Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
10-16-2018, 11:59 AM | #15 | |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Leonardo (10-16-2018), Ultramaroon (10-16-2018) |
10-16-2018, 12:36 PM | #16 |
Drives: 2015 FR-S
A hood strut costs like $15 for the pair https://www.sixityauto.com/sixity-20...BoCQr4QAvD_BwE
A set of mounts costs the same https://www.amazon.com/dp/B01M0JCSTK...d-5d1350972647 Are these companies including $115 in stickers that were prepared by NASA engineers to show off at the car meets? These things should be no more than $50 and also include a gift certificate for a complimentary happy ending at the local massage parlor. |
10-16-2018, 01:06 PM | #17 |
chicken tonight
10-16-2018, 01:32 PM | #18 |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Tcoat (10-16-2018), Ultramaroon (10-16-2018) |
10-16-2018, 02:13 PM | #19 |
Wheels for Brains
I bought the GrimmSpeed hood dampers. They are a tad pricey (~$100 to $140), but I was willing to pay the premium for good design and manufacturing. The brackets are thoughtfully engineered and fully restrained. This is the only kit I was willing to shell money out for. The Greddy carbon kit ($200) looks pretty thoughtfully designed too, but costs more.
I was never impressed by the brackets on a lot of the cheaper cookie cutter import kits ($30 to $80), some are better than others. I work on my car/have the hood open very often; I hardly use them for "show." My friend always thought dampers were just whatever, but he bought a set after he saw mine. We both work on cars frequently, and the convenience was well worth it. Only drawback - on especially windy days (25 mph +), the shocks won't reliably keep the hood up when you're out in the open. However, if you use it in tandem with the prop stick (hood struts holding the stick in tension) or you're in the garage, it works fine. Other than that, totally satisfied with my Grimmspeed purchase. Last edited by EndlessAzure; 10-16-2018 at 04:30 PM. |
The Following User Says Thank You to EndlessAzure For This Useful Post: | GrimmSpeed (10-17-2018) |
10-16-2018, 04:04 PM | #20 |
I had the 86speed V2 shocks. They were cool but the sticker came off and the hood never really closed 100% correctly.
I got rid of them because I realized I bolted 5 pounds of steel to my hood |
10-16-2018, 05:47 PM | #21 |
Drives: 2018 Ford Mustang EB Premium 6M
Just ordered the 86Speed V2 dampers and the OE arm rest. Hoping the lower bracket on the dampers works out okay and doesn't move around. If not a small modification should fix that
Don |
10-16-2018, 07:06 PM | #22 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I've had my Grimmspeed ones for years and have no complaints!
http://www.seriesblueadventures.com/...d-hood-struts/
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
The Following User Says Thank You to Stang70Fastback For This Useful Post: | GrimmSpeed (10-17-2018) |
10-16-2018, 07:10 PM | #23 | |
A.K.A. Starlord
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post: | GrimmSpeed (10-17-2018), Ultramaroon (10-17-2018) |
10-16-2018, 08:45 PM | #24 | |
Drives: 2015 FR-S
That $30 includes profit too so... With profit in there already and another $20, that is plenty. At $50, they'd probably be walking away with still $35 in profit. I am in construction and my materials work out to be roughly 60% and I walk away with only 40%. With them making 70% profit, I think that's plenty. |
10-17-2018, 03:35 AM | #25 |
Drives: Toyota 86
I've had my Grimmspeed hood struts since 2013. No problems whatsoever. If I were to do it again I'd still get the Grimmspeed ones. I've seen the other dampers in person and they don't look as nice and don't open the hood as much as the Grimmspeed.
The Following User Says Thank You to HRTROB For This Useful Post: | GrimmSpeed (10-17-2018) |
10-17-2018, 11:50 AM | #26 | |
Despite the belittling and insulting post I'd like to educate you a little bit so maybe you won't do the same thing to someone else. You've done an excellent job identifying two main components of a hood spring system, which is a start. So you buy these 2001 Camry gas springs and this set of generic set of mounts. DONE! Just got yourself a hoodstrut kit for $100 less than we sell it for. Man, we must be absolute THIEVES! So you go and mount it. But how do you do that? I see you got two right angle mounts, that's good. But you needed four. Luckily you're very clever and have some scrap angle iron around to make one of the flat mounts into a right angle mount. Brilliant! Also, you had to cut and drill those pieces of angle iron. But you already had the drill, bits, and saw, so that counts as free, right? Good. You got brackets that will now bolt to the car. But how do you attach them? It doesn't matter, this stuff is super easy and you do not mind drilling a hole in your hood and putting some self tapping screws into your hood. No one is going to mind some randomly drilled holes, right? Since it worked so great on the hood you do the exact same thing to the chassis of the car. But you have a little class, and you notice that the crappy galvanized brackets look awful next to the paint on the car, and the angle iron mount you made is already rusty, because you know..... angle iron. But, being a complete pro like you are, you have some spare black spray paint. Spray em up, they look fantastic. So now you have gorgeous painted hacked together brackets, secured to the hood and chassis with permanent holes you drilled and fitted with self tapping screws. You knew exactly where to put them because all you have to do is put the springs between the hood and chassis and mount them. Except you notice that the hood isn't even open as high as it used to with the prop rod, what the hell! You got this though, nothing but big plays coming: So you just move the brackets, drill some more holes, and screw the brackets in. Now it