Old 06-12-2013, 08:49 AM   #1
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You have crickets. I have woodpeckers. (Fixed)
As of this weekend, my crickets evolved into woodpeckers. I change has and the crickets pretty much went away. However the high pitched noise that we know an "love" was replaced with a more knock-on-wood sound. This new noise of mine follows the same pattern/frequency as true crickets which leads me to believe that the sources are the same. The difference is that this notice can only really be heard from inside the car, but it is much much louder.
Either way, I'm at the dealership getting it checked out. The service attendant im working with obviously knows about the car. Right off the bat, he told me that the crickets are definitely a recognized annoyance within Toyota. He also informed me that there is a fix for it. This fix may be what fixes my woodpeckers. The car is getting checked out now.
Old 06-12-2013, 08:50 AM   #2
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Keep us posted!
Carlitoz3 is offline   Reply With Quote
Old 06-12-2013, 09:19 AM   #3
Scionshaun
Aloha!
Drives: Whiteout
Yup keep us in the loop
Scionshaun is offline   Reply With Quote
Old 06-12-2013, 09:25 AM   #4
boredom.is.me
Custom User Title
Will do. Here is a little additional info. I've used 93 octane from Sunoco, 711, QT, BP, and Shell in the past without any issues. When I switched, I had a near 50/50 mix of QT and Shell. It was fine for a few days, maybe three. The I went on an airport run which is about 50 miles. That's when the woodpeckers moved in.
Old 06-12-2013, 10:38 AM   #5
DarkSunrise
DarkSunrise's Avatar
Assuming this happens at idle, does the sound go away when you clutch-in? Could be the flywheel rattle issue which apparently happens to some folks only at idle.
2022 BRZ Build
2013 FR-S Build
Old 06-12-2013, 11:09 AM   #6
boredom.is.me
Custom User Title
Not at all the issue...or I should say was the issue. This was also audible along side the induction whine.
Update:
Two hours later, I have a new fuel pump. Now I don't even have crickets. It will be a while before I know if true crickets come back since I will soon be going away for the rest of the summer.
So here is the diagnosis. The fuel pump technically did not fail, but there was a mechanical issue with it. The service rep, didnt know exactly what have out or how long it would have lasted. I think my case is the first of this nature. My personal speculation is that it probably would have completely failed if I didn't have it dealt with.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Marchy (06-12-2013)
Old 06-12-2013, 11:28 AM   #7
tomato86
tomato86's Avatar
Drives: '13 FR-S | '08 Evo [Sold]
I had my high pressure fuel pump replaced by Toyota on Saturday too, crickets gone. Phew.
tomato86 is offline   Reply With Quote
Old 06-12-2013, 02:21 PM   #8
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
How many miles did you put on that fuel pump before woodpecker moved in?
Old 06-12-2013, 05:52 PM   #9
boredom.is.me
Custom User Title
I had 5025 miles on it. The original crickets started around 300 miles.
I have a audio recording. I just have to sift through 11 minutes to get the best clips.
Sigh-on-Rice (06-12-2013)
Old 06-12-2013, 11:53 PM   #10
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Apparently, there is a revised fuel pump that fixes the issue, instead of relieving it for a couple hundred miles (early cases where the dealers replaced the pumps with the same, but new part). I'm assuming you got the "new design" pump installed?
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 06-13-2013, 12:07 AM   #11
boredom.is.me
Custom User Title
Yes, the pump I received today is a revised model and not just the same thing. So I should not get any crickets. If the crickets stay away, then so will the woodpeckers.
Old 06-13-2013, 12:22 AM   #12
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
hm... i just got my new pump do you feel a difference when putting your foot on the gas pedal? like the feedback you get? mine felt different when i pulled off the lot, and feels like it runs smoother. don't know if i have the new revised pump installed bc my service guy s aid there isn't a replacement yet
Kosmos is offline   Reply With Quote
Old 06-13-2013, 12:46 AM   #13
boredom.is.me
Custom User Title
I just went out for a drive "cuz I was bored". The replacement performed like a champ. @Kosmos, it didn't feel as restricted/stifled as before. It may be placebo effect, but I think it feels better. Ya I had fun with that Miata.
Old 06-13-2013, 01:11 AM   #14
Carlysh
Carlysh's Avatar
Drives: 2007 Mazda 3, New Raven FR-S 6mt
So it is a easy fix?? If it start take it to the dealer and get a new fuel pump?
Carlysh is offline   Reply With Quote
(TSB) No More Crickets Under My Hood!! xpicer Issues | Warranty | Recalls / TSB 1140 12-04-2015 09:53 AM
Crickets? Jertronic Scion FR-S / Toyota 86 GT86 General Forum 15 05-24-2013 09:38 PM
Different kind of crickets... KSC Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 03-19-2013 06:51 AM
Crickets After TSB... boredom.is.me Issues | Warranty | Recalls / TSB 9 01-06-2013 12:29 AM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 07:39 PM
