Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
08-12-2015, 11:20 PM | #15 |
Drives: 2014 Black BRZ
I tried grounding the 4th to the trunk oem ground and still have problems when I have both parking and brake lights hooked up. If I have either one only then it works and I don't get the abs/traction light coming on. Any other ideas?
08-21-2015, 07:04 PM | #16 |
Drives: Audi
Have you tried using a resistor?
08-21-2015, 07:24 PM | #17 |
Custom User Title
Drives: Asphalt FR-S MT
Not the problem.
I actually have my own completely (yes 100%) plug and play kit now, but the mods already don't like me for whatever reasons.
03-24-2016, 10:03 AM | #18 |
Drives: 2010 Tacoma, 2015 BRZ AT Limited
Sorry about reviving an old post but I had a similar issue where my Traction control and ABS lights would come on randomly. The car would even cut my throttle every so often. When the dash lights were on, I noticed that all my brake lights (except my 4th) were on as if I was pressing the pedal, so i assumed the problem was the brake actuator switch thingy. I have valenti tails and the phasetek 4th kit, which i was going to disconnect/switch to stock before i took it in to service but i noticed that as I jiggled phasetek taps, the brake lights function properly and the tcs and abs lights went away. I guess the taps included with the kit are kind of loose and shitty which was causing my issues with this.
03-24-2016, 10:18 AM | #19 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I straight wired mine and still had the issue. I just ripped it out and threw it away.
797Performance.com
Similar Threads | ||||
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ | PhastekSport | Exterior Parts - Lighting | 57 | 07-10-2017 08:14 PM |
Wiring BRZ rear fog light to only come on with front fogs | Scenic Driver | DIY (Do-It-Yourself) Guides | 4 | 09-12-2015 09:36 AM |
Valenti 3rd brake light wiring | SPCorBUST | Southern California | 4 | 09-24-2013 11:57 AM |
HELP WIRING MY ZETA REAR BUMPER BACKUP LIGHT | DealerFR-S | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-09-2013 05:55 AM |
rear brake light in the rear fog light section | FR-Shadow | Cosmetic Modification (Interior/Exterior/Lighting) | 34 | 12-13-2012 10:52 AM |
