#15 |
Drives: Whiteout FR-S
Mosconi 6to8 looks good too.
#16 |
Drives: FR-S 10 #103 AT
In all fairness the Cleansweep shouldn't really be in this list. If I remember correctly, it works by reading the output of the H/U while running a test cd and setting internal equalization so that its own outputs are a nice flat signal that can then be tweaked by your crossovers and amps without having to deal with the lousy factory equalization.
It doesn't have anywhere near the power of a good processor, it's more like a deluxe output converter.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
| The Following User Says Thank You to mid_life_crisis For This Useful Post: | Sbeezy (06-06-2013) |
#17 | |
Drives: Argento 6spd FR-S
only issue with that is for the price the interface is complete garbage. I wanted to get it instead of the 360... but was so terrible using the software it turned me off instantly. |
#18 |
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
#19 |
Ya they are funky to do stuff with... with trial and error you can get them to sound great, but still have limited user adjustments. If you can find one used forl like 350 its a good deal, more than that..... pass
#20 |
Drives: GT86
#21 |
Drives: 13 BRZ Limited & 16 Hyperblue
get this for the sub box instead. http://www.jlaudio.com/product/54216....1050512.0/BRZ
#22 | |
#23 |
Drives: Galaxy Blue BRZ
JBL MS-8 works perfectly for me. If you use it properly with the right equipment, it will give you audiophile quality sound a hell of a lot quicker than a BitOne, 6to8, PS8 etc. I think a lot of amateurs just like having a myriad of bells and whistles to tool around with until it sounds good to them.
Also, the MS-8's method of post-set up EQ'ing is a hell of a lot more sophisticated than the 'nuts and bolts' DSPs and means that you're more likely to improve the sound by tweaking rather than constantly messing it up. Of course, if you're a professional audio engineer with 20 years experience and very expensive test equipment, it's possible you can do a better job than the MS-8. Also, somebody that lives and breathes car audio and spends several hours per day tuning systems could possibly beat the MS-8....maybe. |
#24 | |
I usually recommend it to someone with a factory center who is swapping radios, have them run that over the oem amp and it cleans stuff up nicely. |
#25 |
If you are contemplating setting up a processor, you might want to visit DIYMA and read this how-to thread. It sounds interesting.
http://www.diymobileaudio.com/forum/...your-ears.html
| The Following User Says Thank You to mid_life_crisis For This Useful Post: | OnionTou (06-07-2013) |
#26 |
this is so far from the truth... all the guys i know that use them have 20+ years in audio and tuning plus all the tools to ensure a proper tune like RTA,MLS etc... the algorithms of the system suck plain and simple and they all run high end drivers and amps. The PS8 will whip the piss out of an MS8
#27 |
Guys whose services are made obsolete by a product don't like that product? Shocking.
#28 |
Drives: 2010 Subaru LGT
I have installed and tuned over 300 dsps..25 or so were ms8s. There r advantages and disadvantages of it versus a more traditional unit. I will try to elaborate more when im back from vacation.
But two things for sure. 1. Ms8 never did or will. Replace an experienced tuner in a car. It was never meant to be that. 2. Experience still counts a lot when setting up the ms8. I would not call it a dsp for someone with zero knowledge. Rather someone with good and solid fundamentals in audio can achieve decent results in as little as 10 to 15 mins. B Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Mobile Electronics Magazine Top 100 Installer 2012-2013
| gt 86 worth 40k!!!??? | 12345qwerty | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 04-13-2013 10:56 PM |
| Is the FR-S worth getting? | DIM | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 10-28-2012 11:43 PM |
| Is it worth it? | Greaser | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 08-10-2012 10:15 AM |
| is this worth doing | denverizzles | Engine, Exhaust, Transmission | 7 | 08-03-2012 11:35 AM |
| What's this worth? | Sport-Tech | Other Vehicles & General Automotive Discussions | 5 | 04-12-2012 10:21 AM |
