Old 02-21-2014, 08:31 AM   #1
brn12345
brn12345's Avatar
Top speed limiter datalogged
If you ever wondered how the top speed limiter worked in our cars here is a snapshot of if in a real world test. At exactly 221km/h the throttle starts to close and by 226km/h the throttle goes to 50%. The car continues to accelerate but very slowly until 230km/h. This is very different from the fuel cut top speed limiter which is usually set close to 500km/h in our cars i.e. disabled.
I also posted on Datazap :
http://datazap.me/u/brn12345/top-speed-limiter-action
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
The Following 6 Users Say Thank You to brn12345 For This Useful Post:
aagun (02-22-2014), flippy (04-30-2015), mad_sb (02-21-2014), Paewrblue (01-18-2015), troek (02-22-2014), userjack6880 (02-21-2014)
Old 02-21-2014, 08:46 AM   #2
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Interesting, thanks for sharing.
Old 02-21-2014, 09:48 AM   #3
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Can we have this kind of limiter disabled with OFT?
Which maps should i modify and which way?
Or was it probably already disabled in OTS maps?
Ondreiko is offline   Reply With Quote
Old 02-21-2014, 10:36 AM   #4
brn12345
brn12345's Avatar
Yes you can easily disable it with OTS. You have to edit the bin file with a software such as romraider.
Old 02-21-2014, 10:52 AM   #5
jamesm
yeah just increase both of the y axis values by the same amount. i think i have mine set to 326/321.
The Following User Says Thank You to jamesm For This Useful Post:
Contender (12-08-2019)
Old 02-21-2014, 10:53 AM   #6
Ondreiko
RWD addicted
Ondreiko's Avatar
Thank you. Which exactly maps/tables:
Miscellanious-limits->Speed limiting (throttle)? Modify all four tables the same way?
I was asking about the table names initially, just probably used the wrong definition =)))
Old 02-22-2014, 04:29 AM   #7
Victor Draken
Drives: Toyota Gt86
@shiv may your remove the speed limiter in the OTS maps?
Victor Draken is offline   Reply With Quote
Old 02-22-2014, 06:01 AM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
As standard its set to 130 odd mph. You'll struggle to get much past that and I imagine they did that so you don't create a lot of heat. You can increase those boundaries on the maps quite easily, just move them well above the possible max speed to "remove" them.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-22-2014, 08:22 AM   #9
troek
troek's Avatar
Drives: 2012 Toyota 86
+1
Old 02-22-2014, 08:59 AM   #10
brn12345
brn12345's Avatar
Agreed on the temperature rise. Check out how the oil temp went from about 208F to 240F+ (Yellow line in the photo) just in this 5th/6th top speed run.
I've also added a log of this run on Datazap.me with more channels logged including oil and coolant temps.
http://datazap.me/u/brn12345/top-spe...g=0&data=1-5-7
Old 02-22-2014, 09:09 AM   #11
brn12345
brn12345's Avatar
You would want to modify all 4 tables. I have attached a photo of Romraider and opened all 4 speed limiter tables. I modified one of them as you can see. Its important that you increment both values by the same amount as I did in the example by adding 40 to both sides.
The Following 2 Users Say Thank You to brn12345 For This Useful Post:
aagun (02-23-2014), troek (02-22-2014)
Old 02-22-2014, 09:20 AM   #12
troek
troek's Avatar
out of curiosity why does it have to be increased by equal amounts?
Old 02-22-2014, 09:35 AM   #13
brn12345
brn12345's Avatar
I don't know really. I am going with the instructions that came with BRZedit which clearly say to increase by same amount. Could be that if you make the two numbers very close i.e. 137mph and 138mph then you would go from 100% throttle to 50% throttle in just 1mph. I would think that could be a safety concern.
The Following User Says Thank You to brn12345 For This Useful Post:
troek (02-22-2014)
Old 02-22-2014, 09:49 AM   #14
troek
troek's Avatar
ahh i see.
Search this Thread:
Advanced Search
rev limiter / fuel cutoff clayrush Engine, Exhaust, Transmission 49 07-25-2017 11:40 PM
Top/Speed limiter for the 86? DriftEightSix AUSTRALIA 4 09-12-2012 01:53 AM
vid of dealership bouncing frs off rev limiter Big T FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 95 08-01-2012 11:54 PM
Rev limiter? feldy Scion FR-S / Toyota 86 GT86 General Forum 4 06-03-2012 10:47 PM
<3 my rev limiter NESW20 Other Vehicles & General Automotive Discussions 1 05-02-2010 11:05 PM
