / Autocross / HPDE / Drifting | 65 | 08-24-2013 01:43 AM |
| What Hot Tire Pressure? | gbgracer | Tracking / Autocross / HPDE / Drifting | 24 | 05-14-2013 06:47 AM |
| Oil Pressure Specification | Captain Snooze | Engine, Exhaust, Transmission | 0 | 12-05-2012 07:44 PM |
| Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) | switchlanez | BRZ First-Gen (2012+) — General Topics | 68 | 02-14-2012 08:16 AM |
