Old 10-23-2013, 08:07 PM   #43
Dephective
Drives: '13 Whiteout FRS
Any updates? It's almost been a month and I'm starting to check out my options for FI.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 10-24-2013, 01:41 AM   #44
mfbmike
Drives: 2013 FRS, 2008 R32
Me boosta!
mfbmike is offline   Reply With Quote
The Following User Says Thank You to mfbmike For This Useful Post:
Sportsguy83 (10-24-2013)
Old 10-24-2013, 02:14 AM   #45
forzajuve
Drives: Ultramarine 86 - 6MT
@Rev Works - Thank you for posting your kit and sharing with everyone your philosophy and reasoning behind your build. That being said, this may sound like an odd perspective of a question but bare with me...
If Toyota were to have released a Forced Induction 86, could you hold the position that your Rev Works Kit would be at the same level of value/overall quality than the hypothetical Toyota FI kit?
The perspective I am asking the question comes from using Mazda as an example. Mazda releases a FI version of their Mazda 3 i.e. the Mazdaspeed 3. Mazda is confident enough that they can release a turbo car that's engine will sustain life, persist in consistent reliability and leave the driver with an overall feeling of content and/or happiness.
forzajuve is offline   Reply With Quote
Old 10-24-2013, 02:35 AM   #46
Dephective
Um, an OEM is going to do considerable amount more engineering, mostly to the block design or internal components. So no, their kit isn't going to as reliable as any OEM setup from the factory, but then again no aftermarket kit is. Factory forged internals aren't the greatest, but they are certainly better than cast internals. As far as the reliability of their kit, the only two things that you need to worry about for longevity are proper tuning, and oiling, in that order. Tuning is by far the largest factor. Doesn't matter how beefy your internals are if you are getting detonation.
Idk what their oil system looks like, but that coupled with oil temps are the other one, which is less of an issue unless you are womping on it for an extended period of time.
Oil coolers will do wonders for longevity on even stock cars.
Previous:
'01 Accord-daily
The Following User Says Thank You to Dephective For This Useful Post:
forzajuve (10-24-2013)
Old 10-24-2013, 03:31 AM   #47
SUB-ZERO
Drives: GT86/GTR R35
Rev works you in haling hot air for the turbo bcuz the the pipe which is coming from the turbo is beiside the filter which is hot.
SUB-ZERO is offline   Reply With Quote
Old 10-24-2013, 07:27 AM   #48
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
More updates please!!!
Any idea of how much this kit will go for?
Also interested in UEL manifold!
You guys should make it an option.
WTB: FA20 longblock in Socal or shipped.
FTEIGHTSIX is offline   Reply With Quote
Old 10-24-2013, 08:07 AM   #49
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by mfbmike View Post
Me boosta!
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Calum (10-24-2013), mfbmike (10-24-2013), ZionsWrath (11-13-2013)
Old 10-24-2013, 11:45 AM   #50
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Pricing to be released soon guys
Enjoy this video of the kit in the meantime
[ame="https://www.youtube.com/watch?v=z17gHM0JEAo"]Rev Works BRZ/FR-S GTX28 BB Turbo kit teaser - YouTube[/ame]
Rev Works is offline   Reply With Quote
The Following 4 Users Say Thank You to Rev Works For This Useful Post:
Dephective (10-24-2013), DriftEightSix (11-12-2013), FTEIGHTSIX (11-13-2013), Sportsguy83 (10-24-2013)
Old 11-12-2013, 02:07 PM   #51
PICKLEBOY
PICKLEBOY's Avatar
Drives: 2006 Corolla S
Very linear power band for HP nice
PICKLEBOY is offline   Reply With Quote
Old 11-12-2013, 08:54 PM   #52
jamesm
My intake air temps are typically ambient or a few degrees above under boost, so apparently that doesn't matter. At idle the temps creep up when sitting still, then as soon as you get started moving it drops back down to around ambient temp.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Rev Works (11-13-2013), SUB-ZERO (11-13-2013)
Old 11-12-2013, 10:14 PM   #53
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Has it been soon yet?
So will this kit require any cutting ?? Will you still be able to keep the water bottle for windows?
And are you able to supply boost graph?
Will we be able to fit an upgraded radiator with this kit as well?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 11-13-2013, 01:26 AM   #54
SUB-ZERO
aha but the rev works turbo kit looks nice
Old 11-13-2013, 10:01 AM   #55
jamesm
i can answer those questions in to the best of my ability as an owner of the kit:
no it doesn't require cutting that i'm aware of.
i chose to delete the washer bottle. you can add an aftermarket one if you want.
i've posted boost graphs already, but if you like i can re-post them here.
i don't track my car, so i'm not sure about the radiator compatibility. i wouldn't imagine it's any different than any other front-mount turbo kit in that regard.
DriftEightSix (11-13-2013), Rev Works (11-13-2013)
Old 11-13-2013, 10:08 AM   #56
Rev Works
Rev Works's Avatar
Drives: 2013 STi
The only cutting we had to do was cut the stock Fan shroud in half and replace one side of the fans with a slim-line radiator fan which is included in the kit. Other than that the kit works with every other component on the car. The Washer bottle does get removed, due to the Intercooler pipe routing using the space where it would normally be. As James said though, it is as simple as getting a smaller universal bottle and placing it somewhere in the engine bay if one needs to retain the washer bottle.
-Matt
The Following User Says Thank You to Rev Works For This Useful Post:
Search this Thread:
Advanced Search
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
A Sneaky Sneak Peak? White64Goat Other Vehicles & General Automotive Discussions 2 02-20-2013 04:03 PM
Sneak Peak Video of Crawfords Turbo BRZ WingsofWar Forced Induction 48 10-18-2012 10:14 PM
Invidia N1 - Sneak Peak **FT-86 SpeedFactory** FT-86 SpeedFactory Engine, Exhaust, Transmission 54 10-02-2012 10:48 PM
Sneak peak at first Aussie turbo kit MZ21 AUSTRALIA 133 09-22-2012 03:45 AM
