09-15-2018, 10:10 PM | #253 | |
Drives: 2016 BRZ Limited Automatic
The like idea of running a 195/65/16. My only concern would be lateral stability in the dry. |
09-16-2018, 04:24 AM | #254 |
Drives: 2014 GT86
BTW, have you thought of not going for max diameter tires you can fit w/o rubbing, instead installing strut lift spacers or a bit longer springs and closer to stock diameter tires?
As for dry/wet stability/performance on tarmac .. those are points i also don't care much in winter. Car will still handle good enough driving within legal limits , and possibly still will be more stable then most normal family cars or SUVs. I simply can hoon/push a bit less on roads in good state. I can afford give up some grip when it's plentiful. I want to maximize grip when it's scarce. |
09-16-2018, 10:18 AM | #255 | |
As for the lateral stability concerns I agree with you. The car should be find under normal speed limits. Thank you for your help. |
10-09-2018, 12:45 AM | #256 | |
Drives: 2018 Gt86
10-20-2018, 05:45 PM | #257 |
10-29-2018, 10:09 AM | #258 |
Drives: 2018 BRZ Limited Perf Pack
I've just fitted the Michelin X-Ice 3 to my stock wheels.
So far, so good. A bit of wheel slip in the wet on cold starts. I'll be back with more useful content when we get some snow and/or colder weather. I think some of the slip may have been due to the sheer volume of tyre lube used to mount them. edit - cold rain and plastic crosswalk stripes = engagement of TC.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon Last edited by atomicalex; 11-07-2018 at 08:53 AM. |
03-06-2019, 08:18 PM | #259 |
Drives: 2017 BRZ PP CWP
Tire: Michelin Xice3
Size: 215/45/17 on stock Performance Pack rims Location: Central New Jersey Driver: Spirited? I hit redline several times a day and generally push the car pretty hard on public roads. No track days though. These winter tires have been great over the past few months. I had read a number of reviews which said that these would be closer to an all season tire than the blizzaks. After going through a few inches of snow and ice, I can say that you don't need anything that's more of a "snow tire" than these if you live in the tri state area. Grip levels on dry roads were just as good as the stock primacys. My only gripe is that they dramatically took away from the car's steering feel. Probably because the tread is so high. |
03-07-2019, 01:02 AM | #260 |
Drives: 2014 GT86
BierMeister: all proper winter and all-season tires will numb steering feel. Alternative is only to compromise their main purpose of providing more grip on ice/snow and in general when cold. Just live with that, generic trait of all winter tires. Softer rubber, more sipes, small thread patches. They all are for extra winter grip, and they all are making steering feel worse. Sometimes people also use in winter higher profile narrower tires, which also worsens feel, but i guess to less extent then rubber compound and thread pattern/size.
05-17-2019, 10:53 AM | #261 |
Drives: Pumpkin Spice FR-S
Pirelli Sottozero 3 - 205/50R17
Great traction on deep snow and wet roads when new, better than many other snow tires I've used. However as they wore down they became almost useless in snow deeper than 4-5 inches. I ended up replacing them when they had around 6/32", which seems early to me. For reference, my gravel driveway rises 8' at between a 0.1 and 0.35 grade around a 90 degree bend and requires a running start of at least 8-10mph for any vehicle except a locking 4x4. These tires were able to get me up every time but struggled as they wore down. I don't recommend these tires tbh, unless you experience more wet/slushy roads than deep snow or don't mind replacing them early. |
05-17-2019, 11:32 AM | #262 |
Drives: 2014 GT86
You do know that winter tires work well with deeper thread left then summers may? Here locally state even legally require for summers to have minimum 1.5mm and winters minimum 4mm thread grooves left ..
If that's minimum somewhat allowed, i wouldn't expect wonders from it at such wear. Especially as grip of most tires in general is far from new once worn past first 1/3rd. |
05-17-2019, 11:43 AM | #263 |
Drives: 2015 BRZ Sport Tech CWP
I've had Hakkapaliita's on my car for a couple of years now and was blown away by the grip when they were new. Last winter not so much. They still look great and have visually enough thread but I will be replacing them coming winter for sure.
05-25-2019, 01:02 AM | #264 |
Drives: 2018 Subaru BRZ Premium, Blue
Tire: Vredestein Quatrac 5
Size: 205/55R16 Location: Kansas City -> I-70 + I-15 through Colorado into Irvine, and Kansas City -> I-80 through Wyoming into San Jose Driver: Spirited driver. Grew up in the California mountains above the one-mile mark so used to snow, and rear-wheel drive. Porsche 944, a 70's Ford pickup truck, gravel/dirt roads, etc. I've also autocrossed in the past in various cars. Quatrac 5 Impressions: Despite running head-long into the massive blizzard in Colorado on November 11th/12th that shut down swaths of I-70, I never had any issues. Across Kansas in that same blizzard with 60+ mph winds the tires still had plenty of grip and never had any slipping issues. Later in January when I was heading home from San Jose I ran into ANOTHER blizzard in Wyoming this time that shut down all of I-80, so I ended up waiting for them to re-open the highway. I hadn't noticed any traction issues then either. In both cases I actually had to disable traction control at a couple of gas stations that had deeply piled muck over packed ice so I could let the tires spin a little to get moving, TCS's throttle-killing is a hair too aggressive. At this time after 12k miles (11k racked up in four long multi-day highway trips, rotation every 6k miles) both tires are down to 8/32's from the original 10/32's, and come with a 55k treadwear warranty so they're pretty much dead on track. |
08-10-2019, 06:35 PM | #265 |
Database error
Do you recommend: Nokian 205/55R16 91H WR SNOWPROOF / or Nokian in general?
09-11-2019, 07:24 PM | #266 | |
Take a look at these TireRack results in the snow/ice: All Weather Tires (such as Quatrac 5) https://www.tirerack.com/tires/tests...r.jsp?ttid=231 Winter Tires (Blizzaks, etc.) https://www.tirerack.com/tires/tests...r.jsp?ttid=193 Also, All Seasons in the snow/ice: https://www.tirerack.com/tires/tests...r.jsp?ttid=201 It seems like the All Weather Tires could be an excellent option for year round use in places that get low amounts of snow and ice? |
Similar Threads | ||||
Winter tire experiences? | smbrm | CANADA | 10 | 11-06-2012 04:42 PM |
What Winter Tire for NY Weather? | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 84 | 10-29-2012 07:02 PM |
Winter tire | Dub666 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-12-2012 01:32 AM |
Need some help picking a winter tire... | jm1681 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 08-29-2012 01:14 PM |
Contribute your review for California Scion/Subaru dealers | DuMa | Southern California | 20 | 02-06-2012 11:59 AM |