opens ALMOST as high as the hood used to with the prop rod. Good enough, right? No, because now when you go to shut the hood not only is it insanely difficult because the spring force is WAY too high because you bought gas springs for a Camry with a steel hood. You're pulling down with all your weight and you get the hood to start moving, the brackets are flexing because they're literally not designed to do what you're trying to make them to do, and then one of the brackets shears both of it's self taping screws right off because they were not even close to the correct size for the application. But you're still very clever, and realize that you can just use one side, that's only half the spring force. You could have gotten this job done for HALF of what you spent. Maybe you'll hook your buddies car up with the other half of your design when you're done. So now its still way too stiff, but you can at least get the hood to start closing. You get about a foot away from latching and it won't budge. The gas spring is compressed to the maximum and the hood won't close. This is now the second time you realize you can't put the brackets where ever you want. Still being the super clever person you are, you realize that maybe you can't just use any length of gas spring either, maybe there is a specific distance that it needs to be compressed and uncompressed too. And maybe you also need to make the fixed points of that spring in specific places too. And maybe the gas springs need to be a specific spring force in able to open and close without damaging any components, but while still being able to not fall down. Then you realize just how difficult it will be to make these four variables do what you think they're going to do. And now you're out the thirty bucks you spent, the paint, hardware, scrap, and most importantly: The time you wasted. And you still don't have a set of hood struts, but you have a bunch of sweet speed holes that you drilled in your car to remember this occasion by. But it's no big deal, you'll make that money back ASAP working at that local massage parlor. To everyone else, that you very much for the kind words and recommendations. I also appreciate that most of you understand that while I'd love to give away everything we make, we simply can not. Unfortunately we need to not only order and produce these parts (the extremely high quality gas springs we use are completely custom and cost us more than those camry ones for example), but we also need to pay all of our wages, our building, our everything. And we can't exactly ask our distributors to sell these for us for free either. Unfortunately I also need to survive and haven't won the lottery, and while I do enjoy a good linkage design, I also need a little money. We also refuse to cut corners on quality. The ones you can buy for $85 on ebay or whatever have very thin brackets that flex when you articulate the hood, especially because the gas springs themselves are not the proper force. The brackets themselves are universal garbage just like what was posted, but have at least been painted (not powdercoated like ours). The gas springs themselves are the bare minimum, poorly spec'd and will not last as long as ours. And above all, they open the hood LESS than the prop rod. As stated, these are fine for a lot of people and are a great way to save some money if you don't really care about the outcome. See, I can have fun too :P Thank you again everyone, it still makes me very very happy to this day to see people recommending our hood struts. Please let me know if anyone has anymore questions, or if you'd like to go another round in hood strut 101. Chase Engineering |
The Following 13 Users Say Thank You to GrimmSpeed For This Useful Post: | Brink (10-23-2018), daskaman (10-17-2018), finch1750 (10-17-2018), Gunman (10-17-2018), HRTROB (10-19-2018), humfrz (10-17-2018), new2subaru (10-17-2018), pinoy_dorifto (10-23-2018), Stang70Fastback (10-17-2018), Takumi788 (10-17-2018), tehShirt (10-18-2018), Ultramaroon (10-17-2018), yelsew (10-17-2018) |
10-17-2018, 11:59 AM | #27 |
Drives: 2019 Mazda Miata RF
The Following User Says Thank You to Gunman For This Useful Post: | GrimmSpeed (10-17-2018) |
10-17-2018, 12:16 PM | #28 |
Drives: 2015 FR-S
I also made a perfectly functioning oil catch can for about $20 instead of $300 that's been on now for a couple years doing exactly what the ones that cost 15x the amount does if anybody else wants to bite on that one.
Nice to know that some hood strut set out there is made to outlast the car it's on though. Also: "Despite the belittling and insulting post....you'll make that money back ASAP working at that local massage parlor." Nobody was directing anything at you little fella. You didn't have to take anything personally. Good to know that NASA had their brightest engineers on the job for this though since we don't want our hoods ripping off or stuck open coming in on re-entry. Of course some of our audience in here will also buy a custom $5k set of wheels on a $25k car and when they give up on their rocket bunny kit try to sell them for $4800 firm in classifieds so maybe some people just have tons of money to shit away and have no concept of return on investment. |
The Following 2 Users Say Thank You to Impureclient For This Useful Post: | Tcoat (10-17-2018), x808drifter (10-17-2018) |
Similar Threads | ||||
Hood Dampers | AlexK | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 01-20-2015 05:08 PM |
Anyone tried Hood Dampers | technoid | BRZ First-Gen (2012+) -- General Topics | 29 | 08-08-2014 02:27 PM |
Carbon hood and hood dampers?? | ft86me | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 10-19-2013 11:57 AM |
Hood dampers | Ryan86 | AFRICA | 31 | 06-04-2013 02:23 AM |
Looking for Hood Dampers meant for CF hood. | Vicious LED | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-31-2012 02:47 AM |
