Old 12-14-2019, 04:08 AM   #1
mtuluca
Drives: 2016 Scion FRS
Unhappy 2016 auto frs wont start and stuck in reverse when "parked"
The car has been sitting for a few months now(i haven't started it at all since its been sitting), i gotten wheels and tires and placed it on the ground and started it with a jump start from my van. It started well and sounded good nothing was an issue. Once i tried putting it in reverse and only one wheel was spinning(idk if it was from the slippery planks under my car or not). But later that night i came back home from work and I tried to start it, it started but still didn't want to move. I then removed all the planks thinking this was the cause. After that I tried starting it again and it would turn the lights on, the dash lights on, and also have the reverse camera on. The car wont turn over or try to turn on. The reverse camera is constantly on the moment the key is inserted and the accesories are turned on. It wont start and its stuck in reverse i have no idea what do. Also topped off on oil and coolant. Everything was plugged in and looked sound, i mean i tried checking everything.
mtuluca is offline   Reply With Quote
Old 12-14-2019, 07:59 AM   #2
gravitylover
Disconnect the battery for a while and before you reconnect it make sure it's properly charged, not just a quick boost from a jump.
The Following User Says Thank You to gravitylover For This Useful Post:
humfrz (12-14-2019)
Old 12-14-2019, 11:20 AM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
You've probably got stuck bushings on the shift rod, so the PNP doesn't return to Park all the way and stays at the edge of the reverse switch. Not in park? No start for you.
Put the lever in neutral.
That won't solve your one wheel spinning issue, but it'll start
The Following User Says Thank You to RZNT4R For This Useful Post:
soundman98 (12-14-2019)
Old 12-29-2019, 02:26 AM   #4
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Ever get solved ?
mswbrz is offline   Reply With Quote
Search this Thread:
Advanced Search
ecutek inside of KVM: A story of how "not supported" doesnt mean it wont work Breadman DIY (Do-It-Yourself) Guides 6 05-17-2018 09:41 PM
2016 BRZ has reverse "R" indicator on by default in gauge cluster mav1178 BRZ First-Gen (2012+) — General Topics 20 12-12-2015 06:52 PM
The "Parked like a D-bag" thread! soulreapersteve Off-Topic Lounge [WARNING: NO POLITICS] 47 08-07-2015 10:01 AM
Note: "Auto" does not start BRZ Dorb BRZ First-Gen (2012+) — General Topics 14 12-02-2012 12:04 AM
Damn..."hit and run" parked on street sdiver68 BRZ First-Gen (2012+) — General Topics 2 09-02-2012 11:25 AM
