#71 | |
Old School Status
Drives: .
#72 |
1337
Drives: 2013 BRZ WRB S/C
Hi @Racecomp Engineering
I had my eyes set on a set of KW V3's but the lower price point of the Tarmac 0 has my interest peaked. My main concern is the damping itself, can you please comment on maybe the downsides of the dampers on the Tarmac 0 vs the V3/Tarmac 2? (minus the ability of adjustment of course, which if I'm honest I doubt I would really play with much if I had the V3's). Is there a significant difference in technology/method of damping/valving that the T0 uses compared to the V3/T2? Would it be possible to set the V3's to feel the same as the T0's, or is there something inherently different? If my memory serves, the spring rates in the KW's are 340/400 (?), is there a reason you went so much softer aside from the added comfort? Also, last would be about the lifetime warranty. Is that through you or through KW - and does it work the same for Canadians? PM a price for the T0 to Kitchener, ON, N2E3V9 Canada with USPS? Last edited by djdnz; 06-07-2013 at 02:08 PM. |
#73 | |
Drives: WR blue
#74 |
Drives: Firestorm FR-S AT
They are here, will be installing them on Sunday!!
| The Following 2 Users Say Thank You to UnOvertime For This Useful Post: | JoeBoxer (06-08-2013), Sportsguy83 (06-07-2013) |
#75 |
Like any lowering application if you lower the car much more than an inch (25.4mm) you start to kill your camber curve(geometry) resulting in more of a push(understeer).
If someone says" i just want my car to be LOW and dont care how it handles", then sure lower away. For this set up NO LCA are not needed if you stick to the 20-25mm lowering range. Yes you should get WL rear camber adjustment bushings so you can even out rear camber at a minimum. SIDE NOTE:People seem to be stuck on replacing rear control arms yet dont replace the FAR MORE important upper control arm bushings that have 4 , soft, bushings that hold the 2 heaviest arms to the rear of the subframe. So yes those who replace rear control arms and did NOT replace those upper bushings have only put MORE pressure and strain on the upper bushings. Lets see Whiteline rear camber adjustment bushings cost 150.00 and rear control arms are 550.00. ![]() Anyway....the only parts needed to install these coilovers are the OEM conical washer that I posted on the previous page. Thats needed for use of OEM, GROUP-N, and COM-C front mounts. The rear can use STOCK mounts. These shocks come with a slight slot on the front struts so use the stock bolt to adjust camber as it does NOT Stretch like the WL camber bolts do. STOCk can be tq-ed to 140 ft lbs. WL's stretch above 85 ft lbs. Hope that helps. Myles |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | mikochu (09-03-2013), Sportsguy83 (06-07-2013) |
#76 | |
Again... there are optional rates of 350/350 and 400/400 for those who want a more aggressive....set it and forget it set up. Yes we went that soft knowing that there are FAR more people who daily drive their cars and do NOT want SUPER FIRM and or track day tolerable set ups. The outpouring of response has been this,....." Hi I dont plan to track my car or autocross but I like to drive spiritedly from time to time and maybe lower my car. I was on the fence about the yellows but these piqued my interest...". Literally had about 12 pm's in a row like that and I thought it was one of my employees pulling a prank. Then we realized....not everyone with a Zizzle or Frizzle is SUPER GT hardcore ! So the softer rates are very much designed for THAT guy ! ( hence our old usage of "REGULAR GUY" springs for the Impreza's ! Warranty goes thru KW USA in SANGER California. |
#77 | |
If one buys Lower control arms....PLEASE replace the upper rear control arm bushings with Whiteline poly bushings that are NOT adjustable and are a 2 piece deal. IF you do NOT replace Lower control arms then get the WL adjustable camber bushings for the upper arms. Myles |
#78 |
For T2 owners here are some basic settings to get started with. I used this huge sheet while tuning months ago. I am working on a comprehensive set up sheet to post in a few weeks.
#79 |
Keep one thing in mind: my car has ALL pillowball and poly bushings.
When I had ALL STOCK bushings I was much higher on rebound by about 4 clicks. Each major bushing change resulted in tuning rebound OUT(down). This shows that the bushings DO effect feel considerably. Also when making changes to rebound and compression, make ONE CHANGE AT A TIME. Other wise you wont know what made the difference you like. I always start by tuning the extremes: super bumpy back road at slower speed, then same road at higher speeds( WITHIN REASON AND THE LAW and COMMON SENSE). Then tune for smoother roads and find happy medium. Make sure tire pressure is correct. THese are the basics. Im not opposed to calls asking about set up. But I will almost ALWAYS ask you " whats your settings" on the phone. Enjoy. Myles |
#80 |
Drives: Blue Subarus
Just got my T2s in the mail today. Excited to replace the stance c/os!
![]() I've had the T2s on my WRX for ~6 months and am very happy with them. Thanks RCE!
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1 |
| The Following User Says Thank You to pmccut For This Useful Post: | Racecomp Engineering (06-08-2013) |
#81 |
Drives: Toyota 86
#82 |
#83 |
Drives: FRS
Do either of these set ups offer additional suspension travel over stock? If so, how much front and rear?
#84 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
As soon as I can swing it, I will be getting these Tarmac 0s.
I'm glad such a setup was produced. Thanks RCE! |
| The Following User Says Thank You to uspspro For This Useful Post: | Racecomp Engineering (06-08-2013) |
| Racecomp Tarmac II Clubsport coilover | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 11-17-2013 12:02 AM |
| Tarmac Zero Coilovers Specs? | tintumz22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 06-14-2013 12:26 AM |
| KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! | NJA | Brakes, Suspension, Chassis | 7 | 03-30-2013 09:26 PM |
| Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-12-2012 01:24 PM |
| Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster | knoxviue | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 35 | 01-20-2012 02:44 AM |
