11-07-2014, 09:03 AM | #113 | |
King of Kiwi Palace
Drives: Faster than you
The master/slave should not function any differently cold or hot. It's hydraulically operated steel parts. There's no direct heat other than bell housing conduction to the slave, being that the housing is aluminum it really doesn't transfer much heat. If anything is going wrong with the master/slave mechanics I would think a bent fork is to blame before anything else. Or a faulty/incorrectly installed TOB. I've also dealt with DSMs for many many years now, so I wouldn't put aside a notion of worn 1st gear/reverse synchros that have plagued the 4g63. Another notion, lets say there's tranny fluid starvation, in my case after a warm up, I've never been locked out. It's a stretch. I also know that my tranny was properly filled because I did it myself. Lastly, incorrect pressure plate installation can also cause issues where it doesn't matter how you setup your clutch pedal it's not going to disengage fully. When you torque down the PP the release fingers are positioned for the TOB to pivot them to disengage the plate. If one side of the PP isn't fully positioned, when the TOB presses on the fingers, you'll have slight engagement resulting in a lock out. Adding heat, the PP fingers may warp slightly if made from materials not meant for track or extended hot cycle usage. There's actually quite a lot that can go wrong unfortunately...
11-18-2014, 08:28 AM | #114 |
Drives: WRB Subaru BRZ Limited
Bump, any new info on this?
Thanks! |
12-03-2014, 01:50 PM | #115 |
Drives: 2013 Subaru BRZ
The clutch kit that was sent back from QTWRE was installed into the other tech guys car for testing. Steve installed (Former Subaru master Tech) the entire clutch kit, flywheel and bearings that were returned. So far (400 miles) there has been no locking out or shifting issues that he has reported about. The plan is to keep the clutch in the car for at least 5k miles or until there is any problems that may or may not occur.
The Following User Says Thank You to RallySTI For This Useful Post: | Sportsguy83 (12-12-2014) |
12-12-2014, 09:09 AM | #116 | |
I Love custom Turbo kits
Drives: Limited BRZ
the diagnosis I got was that there was no grease on the disk hub. Speaks volumes for great customer service. On another note, I've been running ACT clutch now and so far around 1K miles and no issues (all fingers crossed).
The Following User Says Thank You to Sportsguy83 For This Useful Post: | GT86_PRAGUE (12-12-2014) |
02-17-2015, 11:59 AM | #117 |
Drives: 2013 SWP BRZ (Vortech Supercharged)
I hope you don't mind me necro-bumping this thead, but I just bought a BRZ with an exedy stage 2 clutch and I believe I'm experiencing some drag. (edit, clutch was installed about 8 months ago, invoice doesn't have milage of car on it)
My experience so far: After driving for a bit, I started regularly getting locked out of first and reverse from a stand still. I could "remedy" it by disengaging the clutch, shifting into third (which felt forced), then first. I took the car to the shop and had them do a transmission flush, since I had read a lot of this fixing misc shifting issues. The car shifted much better, and I didn't feel locked out of anything except occasionally reverse. Once I got home, I started reading the shops inspection notes, which inferred there was clutch drag, nothing was done about it, but something should be My biggest issue is that since I just bought the car, I have no frame of reference and I'm not sure how notchy the shifter should feel. I'm going to make an appt. at a local performance shop for this week. Should I be getting the car towed there? or is it safe to drive? The car's warranty is voided, so the last thing I wanna do is mess up a synchro and need a transmission rebuild. |
02-17-2015, 12:58 PM | #118 |
Drives: White FR-S
It's safe to drive. Just be gentle with the shifting if it's giving you trouble.
