05-22-2013, 01:43 PM | #29 |
Drives: 2013 Scion Frs(Scarlet)
Just checked coolant while the car was hot, and all the coolant is to the top but when the car is cold it shows low...not sure if thats normal
05-22-2013, 01:56 PM | #30 |
Drives: Attitude
Coolant expands when it's hot, so that behavior is normal. As to whether or not the values you see are normal, I can't comment.
05-22-2013, 02:02 PM | #31 |
NASA SpecE30 Racer
As long as it continues to show correctly while warm, then you aren't losing any.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
05-29-2013, 07:59 PM | #32 |
Boosted
Drives: Not a supra....yet
Care to expand on that ? I recently noticed that my coolant is barley over the low mark once it sits over a day or two, but after a long drive its almost full ! Should I just top it off or take it to the dealer , considering I'm going to boost my car soon I'm trying to figure out any issues I have
05-29-2013, 08:15 PM | #33 | |
Drives: 2013 Subaru SWP BRZ Limited 6AT
Rule of thumb: if you measure/check your coolant levels when warm then continute to do so when warm. If you check when cold do so when cold. Just don't mix between the two as someone stated earlier coolant does expand due to temperature.
This issue does seem weird to me. Hope you guys get it figured out. GL. Quote:
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
05-29-2013, 09:06 PM | #34 | |
Boosted
After letting it warm up, and driving to Uni (4sh minutes) it's over 1/4, a 15 minute drive gives me a 1/2 reading What's weird is after a very long drive 1hour or so it's 3/4 full I'm lost, I do know coolant tends to expand but that much ?
05-29-2013, 09:16 PM | #35 | |
Drives: 2018 Golf R
When stone cold (sitting for 24+ hours), the radiator itself is down ~2" and the overflow tank is halfway between min and max. When hot, obviously I don't open the rad cap, but the overflow is about 1/4" above max. That's a huge variation between cold and hot coolant levels. I haven't had the time to have the compression tested by a trusted mechanic yet, but I'm still planning on it. Sent from my Nexus 4
Parting out HERE
05-29-2013, 09:26 PM | #36 | |
Boosted
05-29-2013, 10:29 PM | #37 |
NASA SpecE30 Racer
You guys are worrying too much. As long as you have some coolant in your overflow, then don't worry about it.
- King Tut
The Following User Says Thank You to King Tut For This Useful Post: | SmsAlSuwaidi (05-29-2013) |
05-29-2013, 10:39 PM | #38 |
Boosted
thats what i thought ! i told my self as long as my car didn't over heat yet I'm good
05-30-2013, 12:12 AM | #39 |
Drives: 2018 Golf R
I'm really hoping thats the case, but the white smoke out of my exhaust while on the dyno concerned me. Same with the compression test that the dealer did. If anything, the compression should rise when warm, not the drop (which is what it did).
Parting out HERE
05-30-2013, 12:20 AM | #40 |
Drives: frs
i bought my car a month ago, couple of days later noticed an occasional coolant smell under a load (around 4k rpm, still breaking in the engine so try no to rev it above 4k). took it to the dealer, they said they didn't find any leaks (though I think it was just a visual, the guy said the car is hot, so the system is under pressure, there is no point of doing pressure test). anyways, I put a tape on the coolant reservoir in a morning, while the engine is cold, the mileage was just like 50. Now I have just under 800, one month later, the coolant level is about 3/4-1" down, checked again in a morning.
I just did a quick search for 'coolant' in the topic of a thread and a decent amount of threads came up. It looks like the coolant level drops fairly rapidly for lots of people, yet no one in the threads I looked through were able to determine why. Just seems like it just evaporates at a higher rate when it overflows hot into the coolant reservoir. Curious to see if there will be a reasonable explanation in this thread or if it will just die off like the rest of them |
05-30-2013, 02:46 AM | #41 |
Drives: 2018 Golf R
Well, coolant doesn't evaporate, so its not that. I will figure out what the issue is, but it may take some time.
Parting out HERE
05-30-2013, 07:52 AM | #42 |
Drives: frs
Similar Threads | ||||
FRS uses a lot of coolant? | JLMtm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 124 | 01-23-2015 06:34 AM |
Coolant Question | boredom.is.me | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-15-2013 07:50 PM |
Engine Coolant? | L3P47 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-13-2013 11:33 PM |
Alright to use 5-6 old coolant? | Hanakuso | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-11-2013 08:47 PM |
Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 12:03 PM |