I remain unimpressed with my stg2 ownership experience. It seems like a finnicky product that's given experienced mechanics problems. My resolution so far has been that I'm now using their 3-puck disc that works with the stock pressure plate. Shifts are back to feeling like stock, meaning smooth with no problems as you would expect from a new modern car. Sportsguy83 also seems to have solved his problem by switching out to a different clutch. I don't know what happened with the rest of the guys in this thread. I thought there were around a dozen of us. |
02-17-2015, 01:10 PM | #119 | ||
Drives: Limited BRZ
Now, there should not be any effort needed to engage first/reverse from a stop. Quote:
I received as warranty the 3 puck clutch and sold it to a forum member, who I really don't know if he's having issues, but there have been no complains and he had seen this thread before buying so that's encouraging. I ended up really happy with the customer service, they did stand up behind their product and tried to make the situation right for me. The locals in this thread (I believe 5 or 6) continued experiencing lockout issues. One of them removed the transmission 2 times, including lats time over lubbing the shaft and disk hub extensively, to the point the clutch slipped for the first hundred miles or so. His lockout issues got noticeably better, but not completely dissapeared.
02-17-2015, 01:45 PM | #120 |
Thanks guys, this is some great info! I appreciate it and I'm really glad to hear I probably haven't messed up my transmission.
I'll reply after I take it to the shop for for posterity's sake. |
02-24-2015, 06:51 PM | #121 | |
Drives: 2013 Scion FRS
I'm still having the same issue with mine. Who did you guys contact to get the warranty? |
02-27-2015, 09:28 PM | #122 | |
I decided to give their stage 2 kit another go, but this time the new kit that works with the stock flywheel (part #15955). That's what the Exedy guy said would work for my application. I had my heart set on the South Bend Stage II Daily kit, but that was discontinued . I'll let you all know how it works out. |
02-28-2015, 03:42 PM | #123 | |
Thanks. Just fill out the forum on Exedy website. Waiting to hear from them. The shop that installed my clutch also had two of their car with the exedy stage 2 clutch that they swap out for the South Bend stage 2 & 3 clutch. They have not had any issue with the clutch like the exedy. I'll see what exedy does for me. I might go with South Bend too. |
03-02-2015, 11:59 PM | #124 | |
Did you receive the replacement part before sending in the old one or anyone else? |
03-03-2015, 12:43 PM | #125 | |||
My experience with Exedy to this point has been a total disappointment. Their concern for us as consumers is nonexistent. Their requesting that I remove my clutch,mail it to them, so they can inspect it while my car sits in the shop waitingfor the new clutch to arrive. Theysuggested checking the master cylinder and changing the transmission oil, bothof which have been done. My shop technicianand the owner of the shop have experience the same problem with Exedy and havechosen to replace their clutch with South Bend Clutch Stage 2 & 3. For them it was headache dealing with the Exedyclutch and not worth the trouble. All I’masking is that Exedy back their product and do the right thing by us consumers. What I’m looking for is a replacement clutcheven though I have to pay hundreds more to install the new one. I’ve read here on this forum of otherconsumers having the same problems with Exedy and getting no help as well, for thatreason they’re all changing to different brand clutches. I’ve called and email a number of times toSteve an Evans but they both choose to not satisfy my complaint. Where do I go from here? I have filed a complaint with BBB and NHTSA regarding thismatter. My concern also is that if myclutch is to fail, I’ll have to take legal action against Exedy. For all consumers that have had similar issuewith Exedy I encourage you to also file a complaint against Exedy. If we get enough out cry on this forum maybeExedy will do the right thing and back its product and finally satisfy usconsumers. |
Similar Threads | ||||
Exedy Clutch | KAR | Engine, Exhaust, Transmission | 28 | 01-03-2016 07:27 PM |
Exedy Stage 2 Clutch | alpine | Engine, Exhaust, Transmission | 21 | 09-09-2014 12:24 AM |
Share your interesting experience when you bought your BRZ/FRS | g0ast | BRZ First-Gen (2012+) -- General Topics | 18 | 02-25-2014 12:39 PM |
exedy clutch questions | ft86me | Engine, Exhaust, Transmission | 8 | 02-13-2014 09:58 PM |
